Discuss
Frigidaire circ pump help
 in
Dishwasher Repair
Problem: Low water pressure coming out of circ. pump. Little sad spout of water comes straight up, then the little
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Frigidaire circ pump help
  #1 (permalink)
Old 02-24-2013, 02:48 PM
Junior Member
diablobob is on a distinguished road
Default Frigidaire circ pump help
Model Number: PLD4375RFC2   Brand: Frigidaire   Age: 1 - 5 years
Problem: Low water pressure coming out of circ. pump. Little sad spout of water comes straight up, then the little ball rolls back and blocks the upward spout and no water comes out of top tube, since the pressure is so low. I've run the diagnostics on the control panel and the pump motor appears to spin at the rpms it is asked to do (4 levels in the diagnostic test). Impeller looks like new. No binding anywhere. Stumped.
Unless...the motor decided to spin backwards. Hence my question...what is the right direct?
Looking down at the motor assembly from the impeller end, what is the correct spin direction? Clockwise or counter? ie, should the impeller spin with the scoops facing the direction of rotation, or the other way?
Mine is spinning counter clockwise, or with the scoops on the impeller "dragging" instead of "pushing" water.
final Q: If my pump is spinning backwards, Why? and what can I do about it?
Ads By Google
Related Models
Frigidaire PLD4375RFC2 DISHWASHER
Frigidaire PLD4375RFC3 DISHWASHER
Frigidaire PLD4460REC Frigidaire/dishwasher
Frigidaire PLD4555RFC0 Frigidaire/dishwasher
Frigidaire PLD4555RFC1 DISHWASHER
Frigidaire PLD4555RFC2 DISHWASHER
Frigidaire PLD4555RFC3 DISHWASHER
Frigidaire PLDB998AC0 Frigidaire/dishwasher
Frigidaire PLDB998AC1 Frigidaire/dishwasher
Frigidaire PLDB998CC0 Frigidaire/dishwasher
Frigidaire PLDB999AC0 Frigidaire/dishwasher
Frigidaire PLDB999CC0 Frigidaire/dishwasher
Frigidaire PLDS999CC0 Frigidaire/dishwasher
Frigidaire PLEB27M9ECA Frigidaire/wall Oven/microwave Combo
Frigidaire PLEB27M9ECB Frigidaire/wall Oven
Frigidaire PLEB27M9ECC Frigidaire/walloven - Microwave Combo
Frigidaire PLEB27M9ECD WALLOVEN-MICROWAVE COMBO
Frigidaire PLEB27M9ECE WALLOVEN-MICROWAVE COMBO
Frigidaire PLEB27S8ACA Frigidaire/electric Range
Frigidaire PLEB27S8ACB Frigidaire/electric Wall Oven
Frigidaire PLEB27S8CCA Frigidaire/electric Wall Oven
Frigidaire PLEB27S8CCB Frigidaire/electric Wall Oven
Frigidaire PLEB27S8CCC Frigidaire/wall Oven
Frigidaire PLEB27S9DCA Frigidaire/walloven
Frigidaire PLEB27S9DCB Frigidaire/electric Walloven
Frigidaire PLEB27S9FCA Frigidaire/wall Oven
Frigidaire PLEB27S9FCB Frigidaire/walloven
Frigidaire PLEB27S9FCC ELECTRIC OVEN
Frigidaire PLEB27S9FCD ELECTRIC OVEN
Frigidaire PLEB27S9FCE ELECTRIC OVEN
Frigidaire PLEB27S9FCF ELECTRIC OVEN
Frigidaire PLEB27T8ACA Frigidaire/electric Wall Oven
Frigidaire PLEB27T8ACB Frigidaire/electric Wall Oven
Frigidaire PLEB27T8CCA Frigidaire/electric Wall Oven
Frigidaire PLEB27T8CCB Frigidaire/electric Wall Oven
