Discuss
start button not woking on dishwasher.
 in
Dishwasher Repair
I found this post and found a problem. Hello tigergurle. You will need to disconnect the power to the unit.
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » start button not woking on dishwasher.
  #1 (permalink)
Old 01-24-2013, 06:21 AM
Junior Member
ALB64 is on a distinguished road
Default start button not woking on dishwasher.
Model Number: mdbh965awb   Brand: Maytag   Age: 5 - 10 years
Hello tigergurle. You will need to disconnect the power to the unit. Then remove all the screws on the inner door panel and remove the inner door panel. Once removed, you will need to remove the cover on the control board and remove the ribbon cable from the control board. On the ribbon cable is an arrow by one of the contacts. The arrow is number 1. You will need to test across pins 10 and 6. When you push the start/cancel button, the contact should close for continuity. If it does not, you will need to replace the control panel. If the control panel needs replaced, you will remove the screws holding the control board in place. Then remove the screws holding the control panel in place. Reinstall in reverse order. Hope this helps.
Part number: AP4364316
When I did this I found that there was 12 ohms across the #6 and 10 pin.
pushing the button does not change anything so I think the button is fried.The ribbon cable was disconnected. Also I can not feel the "click" when pushing the button.
Looks like I need to replace the whole front panel to fix this.
Is this correct?
After rethinking this these instructions do not make sense so I rechecked with ribbon cable connected because that is where the signal is coming from via the the start button and now I can see the switch is working and a change in the ohm reading whenever I push the start button. And I actually got the dishwasher to start but I still think it will fail to start the next time. Any help would be great!
Ads By Google
Related Models
Maytag MDBH965AWB 30" Electric Freestanding Standard Clean Range
Maytag MDBH965AWQ Dishwasher - Undercounter
Maytag MDBH965AWS Dishwasher - Undercounter
Maytag MDBH965AWW Dishwasher - Undercounter
Maytag MDBH970AWB Dishwasher - Undercounter
Maytag MDBH970AWQ Dishwasher - Undercounter
Maytag MDBH970AWS Dishwasher - Undercounter
Maytag MDBH970AWW Dishwasher - Undercounter
Maytag MDBH975AWB Dishwasher - Undercounter
Maytag MDBH975AWS Dishwasher - Undercounter
Maytag MDBH975AWW Dishwasher - Undercounter
Maytag MDBH985AWB10 Undercounter Dishwasher
Maytag MDBH985AWS10 Undercounter Dishwasher
Maytag MDBH985AWW10 Undercounter Dishwasher
Maytag MDBM601AWB Dishwasher - Undercounter
Maytag MDBM601AWQ Dishwasher - Undercounter
Maytag MDBM601AWS Dishwasher - Undercounter
Maytag MDBM601AWW Dishwasher - Undercounter
Maytag MDBM755AWB Dishwasher - Undercounter
Maytag MDBM755AWQ Dishwasher - Undercounter
Maytag MDBM755AWS Dishwasher - Undercounter
Maytag MDBM755AWW Dishwasher - Undercounter
Maytag MDBS561AWB Dishwasher - Undercounter
Maytag MDBS561AWQ Dishwasher - Undercounter
Maytag MDBS561AWS Dishwasher - Undercounter
Maytag MDBS561AWW Dishwasher - Undercounter
Maytag MDBS661AWB Dishwasher - Undercounter
Maytag MDBS661AWQ Dishwasher - Undercounter
Maytag MDBS661AWS Dishwasher - Undercounter
Maytag MDBS661AWW Dishwasher - Undercounter
Maytag MDBTT50AWB Dishwasher - Undercounter
Maytag MDBTT50AWQ Dishwasher - Undercounter
Maytag MDBTT50AWS Dishwasher - Undercounter
Maytag MDBTT50AWW Dishwasher - Undercounter
Maytag MDBTT59AWB Dishwasher - Undercounter
Maytag MDBTT59AWQ Dishwasher - Undercounter
Maytag MDBTT59AWS Dishwasher - Undercounter
Maytag MDBTT59AWW Dishwasher - Undercounter
Maytag MDBTT60AWB Dishwasher - Undercounter
Maytag MDBTT60AWQ Dishwasher - Undercounter
