| » GE dishwasher won't drain |
Model Number: GSD2030F01WW Brand: GE Age: 5 - 10 years
I am troubleshooting this dishwasher at a rental that wont drain. I checked the motor with my multimeter and it's fine, and the solenoid moves up and down but the reading on the mm was 16 ohms (I think - new at using this device).
I checked the sump cover and cap and they seem okay. I couldn't get the drain hose off at the bottom, but I took it off at the connection to the sink drain and blew into it, and saw air bubbles. Not sure what to do next - double check the solenoid wi the mm or perhaps the water inlet valve? Am I missing something obvious? Thanks! Ads By Google Related Models |
Hi.
Disconnect the drain hose from the air-gap and put it into the bucket. With the kick panel off start the dishwasher and when it's full with water advance the timer to the drain position. Check if the motor runs and the plunger goes into the drain solenoid all the way and the gate shaft is turning. If the water drains from the hose full pressure, then you need to clean or replace the air-gap. In case of "no drain"- turn the power off, remove the drain hose from the pump, make sure the hose and the pump outlet are not blocked. If everything looks OK - replace the motor/pump assembly Part number: WD26X10013 Here are the breakdown diagrams and Motor-Pump Mechanism parts for GE GSD2030F01WW - AppliancePartsPros.com Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. Last edited by Simon / APP Team : 01-30-2013 at 12:45 PM. |
| Display Modes | |
| Fridigaire dishwasher no power to the dishwasher and water will not drain out | jarhead1984 | Dishwasher Repair | 0 | 02-27-2012 07:43 AM |
| Dishwasher won't drain, push cancel/drain button will clicking then hum, no draining | bluelakes77 | Dishwasher Repair | 0 | 11-10-2011 09:17 PM |
| Dishwasher drain motor not spinning and won't drain | bwp | Dishwasher Repair | 1 | 01-02-2011 03:39 PM |
| Dishwasher Won't Drain | Paul5362 | Dishwasher Repair | 2 | 05-18-2010 03:32 PM |
| dishwasher will not drain (drain pump is new) | jkda1975 | Dishwasher Repair | 1 | 04-06-2010 01:56 PM |
