Discuss
Kenmore elete dishwasher
 in
Dishwasher Repair
I have a question. I want to buy parts but not really sure what I should buy. I have to
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Kenmore elete dishwasher
  #1 (permalink)
Old 02-04-2008, 01:39 PM
MichelleHoliday MichelleHoliday is offline
Junior Member
MichelleHoliday is on a distinguished road
Question Kenmore elete dishwasher
Model Number: 665.16493300   Brand: Kenmore   Age: 1 - 5 years
I have a question. I want to buy parts but not really sure what I should buy. I have to pull out the grinder about every few loads and clean it out. I am not sure if I just need to replace the grinder or if I need to buy the part that causes the grinder to run, there must be some kind of motor? Everything else works fine it just doesn't grind food. Can anybody help me?
Michelle
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-04-2008, 08:21 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Michelle,
The best way to prevent such problem is to remove all food particles from your dishes prior to load the dishwasher.
The chopper is attached to the main wash motor and you do not have to replace the chopper if it's not damaged.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 02-04-2008, 11:39 PM
Junior Member
Default Dishwasher Chopper
I am not sure if the chopper is out or not. It does not work and the rest of the dishwasher seems to. It is a lot of work to wash off all the food particles, I have ten kids plus andother who lives with us so there are a lot of dishes to get food particles off of. If the rest of the dishwasher is working fine and the only problem is that it isn't grinding food how would you tell if it were just the grinder and not hte main motor part that is connected? I hope I made sense?
Michelle
  #4 (permalink)
Old 02-05-2008, 03:20 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Just replace the chopper assembly, the main motor impeller and the check valve in the housing to the right of the chopper. The check valve back flows the chopper screen in pump out and the motor impeller gets worn with the chopper shaft.
__________________
  #5 (permalink)
Old 02-06-2008, 10:45 AM
Junior Member
Thumbs up impeller motor?
Do I need to buy a motor or the impeller assembly kit? Thank you for you help. It is greatly appreciated and I can't wait to get my dishwasher up and running again.
Michelle
  #6 (permalink)
Old 02-06-2008, 11:39 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Michelle,
Here are the parts you have to order:
- The chopper assembly - AP3039186
- The impeller kit - AP3738238
- The washer - AP3179654
- The check valve - AP3152971
Good luck.
__________________
  #7 (permalink)
Old 02-06-2008, 04:02 PM
Senior Expert
APP Volunteer
Default
Carefully look at the white coupler end of the chopper, if it is worn, you will need to replace the motor impeller, the motor should be ok. You will need to pull the dishwasher to do this.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
kenmore dishwasher adrian Dishwasher Repair 3 02-01-2008 12:35 PM
kenmore dishwasher plumber75 Dishwasher Repair 3 01-29-2008 11:57 AM
kenmore dishwasher AMSM Dishwasher Repair 3 01-28-2008 06:32 PM
Kenmore Dishwasher Problem imanurse Dishwasher Repair 1 12-11-2007 08:53 PM
Kenmore Dishwasher PRESLEY Dishwasher Repair 1 10-19-2007 03:47 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
