| » Dishwasher has slow drain |
Model Number: GSD4430 Brand: GE Age: 5 - 10 years
I have a GE dishwasher and was getting a C1 code for a while which turned into a C2 Code and now the washer will beep and shut down about 10 minutes into the first cycle
I checked the drain hose and there is no obstruction. I cleaned out the well and didnt find any obstruction and then I pulled the unit out, disconnected the water line and then unscrewed what I call the check valve and found the black flapper piece inside. It seemed a bit distorted do I cleaned it up and lubricated it with vaseline so it could flap back and forth and reconnected everything. It worked for about 1 or 2 entire cycles after that and then went back to C1 and now I am back to C2 I cant even find this part on the APP site. Am I on the right track here? Is there something else I can do to determine if this is the problem? thanks in advance for help Ads By Google Related Models |
| Display Modes | |
| Whirlpool won't drain, then spins VERY slow | nswaibel | Washer Repair | 4 | 11-09-2009 11:34 AM |
| spins slow and wont drain | kaavman66 | Washer Repair | 1 | 07-07-2009 03:48 PM |
| GE Top Load - Very Slow Drain | nemo594 | Washer Repair | 1 | 04-21-2009 11:55 AM |
| Kenmore dishwasher slow drain | JATC | Dishwasher Repair | 1 | 07-21-2008 09:04 PM |
| drain and spin is slow | jmay | Washer Repair | 1 | 02-28-2008 02:38 PM |
