Discuss
Dead Bosch Dishwasher
 in
Dishwasher Repair
Someone knowledgeable (Gene, others?). I have a Bosch SHV99A03UC that just died. No display. Nothing. Was working perfectly up to
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dead Bosch Dishwasher
  #1 (permalink)
Old 02-03-2013, 09:16 AM
Junior Member
rowingupstream is on a distinguished road
Default Dead Bosch Dishwasher
Model Number: SHV99A03UC   Brand: Bosch   Age: 5 - 10 years
I have a Bosch SHV99A03UC that just died. No display. Nothing. Was working perfectly up to that point. Not a circuit breaker issue.
I am guessing control or switch; display lit momentarily at one point but died a moment later, so anticipate some sort of intermittent.
A source for a repair manual would be nice,, for disassembly, assembly guidance. Any suggestions for places to look would be welcome.
Thanks,
Don
Ads By Google
Related Models
Hoover SHWA2501A Washer - Top Loading
Hoover SHWA2501W Washer - Top Loading
Hoover SHWA2506A Washer - Top Loading
Hoover SHWA2506AT Washer - Top Loading
Hoover SHWA2506W Washer - Top Loading
Hoover SHWA2506WT Washer - Top Loading
Hoover SHWA2507A Washer - Top Loading
Hoover SHWA2507V Washer - Top Loading
Hoover SHWA2507W Washer - Top Loading
Bosch SHX33A02 UC/14 (FD 8211-)
Bosch SHX33A05 UC/14 (FD 8211-)
Bosch SHX33A06 UC/14 (FD 8211-)
Bosch SHX43E02 UC/14 (FD 8211-)
Bosch SHX43E05 UC/14 (FD 8211-)
Bosch SHX43E06 UC/14 (FD 8211-)
Bosch SHX46A02 UC/14 (FD 8211-)
Bosch SHX46A05 UC/14 (FD 8211-)
Bosch SHX46A06 UC/14 (FD 8211-)
Bosch SHX46A07 UC/14 (FD 8211-)
Bosch SHX46B02 UC/14 (FD 8211-)
Bosch SHX46B05 UC/14 (FD 8211-)
Bosch SHX46B06 UC/14 (FD 8211-)
Bosch SHX46B07 UC/14 (FD 8211-)
Bosch SHX56B02 UC/14 (FD 8211-)
Bosch SHX56B05 UC/14 (FD 8211-)
Bosch SHX56B06 UC/14 (FD 8211-)
Bosch SHX99B05 UC/14 (FD 8212-)
Bosch SHX99B06 UC/14 (FD 8212-)
Bosch SHY56A02 UC/14 (FD8301-)
Bosch SHY56A05 UC/14 (FD8301-)
Bosch SHY56A06 UC/14 (FD8301-)
Bosch SHY66C02 UC/14 (FD8301-)
Bosch SHY66C05 UC/14 (FD8301-)
Bosch SHY66C06 UC/14 (FD8301-)
Bosch SHY99A02 UC/14 (FD 8212-)
Bosch SHY99A05 UC/14 (FD 8212-)
Bosch SHY99A06 UC/14 (FD 8212-)
Amana SI19E Ref - SXS/I&W
General Electric SIG7010ET1WG Electric dryer
International SILVER22 Ref - SXS/I&W
International SILVER24 Ref - SXS/I&W
Maytag SK525-2W  Ref - Sxs
Maytag SK535-2  Ref - SXS/I&W
Gaggenau SK590-2  Ref - Bottom Mounts
Hardwick SKG4622MGA639R Range - F/s Cont Clean Gas
Hardwick SKG4622MGW639R Range - F/s Cont Clean Gas
Hardwick SKG9611A540R Range - F/s Cont Clean Gas
Hardwick SKG9611W540R Range - F/s Cont Clean Gas
Amana SKI22F Ref - SXS/I&W
Amana SKI22F-A Ref - SXS/I&W
Amana SKI22F-C Ref - SXS/I&W
Amana SKI22F-G Ref - SXS/I&W
Amana SKI22FL Ref - SXS/I&W
Hardwick SKJ7141819DE Walloven - Cont Clean Gas
Maytag SL10AA Stacked Laundry - Ele
Maytag SL10AA-A01 Stacked Laundry - Ele
Maytag SL10AN Stacked Laundry - Ele
Maytag SL10AN-A00 Stacked Laundry - Ele
Maytag SL10AN-A01 Stacked Laundry - Ele
Maytag SL10AN-A02 Stacked Laundry - Ele
Maytag SL10AN-A03 Stacked Laundry - Ele
Maytag SL11AA Stacked Laundry - Ele
Maytag SL11AN Stacked Laundry - Ele
General Electric SL208 Room air conditioner
