Discuss
It has only been used 7 times and it isn't working
 in
Dishwasher Repair
Model 363.14458692, Ser: RS325729R. We installed the DW 15 years ago and ran it once every 14 months for the
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » It has only been used 7 times and it isn't working
  #1 (permalink)
Old 02-07-2013, 10:46 AM
Junior Member
minmn is on a distinguished road
Unhappy It has only been used 7 times and it isn't working
Brand: Kenmore   Age: More than 10 years
We installed the DW 15 years ago and ran it once every 14 months for the first 10 years. Five years ago we turned the water off and just let the DW sit. Instead, we hand wash, as there is only 2 people.
Does sitting unused for years wreck parts in a DW?
I went to turn the DW on yesterday. I forgot the water was off. It was silent for a minute or 2 and then just a motor hum for the next 4-5 minutes.
I turned the DW off, restarted it from the beginning and got no motor noise. I noticed an slight odd smell [burning or smoking smell??].
Remembering the water, I turned the water back on.
This still did not make the machine work. It was still silent when I tried a 3rd time to restart it. I turned it off after 2 minutes.
Did running the DW with the water off wreck a part?
Any ideas?
thank you, Mrs. J
Ads By Google
  #2 (permalink)
Old 02-08-2013, 03:13 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Yes it can. Seals etc. can dry out and crack etc.
I would say yes.
You probably overheated/melted the motor to pump seals and now the motor is seized.
__________________
  #3 (permalink)
Old 02-08-2013, 05:23 AM
Junior Member
Exclamation Yikes, is it repairable?
If I "overheated/melted the motor to pump seals and now the motor is seized", is this repairable?
Does it mean a new motor?
Is that cost effective?
Thanks for any help.
  #4 (permalink)
Old 02-08-2013, 06:33 AM
Senior Expert
APP Volunteer
Default
I could not find a parts list for the given model number.
Yes it is repairable.
I would replace the motor/pump assembly but if you are mechanically inclined you could replace the seals.
There is a possibility that you burned out the motor so that is why I would go with the motor assembly plus it is much easier.
A new motor assembly will run you about $150.00
In your case it does not sound cost effective because you do not use the unit.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
"Clean" icon blinks 7 times, stop, 7 times keyarrow Dishwasher Repair 2 11-01-2012 11:36 AM
Washer works properly at times and stops between wash and spin/pump cycles at times sawgrassusa Washer Repair 0 02-26-2011 08:02 AM
tried three times Steven1 Dishwasher Repair 0 04-18-2010 05:51 PM
dry shuts off/times out Mike the barber Dryer Repair 0 11-22-2009 10:47 AM