Frigidaire PLEB27T9DCA Frigidaire/walloven
Frigidaire PLEB27T9DCB Frigidaire/electric Walloven
Frigidaire PLEB27T9DCC Frigidaire/walloven
Frigidaire PLEB27T9FCA Frigidaire/wall Oven
Frigidaire PLEB27T9FCB Frigidaire/walloven
Frigidaire PLEB27T9FCC ELECTRIC OVEN
Frigidaire PLEB27T9FCD ELECTRIC OVEN
Frigidaire PLEB30M9ECA Frigidaire/wall Oven/microwave Combo
Frigidaire PLEB30M9ECC Frigidaire/wall Oven/microwave
Frigidaire PLEB30M9ECD Frigidaire/walloven - Microwave Combo
Frigidaire PLEB30M9ECE ELECTRIC OVEN W/MICROWAVE
Frigidaire PLEB30M9ECF ELECTRIC OVEN W/MICROWAVE
Frigidaire PLEB30S8ACA Frigidaire/electric Range
Frigidaire PLEB30S8ACB Frigidaire/electric Wall Oven
Frigidaire PLEB30S8CCA Frigidaire/electric Wall Oven
Frigidaire PLEB30S8CCB Frigidaire/wall Oven
Frigidaire PLEB30S8CCC Frigidaire/wall Oven
Frigidaire PLEB30S9DCA Frigidaire/walloven
Frigidaire PLEB30S9DCB Frigidaire/electric Walloven
Frigidaire PLEB30S9FCA Frigidaire/wall Oven
Frigidaire PLEB30S9FCB Frigidaire/wall Oven
Frigidaire PLEB30S9FCC ELECTRIC OVEN
Frigidaire PLEB30S9FCD ELECTRIC OVEN
Frigidaire PLEB30S9FCF ELECTRIC OVEN
Frigidaire PLEB30T8ACA Frigidaire/electric Wall Oven
Frigidaire PLEB30T8ACB Frigidaire/electric Wall Oven
Frigidaire PLEB30T8CCA Frigidaire/wall Oven
Frigidaire PLEB30T8CCB Frigidaire/electric Wall Oven
Frigidaire PLEB30T9DCA Frigidaire/electric Walloven
Frigidaire PLEB30T9DCB Frigidaire/wall Oven
Frigidaire PLEB30T9DCC Frigidaire/walloven
Frigidaire PLEB30T9FCA Frigidaire/wall Oven
Frigidaire PLEB30T9FCB Frigidaire/walloven
Frigidaire PLEB30T9FCC ELECTRIC OVEN
Frigidaire PLEB30T9FCD ELECTRIC OVEN
Frigidaire PLEB30T9FCE ELECTRIC OVEN
Frigidaire PLEC30S9ECA Frigidaire/electric Cooktop
Frigidaire PLEC30S9ECB Frigidaire/electric Cooktop
Frigidaire PLEC30S9ECC Frigidaire/cooktop
Frigidaire PLEC36S9ECA Frigidaire/electric Cooktop
Frigidaire PLEC36S9ECB Frigidaire/electric Cooktop
Frigidaire PLEC36S9ECC Frigidaire/cooktop
Frigidaire PLEF398ACA Frigidaire/range
Frigidaire PLEF398ACB Frigidaire/electric Range
Frigidaire PLEF398ACC Frigidaire/electric Range
Frigidaire PLEF398CCA Frigidaire/electric Range
Frigidaire PLEF398CCB Frigidaire/electric Range
Frigidaire PLEF398CCC Frigidaire/electric Range
Frigidaire PLEF398CCD Frigidaire/electric Range
Frigidaire PLEF398CCE Frigidaire/electric Range
Frigidaire PLEF398DCA Frigidaire/electric Range
Frigidaire PLEF398DCB Frigidaire/electric Range
Frigidaire PLEF398DCC Frigidaire/electric Range
Frigidaire PLEF398DCD Frigidaire/range
Frigidaire PLEF398DCE Frigidaire/range
Frigidaire PLEF398DCH Frigidaire/range
Frigidaire PLEF398DCJ Frigidaire/electric Range
Frigidaire PLEF489ACA Frigidaire/electric Range
Frigidaire PLEF489ACB Frigidaire/electric Range
Frigidaire PLEF489ACC Frigidaire/electric Range
Frigidaire PLEF489ACD Frigidaire/electric Range
Frigidaire PLEF489CCA Frigidaire/electric Range
Frigidaire PLEF489CCB Frigidaire/electric Range
Frigidaire PLEF489CCC Frigidaire/electric Range
