Appliance Repair Forum
-   Dishwasher Repair (http://forum.appliancepartspros.com/dishwasher-repair/)
-   -   Dishwasher (http://forum.appliancepartspros.com/dishwasher-repair/518921-dishwasher.html)
swallen 02-28-2013 06:08 PM
Dishwasher
Lights on the panel come on but the dishwasher will not start. If we flip the circuit breaker it will start even though the breaker was not off.
denman 03-01-2013 03:22 AM
I cannot find any info on the given model number.
Tried here and the Whirlpool site.
Please check it.
Sounds like a control board problem.
The4 microprocessor is not resetting by itself but when you remove power from the unit then you manually reset it.
swallen 03-01-2013 03:45 AM
Dishwasher problem
That may be a zero instead of an O on the model number. If it is the control board does that mean we would have to replace the whole board and what would be the cost?
denman 03-01-2013 08:36 AM
Already tried a zero.
swallen 03-01-2013 02:48 PM
Dishwasher
Sorry, the model is KUDSO3FTSS2
denman 03-02-2013 05:40 AM
1 Attachment(s)
Parts for Whirlpool KUDS03FTSS2 Dishwasher - AppliancePartsPros.com
I am assuming that everything looks normal after a cycle other than you cannot start another cycle.
Look through the tech sheet in case anything listed there comes up.
if all OK I would replace the control board (item 6 in Control Panel Parts section)
swallen 03-02-2013 03:07 PM
Dishwasher
Thank you for your help Denman. The PDF wouldn't open but I will check out the control board. That is what we expected.
denman 03-03-2013 02:07 AM
1 Attachment(s)
I do not know what happened with the tech sheet so here is another try at attaching it.
