Rjsgvc
This dishwasher was working fine until 5 days ago when I noticed water coming from beneath the unit and found that a clamp failed on the hose from the filter area to the pump came off. I replaced the hose and clamp and that problem seems resolved. However, also at that time the clean light began flashing 6 times quickly followed by 1 more. Appliancepartspros said the control board was faulty and needed to be replaced. So I've replaced the board and the clean light has stopped flashing but I can't get the machine to start a cycle. I push the setting buttons and machine won't load the water and after a minute or so the cycle setting lights go off without starting the cycle. What's next??
Ads By Google
Related Models
