| » dishwasher not draining completly |
Model Number: dp920pfgy1 Brand: Whirlpool Age: 5 - 10 years
dishwasher doesnt drain completely lots of water still in bottom and starts to stink any sugestions thanks
My whirlpool dw did the same thing. There is a check valve in the elbow of the drain tube that attaches to the dw. Mine was leaking and allowing water to run back from the drain. Sounds like you are getting water from the disposer. I suggest replacing the drain tube, not with a generic one from a home improvement store, but an official one from here that has that valve in it.
Hello,
There is a check valve screwed into the pump (#15 at the diagram). Remove the toe panel. Disconnect the drain hose from the check valve (be prepared to catch water remaining inside the pump and the hose). Unscrew the check valve and check for a clog inside. Replace the check valve if it's broken. - The check valve Part number: 675238 Here are the breakdown diagrams and Parts for Whirlpool DP920PFGY1 Dishwasher - AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| Dishwasher not draining completly | TLR1969 | Dishwasher Repair | 3 | 07-09-2011 01:34 PM |
| Dish Washer Not Completly Draining | johnspoa | Dishwasher Repair | 5 | 01-11-2011 03:17 AM |
| touch pad completly out | rloubame | Oven Repair (including Ranges and Cooktops) | 3 | 11-03-2010 03:43 PM |
| Dishwasher not drain completly after is done washing | nicamex | Dishwasher Repair | 0 | 06-01-2010 10:07 AM |
| Dishwasher doesnt fill completly | kenson | Dishwasher Repair | 1 | 01-07-2008 06:00 AM |