Maytag MDBTT60AWS Dishwasher - Undercounter
Maytag MDBTT60AWW Frigidaire/refrigerator
Maytag MDBTT70AWB Dishwasher - Undercounter
Maytag MDBTT70AWQ Dishwasher - Undercounter
Maytag MDBTT70AWS Dishwasher - Undercounter
Maytag MDBTT70AWW Dishwasher - Undercounter
Maytag MDBTT75AWB Dishwasher - Undercounter
Maytag MDBTT75AWQ Dishwasher - Undercounter
Maytag MDBTT75AWS Dishwasher - Undercounter
Maytag MDBTT75AWW Dishwasher - Undercounter
Maytag MDBTT79AWB Dishwasher - Undercounter
Maytag MDBTT79AWQ Dishwasher - Undercounter
Maytag MDBTT79AWS Dishwasher - Undercounter
Maytag MDBTT79AWW Dishwasher - Undercounter
Maytag MDC4000AWE Dishwasher - Convertible
Maytag MDC4000AWX Dishwasher - Convertible
Maytag MDC4100AWB Dishwasher - Convertible
Maytag MDC4100AWE Dishwasher - Convertible
Maytag MDC4100AWX Dishwasher - Convertible
Maytag MDC4650AWB Dishwasher - Convertible
Maytag MDC4650AWW Dishwasher - Convertible
Maytag MDC5100AWB Dishwasher - Convertible
Maytag MDC5100AWW Dishwasher - Convertible
Magic Chef MDCP1085 Dryer - Ele
Magic Chef MDCP1085- Dryer - Ele
Magic Chef MDCP1085-A Dryer - Ele
Frigidaire MDD25TF1 Frg(v1) / Dehumidifier
Frigidaire MDD25TG1 Gib(v1) / Dehumidifier
Frigidaire MDD25WF1 Frg(v1)
Frigidaire MDD25WG1 Gib(v1) / Dehumidifier
Frigidaire MDD25WW1 Wwh(v1) / Dehumidifier
Frigidaire MDD30FW1 Wwh(v0) / Dehumidifier
Frigidaire MDD30FW2 Wwh(v0) / Dehumidifier
Frigidaire MDD30TF1 Frg(v2) / Dehumidifier
Frigidaire MDD30TG1 Gib(v2) / Dehumidifier
Frigidaire MDD30TG2 Gib(v3) / Dehumidifier
Frigidaire MDD30WF1 Frg(v2)
Frigidaire MDD30WG1 Gib(v2) / Dehumidifier
Frigidaire MDD30WG2 Gib(v0) / Dehumidifier
Frigidaire MDD30WW1 Wwh(v1) / Dehumidifier
Frigidaire MDD40TF1 Frg(v1) / Dehumidifier
Frigidaire MDD40TG1 Gib(v1) / Dehumidifier
Frigidaire MDD40TG3 Gib(v0) / Dehumidifier
Frigidaire MDD40WF1 Frg(v3)
Frigidaire MDD40WF2 Frg(v4)
Frigidaire MDD40WG1 Gib(v3) / Dehumidifier
Frigidaire MDD40WG2 Gib(v4) / Dehumidifier
Frigidaire MDD40WW2 Wwh(v2) / Dehumidifier
Frigidaire MDD40WW4 Wwh(v3) / Dehumidifier
Frigidaire MDD50TF1 Frg(v2) / Dehumidifier
Frigidaire MDD50TF2 Frg(v3) / Dehumidifier
Frigidaire MDD50TG1 Gib(v2) / Dehumidifier
Frigidaire MDD50TG2 Gib(v3) / Dehumidifier
Frigidaire MDD50WF1 Frg(v5)
Frigidaire MDD50WG1 Gib(v5) / Dehumidifier
Frigidaire MDD50WG2 Gib(v0) / Dehumidifier
Frigidaire MDD50WW1 Wwh(v2) / Dehumidifier
Frigidaire MDD50WW2 Wwh(v0) / Dehumidifier
Frigidaire MDDQ40FF1 Frg(v0) / Dehumidifier
Frigidaire MDDQ40FF3 Frg(v0) / Dehumidifier
Frigidaire MDDQ40FG1 Gib(v0) / Dehumidifier
Frigidaire MDDQ40FW1 Wwh(v1) / Dehumidifier
Frigidaire MDDQ40FW3 Wwh(v0) / Dehumidifier
Frigidaire MDDQ50FF1 Frg(v0) / Dehumidifier
Frigidaire MDDQ50FF2 Frg(v0) / Dehumidifier
Frigidaire MDDQ50FF3 Frg(v0) / Dehumidifier
Frigidaire MDDQ50FG1 Gib(v0) / Dehumidifier
Frigidaire MDDQ50FG2 Gib(v0) / Dehumidifier
Frigidaire MDDQ50FG3 Gib(v0) / Dehumidifier
Frigidaire MDDQ50FW1 Wwh(v2) / Dehumidifier
Frigidaire MDDQ50FW2 Wwh(v0) / Dehumidifier
Frigidaire MDDQ50FW6 Wwh(v0) / Dehumidifier
Maytag MDE10CSACL Dryer - Ele
Maytag MDE10CSACW Dryer - Ele
Maytag MDE10CSADL Dryer - Ele
Maytag MDE10CSADW Dryer - Ele
Maytag MDE10CSAGL Dryer - Ele
Maytag MDE10CSAGW Dryer - Ele
Maytag MDE10CSAKL Dryer - Ele
Maytag MDE10DAACL Dryer - Ele
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Profile Dishwasher start button does not light up RuthGreenwald Dishwasher Repair 0 09-04-2011 06:16 AM
Whirlpool Dishwasher Start button won work PLC0174 Dishwasher Repair 1 01-28-2011 01:51 AM
Dishwasher start button will not work bevberni Dishwasher Repair 0 03-30-2010 02:38 PM
frigidaire dishwasher will not start when start button is bushed clacker48 Dishwasher Repair 0 03-09-2010 10:09 PM
Dishwasher Start button Inga Dishwasher Repair 1 10-26-2009 04:15 PM
