Discuss
Maytag WU 482 Problem
 in
Dishwasher Repair
I have an 'older' Maytag dishwasher WU 482. It has been working fine until recently. Currently it will not drain
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Maytag WU 482 Problem
  #1 (permalink)
Old 09-30-2009, 06:19 PM
Junior Member
russelltribe is on a distinguished road
Unhappy Maytag WU 482 Problem
Model Number: WU 482   Brand: Maytag   Age: More than 10 years
I have an 'older' Maytag dishwasher WU 482. It has been working fine until recently. Currently it will not drain and will not work in any mode except low energy mode. When I turn the dial to other settings the timer runs (ticks) and the dial rotates thru the different cycles. I can hear it click as it enters a new cycle, but nothing works until it gets to the Low Energy cycle, then it fills up and goes thru a wash cycle. It finishes the wash cycle but does not drain. The dry cycle still works but the tub is full of water. The motor is working and the belt is in good condition. I recently replaced the drain switch fixture and the unti had been working for about a week after this replacement. I believe my kids were playing with the dial, cranking it around. I opened up the control panel and checked the wires and the connections, all look good, I did not do a voltage check yet. Could this be (1) an implerer/pump issue (2) timer motor or (3) timer board and motor unit. Is there a way to test the motor or board? I would like to keep the unit since the tub is in very good shape and is steel vs. plastic. Any help would be greatly appreciated
Ads By Google
Related Models
Whirlpool WU0800B
Whirlpool WU0800XX0
Whirlpool WU0800XX1
Maytag WU100 Dishwasher - Undercounter
Maytag WU1000 Dishwasher - Undercounter
Whirlpool WU1000X0
Whirlpool WU1000X1
Whirlpool WU1000X4
Whirlpool WU1000X5
Whirlpool WU1000X6
Whirlpool WU1000X7
Whirlpool WU1000X8
Whirlpool WU1000Y0
Whirlpool WU1000Y1
Maytag WU1004 Dishwasher - Undercounter
Maytag WU1005 Dishwasher - Undercounter
Maytag WU101 Dishwasher - Undercounter
Maytag WU103 Dishwasher - Undercounter
Maytag WU104 Dishwasher - Undercounter
Maytag WU180 Dishwasher - Undercounter
Whirlpool WU1800XX0
Frigidaire WU180T1BLACK Wwh(v5) / 18 " Dishwasher
Frigidaire WU180TF1 Wwh(v3) / 18 " Dishwasher
Frigidaire WU180TH1 Wwh(v2) / 18 " Dishwasher
Frigidaire WU180TR1 Wwh(v1) / 18 " Dishwasher
Frigidaire WU180TV1 Wwh(v4) / 18 " Dishwasher
Frigidaire WU180TW1 Wwh(v6) / 18 " Dishwasher
Maytag WU181 Dishwasher - Undercounter
Maytag WU200 Dishwasher - Undercounter
Maytag WU201 Dishwasher - Undercounter
Maytag WU202 Dishwasher - Undercounter
Maytag WU203 Dishwasher - Undercounter
Maytag WU204 Dishwasher - Undercounter
Maytag WU282 Dishwasher - Undercounter
Maytag WU284 Dishwasher - Undercounter
Maytag WU285 Dishwasher - Undercounter
Maytag WU300 Dishwasher - Undercounter
Whirlpool WU3000V0
Whirlpool WU3000V1
Whirlpool WU3000V2
Whirlpool WU3000V3
Whirlpool WU3000X0
Whirlpool WU3000X1
Whirlpool WU3000X2
Whirlpool WU3000X3
Whirlpool WU3000X4
Whirlpool WU3000X5
Whirlpool WU3000X6
Whirlpool WU3000Y0
Whirlpool WU3000Y1
Whirlpool WU3006V0
