Discuss
No power to Bosch dishwasher
 in
Dishwasher Repair
Rats ate through my drain hose to the dishwasher so was flooding kitchen and eventually came up with a fault
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » No power to Bosch dishwasher
  #1 (permalink)
Old 01-24-2013, 06:20 AM
Junior Member
paulhud is on a distinguished road
Default No power to Bosch dishwasher
Model Number: SMS40A08GB   Brand: Bosch   Age: Less than 1 year
Rats ate through my drain hose to the dishwasher so was flooding kitchen and eventually came up with a fault notification. Switched power off, unplugged machine and replaced hose with no problems. Having now re-fixed the side panel, plugged in and switched on, there are no lights or anything. Didn't touch any electrics inside the machine - what could it be?
Have checked fuse in appliance and RCD board - both fine
Ads By Google
Related Models
Bosch SMU2042 UC/09 (FD 7307-7504)
Bosch SMU2042 UC/09 (FD 7505-7902)
Bosch SMU2042 UC/13 (FD 7312-7504)
Bosch SMU2042 UC/13 (FD 7505-7902)
Bosch SMU2042 UC/14 (FD 7402-7504)
Bosch SMU2042 UC/14 (FD 7505-7902)
Bosch SMU2046 UC/09 (FD 7307-7902)
Bosch SMU2046 UC/13 (FD 7312-7902)
Bosch SMU2046 UC/14 (FD 7402-7902)
Bosch SMU3032 UC/14 (FD 7507-7902)
Bosch SMU3036 UC/14 (FD 7507-7902)
Bosch SMU4052 UC/09 (FD 7307-7902)
Bosch SMU4052 UC/14 (FD 7402-7902)
Bosch SMU4052 US/01 (FD 7106-7308)
Bosch SMU4052 US/08 (FD 7203-)
Bosch SMU4052 US/09 (FD 7210-)
Bosch SMU4056 UC/09 (FD 7307-7902)
Bosch SMU4056 UC/14 (FD 7402-7902)
Bosch SMU4056 US/01 (FD 7106-7308)
Bosch SMU4056 US/09 (FD 7211-)
Bosch SMU4092 UC/14 (FD -7902)
Bosch SMU4096 UC/14 (FD -7902)
Bosch SMU7052 UC/09 (FD 7307-7504)
Bosch SMU7052 UC/09 (FD 7505-7506)
Bosch SMU7052 UC/09 (FD 7507-7902)
Bosch SMU7052 UC/14 (FD 7402-7902)
Bosch SMU7052 UC/14 (FD 7507-7902)
Bosch SMU7052 US/02 (FD 7106-7308)
Bosch SMU7052 US/09 (FD 7210-)
Bosch SMU7056 UC/09 (FD 7307-7504)
Bosch SMU7056 UC/09 (FD 7505-7506)
Bosch SMU7056 UC/09 (FD 7507-7902)
Bosch SMU7056 UC/14 (FD 7402-7902)
Bosch SMU7056 UC/14 (FD 7507-7902)
Bosch SMU7056 US/02 (FD 7106-7308)
Bosch SMU7056 US/09 (FD 7210-)
 SMV9165BC MWAVE- MOUNTED OVER RANGE/WO
 SMV9165SC MWAVE- MOUNTED OVER RANGE/WO
Thermador SMW272B BUILT-IN OVEN
Thermador SMW272P BUILT-IN OVEN
Thermador SMW272S BUILT-IN OVEN
Thermador SMW272W BUILT-IN OVEN
Thermador SMW272YB AFTER S/N 8204
Thermador SMW272YS AFTER S/N 8204
Thermador SMW272YW AFTER S/N 8204
Thermador SMW272ZS AFTER S/N 8204
Thermador SMWS72YP AFTER S/N 8204
Bosch SMZ3022
Bosch SMZ3044
Bosch SMZ3055
Bosch SMZ3077
Bosch SMZ3088
Amana SNAC-700.A COMMERCIAL MICROWAVES
Amana SNAC-700.B COMMERCIAL MICROWAVES
Amana SNAC-7TP.A COMMERCIAL MICROWAVES
Amana SNAC-7TP.B COMMERCIAL MICROWAVES
Amana SNAC700 COMMERCIAL MICROWAVES
Amana SNAC700.C COMMERCIAL MICROWAVES
Amana SNAC700.D COMMERCIAL MICROWAVES
Amana SNAC7TP.003 COMMERCIAL MICROWAVES
Amana SNAC7TP.004 COMMERCIAL MICROWAVES