General Electric SL210 Room air conditioner
General Electric SL212 Room air conditioner
General Electric SL214 Room air conditioner
General Electric SL217 Room air conditioner
General Electric SL220 Room air conditioner
General Electric SL223 Room air conditioner
Amana SL22F Ref - SXS/I&W
Amana SL22F-A Ref - SXS/I&W
Amana SL22F-C Ref - SXS/I&W
Amana SL22F-G Ref - SXS/I&W
Amana SL22F-L Ref - SXS/I&W
Amana SL22G Ref - SXS/I&W
Amana SL22GL Ref - SXS/I&W
Amana SL22JB Ref - SXS/I&W
Amana SL22MBG Ref - SXS/I&W
Amana SL22MBL Ref - SXS/I&W
Amana SL22MBW Ref - SXS/I&W
Amana SL25G Ref - SXS/I&W
Amana SL25GL Ref - SXS/I&W
Amana SL25H Ref - SXS/I&W
Amana SL25J Ref - SXS/I&W
Amana SL25M2L Ref - SXS/I&W
Amana SL25M2W Ref - SXS/I&W
Amana SL25MG Ref - SXS/I&W
Amana SL25ML Ref - SXS/I&W
Amana SL25MW Ref - SXS/I&W
Amana SLD22JB Ref - SXS/I&W
Amana SLD22MB2L Ref - SXS/I&W
Amana SLD22MB2W Ref - SXS/I&W
Amana SLD22MBG Ref - SXS/I&W
Amana SLD22MBL Ref - SXS/I&W
Amana SLD22MBW Ref - SXS/I&W
Amana SLD25J Ref - SXS/I&W
  #2 (permalink)
Old 02-05-2013, 01:44 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Don,
You may want to start the troubleshooting from verifying the power supply to the dishwasher.
Remove the toe panel and check the power cord connections to the dishwasher junction box. Make sure that the power cord hot (black) wire is connected to the dishwasher black wire, the neutral (white) wire is connected to the dishwasher white wire and the dishwasher is properly grounded.
Check the wires at the door bottom edge for any physical damage.
Check the on-off switch for continuity in accordance with the wiring diagram.
Post the results.
Here are the breakdown diagrams and Parts for Bosch SHV99A03 UC/14 (FD 8212-) Dishwasher - AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 02-13-2013, 06:59 AM
Junior Member
Default
Gene,
Thanks for the advice. I checked power and wires and all were okay. I checked the switch and it appeared not have continuity between 1-2 when closed, so got a replacement power switch P/N 175338 - which curiously seems to have the same issue with respect to continuity. Hard to believe a new power switch would have same problem as the old.
In the process of testing dishwasher with both switches, I noticed the same behavior with each - illegible, faint flickering of the display when the unit was powered on - but no operation whatsoever. Should I be looking at the control or the display modules instead?
Thanks,
Don
  #4 (permalink)
Old 02-13-2013, 08:30 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Don,
Check for 120 VAC between the wire connected to the terminal 3 at the on-off switch and the ground. If the reading is correct, check for 120 VAC between this wire and the wire connected to the terminal 1. Post the results.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dead control panel on Bosch Range rcavalie Oven Repair (including Ranges and Cooktops) 1 04-14-2013 09:15 PM
My Bosch SHU43C07 is dead wyesguy Dishwasher Repair 0 04-19-2010 10:05 AM
Bosch Dishwasher Dead ejluhn720 Dishwasher Repair 0 06-27-2009 01:21 PM
Bosch dishwasher dead mid-cycle FoleyPhoto Dishwasher Repair 1 02-17-2009 07:44 PM
