Discuss
Gu2475xtvy0
 in
Dishwasher Repair
A year ago,I purchased a new membrane keypad becaue one button was cracked. Did not put it in then ,
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Gu2475xtvy0
  #1 (permalink)
Old 02-23-2013, 08:19 AM
Junior Member
jimbo6679 is on a distinguished road
Default Gu2475xtvy0
Brand: Whirlpool   Age: 1 - 5 years
A year ago,I purchased a new membrane keypad becaue one button was cracked. Did not put it in then , but now need to do it. I have the parts diagram, but not a service manual. Can I do this repair by removing the top two screws on each side of the inner door, plus screws at latch..or do I have to completely take apart the inner door?
Also, I noted that the control panel is NOW sold as a complete assembly including the plastic "body" but I have just the membrane itself. Will this be OK? The problem is that the buttons are cracking. Everything still works, and wife has been using scotch tape over the buttons...but this will not last!!
Actually, I just opened the box with my part and it is the complete panel assembly, so my only question is how to get the old one out to access the ribbon connector.
Thank you very much.
Ads By Google
  #2 (permalink)
Old 02-24-2013, 02:12 PM
Junior Member
Default
Well, we got it done! Turns out you do have to remove ALL the screws on both sides of inner door, so the front panel will drop away far enough to access the latch assembly, and control board, both of which have to be moved over to the new panel.
Seems to be working fine, will keep an eye out for door leaks for a few days.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
