| » dishwasher underfills |
Model Number: 66517263402 Brand: Kenmore Age: 1 - 5 years
Waterline and water inlet valve are clear, valve has 1000 ohms resistance, control panel delivers 99 volts to water inlet valve when directly connected to voltmeter. The float moves freely and is not stuck in the up position or obstructed. Is it the water inlet valve or the control panel? Can I test for improved water flow by directly connecting 120 volts to the valve? Any suggestions?
Hello,
99 VAC is definitely out of range. Check the voltage at the wall outlet. It suppose to be 120 VAC ± 10%. If the reading is correct, replace the control board. - The control board Part number: 8564547 Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| Fridigaire dishwasher no power to the dishwasher and water will not drain out | jarhead1984 | Dishwasher Repair | 0 | 02-27-2012 07:43 AM |
| Dishwasher control lights out and dishwasher stopped working | hatchchuck | Dishwasher Repair | 1 | 12-26-2010 04:48 AM |
| Dishwasher will not empty no lights on front of dishwasher except led lines | badtothebone | Dishwasher Repair | 0 | 05-13-2010 02:17 PM |
| Dishwasher will not empty no lights on front of dishwasher except led lines | badtothebone | Dishwasher Repair | 0 | 05-13-2010 02:14 PM |
| dishwasher spray arm melted to heating element and now dishwasher not working | msphillips2 | Dishwasher Repair | 0 | 05-08-2010 10:21 AM |