Whirlpool WU3006V1
Whirlpool WU3006V2
Whirlpool WU3006V3
Whirlpool WU3006X0
Whirlpool WU3006X1
Whirlpool WU3006X2
Whirlpool WU3006X3
Whirlpool WU3006X4
Whirlpool WU3006X5
Whirlpool WU3006X6
Whirlpool WU3006Y0
Whirlpool WU3006Y1
Maytag WU301 Dishwasher - Undercounter
Maytag WU302 Dishwasher - Undercounter
Maytag WU303 Dishwasher - Undercounter
Maytag WU304 Dishwasher - Undercounter
Whirlpool WU3050Y0
Whirlpool WU3050Y1
Whirlpool WU3056Y0
Whirlpool WU3056Y1
Maytag WU384 Dishwasher - Undercounter
Maytag WU400 Dishwasher - Undercounter
Maytag WU401 Dishwasher - Undercounter
Maytag WU404 Dishwasher - Undercounter
Whirlpool WU4300B0
Whirlpool WU4300B1
Whirlpool WU4300Y0
Whirlpool WU4300Y1
Whirlpool WU4300Y2
Whirlpool WU4300Y3
Whirlpool WU4300Y4
Whirlpool WU4400V0
Whirlpool WU4400V1
Whirlpool WU4400V2
Whirlpool WU4400V3
Whirlpool WU4400X0
Whirlpool WU4400X1
Whirlpool WU4400X2
Whirlpool WU4406V1
Whirlpool WU4406V3
Whirlpool WU4500B0
Whirlpool WU4500B1
Whirlpool WU4500Y0
Whirlpool WU4500Y1
Whirlpool WU4500Y2
Whirlpool WU4500Y3
Maytag WU482 Dishwasher - Undercounter
Maytag WU484 Dishwasher - Undercounter
Maytag WU490 Dishwasher - Undercounter
Maytag WU494 Dishwasher - Undercounter
Maytag WU500 Dishwasher - Undercounter
Maytag WU501 Dishwasher - Undercounter
Maytag WU502 Dishwasher - Undercounter
Maytag WU504 Dishwasher - Undercounter
Whirlpool WU5650V0
Whirlpool WU5650V1
Whirlpool WU5650V2
Whirlpool WU5650X0
Whirlpool WU5650X1
Whirlpool WU5650X2
Whirlpool WU5750B0
Whirlpool WU5750B1
Whirlpool WU5750Y0
Whirlpool WU5750Y1
Whirlpool WU5750Y2
Whirlpool WU5750Y3
Whirlpool WU5755B0
Whirlpool WU5755B1
Maytag WU600 Dishwasher - Undercounter
  #2 (permalink)
Old 09-04-2010, 01:05 PM
Junior Member
ovhdcam is on a distinguished road
Default Maytag WU482 pump out
We have the same dishwasher and had a similar problem. This model uses a dual-direction pump with a soft rubber impeller. Over time, the impeller swells and begins to drag on the inside of the pump housing. Since the impeller has a swept look, it runs fine in wash mode but digs in to the housing during the drain, dramatically increasing the load on the motor. Depending on the condition of components, the complete wash cycle may not complete before the motor overheats and the thermal protection stops it. It was a very simple matter of replacing the impeller (actually, a complete pump kit) and it works perfectly again. This is a great machine.
  #3 (permalink)
Old 10-19-2010, 02:17 PM
Junior Member
nitronorm is on a distinguished road
Default nitronorm
Hey I think it's your timer on the drain cycle lost contact in the timer burned out.. If you are handy you can check this out with an volt the pump runs on was to wash the other way to drain.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
MAYTAG problem neefly Dishwasher Repair 0 12-08-2009 07:41 PM
Maytag Dryer problem cptcaveman73 Dryer Repair 0 10-14-2009 10:14 AM
maytag washer problem nowash Dishwasher Repair 1 04-26-2009 03:37 PM
Maytag Washer Problem Mike B Washer Repair 9 09-03-2008 02:05 PM
Maytag problem J-Reb Dryer Repair 1 07-27-2007 09:23 PM