Frigidaire PLEF489CCD Frigidaire/electric Range
Frigidaire PLEF489CCE Frigidaire/electric Range
Frigidaire PLEF489CCF Frigidaire/electric Range
Frigidaire PLEF489CCG Frigidaire/electric Range
Frigidaire PLEF489CCH ELECTRIC RANGE
Frigidaire PLEF489GCA ELECTRIC RANGE
Frigidaire PLEFM399DCA Frigidaire/electric Range
Frigidaire PLEFM399DCB Frigidaire/electric Range
Frigidaire PLEFM399DCC Frigidaire/electric Range
Frigidaire PLEFM399DCD Frigidaire/range
Frigidaire PLEFMZ99ECA Frigidaire/range
Frigidaire PLEFMZ99ECC Frigidaire/range
Frigidaire PLEFMZ99ECE Frigidaire/electric Range
Frigidaire PLEFMZ99ECF Frigidaire/electric Range
Frigidaire PLEFMZ99ECG Frigidaire/range
Frigidaire PLEFMZ99ECJ Frigidaire/electric Range
Frigidaire PLEFMZ99ECK Frigidaire/range
Frigidaire PLEFMZ99ECM ELECTRIC RANGE
Frigidaire PLEFMZ99ECN ELECTRIC RANGE
Frigidaire PLEFMZ99GCA ELECTRIC RANGE
Frigidaire PLEFMZ99GCB ELECTRIC RANGE
  #2 (permalink)
Old 02-25-2013, 02:34 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hello,
How much water is in the dishwasher during the wash cycle?
Quote:
... I've run the diagnostics on the control panel and the pump motor appears to spin at the rpms it is asked to do...
What was the number of RPM?
CCW is the correct direction for the motor.
Here are the breakdown diagrams and Parts for Frigidaire PLD4375RFC2 Dishwasher - AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 02-25-2013, 02:44 PM
Junior Member
Default
Thanks, Gene. I filled the tub up to the bottom of the overflow float. RPM indicator was "34" (3400?). That's what the sheet said it should show.
I've determined that mine is spinning the right direction. So...how can the motor be "at speed" but the impeller not driving enough water? I'm stumped.
  #4 (permalink)
Old 02-26-2013, 01:32 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
This model dishwasher use a variable speed DC motor. The speed of the motor is determined by the electronic control based on the cycle selected. The control continually monitors motor speed with input from a Hall Effect sensor mounted to the rear of the wash motor. Input voltage for operating the motor will be 120 VAC with the motor changing this to VDC with a build-in rectifier.
Because of the test result shown the correct RPM I would suggest to replace the motor. It could be the impeller slipping on the motor shaft or a problem with the Hall Effect sensor.
- The motor kit Part number: 154844101
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replacement Circ Pump Motor Assembly Question me1 Dishwasher Repair 0 11-27-2011 06:05 PM
dacor relay circ failure rmass Oven Repair (including Ranges and Cooktops) 0 10-22-2010 11:35 AM
Bosch shu66c02uc/14 needs Circ pump luweee Dishwasher Repair 3 08-18-2010 03:00 PM
Frigidaire Pro Series main circ. pump inop butternut Dishwasher Repair 4 09-14-2009 07:07 PM
Circ pump motor/capacitor connections sunwind Dishwasher Repair 7 01-28-2008 01:49 AM