Amana SNAC7TP.005 COMMERCIAL MICROWAVES
Amana SNAC8LW COMMERCIAL MICROWAVES
Amana SNE26AA RANGE - ELECTRIC STD DELAWARE
Amana SNE26CB RANGE- S/C S/I DDRAFT GAS
Amana SNE26CB RANGE - ELECTRIC STD DELAWARE
Amana SNE26ZZ RANGE- S/C S/I DDRAFT GAS
Amana SNK26AA RANGE- S/C S/I DDRAFT GAS
Amana SNK26AA0 RANGE- S/I STD GAS
Amana SNK26AA5 RANGE- S/I STD GAS
Amana SNK26CB RANGE- S/C S/I DDRAFT GAS
Amana SNK26CB0 RANGE- S/I STD GAS
Amana SNK26CB5 RANGE- S/I STD GAS
Amana SNK26FS RANGE- S/C S/I DDRAFT GAS
Amana SNK26FS0 RANGE- S/I STD GAS
Amana SNK26FS5 RANGE- S/I STD GAS
Amana SNP26AA RANGE- S/I STD GAS
Amana SNP26AA0 RANGE- S/I STD GAS
Amana SNP26AA5 RANGE- S/I STD GAS
Amana SNP26AH0 RANGE- S/I STD GAS
Amana SNP26CB RANGE- S/I STD GAS
Amana SNP26CB0 RANGE- S/I STD GAS
Amana SNP26CB5 RANGE- S/I STD GAS
Amana SNP26ZZ RANGE- S/I STD GAS
  #2 (permalink)
Old 01-24-2013, 12:46 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Are you getting the 120VAC to the junction box underneath, check the connection inside the box, check the wires to the door latch.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 01-25-2013, 11:51 AM
Junior Member
Default
Just over 120VAC to the on/off button on the front. I have checked the functionality of the switch and it works on the meter. There is low voltage maybe 8 or 9 volts to the door closed switch/sensor.
Anything else i should check?
Thanks for your help so far.
  #4 (permalink)
Old 01-28-2013, 10:20 AM
Expert
Default
HI.
when the door is open you should read about 120VAC at the door switch. Check the wiring under and inside the door, the rat could damage it.
Unfortunately Bosch allows limited access to the tech literature for you model, the diagram is not available.
Simon.
__________________
  #5 (permalink)
Old 05-30-2013, 01:07 PM
Junior Member
montanagrl is on a distinguished road
Default bosch dishwasher what do the buttons do?
Simon,
I just acquired a 20 year old bosch dishwasher [E-NR: SMU7056US/09] that is fully functional. No manuals are available any longer for it. ALL I NEED TO KNOW is what each button does. There are seven rectangular buttons lined up in a row on the top right side of the door. The far left one is (1) Power On/Off. The six to the right starting at the left *should be* (2) power scrub, (3) Auto, (4) Regular/Normal, (5) ?, (6) ?, (7) ?. Any clue what the last should be? Have you ever seen one of these before? Have an old manual.
A preemptive thanks one way or the other for your reply,
Delphine
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch dishwasher power on and off kavman19 Dishwasher Repair 0 12-15-2011 07:09 AM
Bosch dishwasher with no power SKW1239 Dishwasher Repair 3 11-16-2010 05:57 PM
Bosch Dishwasher no power berrytc Dishwasher Repair 0 11-11-2010 08:27 AM
Bosch Dishwasher No power chen139 Dishwasher Repair 0 01-17-2010 07:49 AM
bosch dishwasher with no power ricks Dishwasher Repair 0 01-15-2009 08:52 AM
