| » Maytag MDB-7 lights flashing |
Model Number: MDB-7 Brand: Maytag Age: Less than 1 year
All the lights are flashing on the control panel sometimes after 15 or 30 sec the dishwasher will start back up lights stop flashing and maybe run for 10 sec or a few minutes than stop and the lights flash. I thought it was a handle issue because it somewhat broke awhile back. I took the handle out and made sure the micro switches worked checked continuity and pulled the switches out of the handle and plugged the dishwasher back in and the lights just flash. It looks like the lights are flashing a code possibly.
Ads By Google Related Models Last edited by smith10210 : 01-24-2013 at 02:28 PM. |
Your model number is incomplete.
Need the correct model number in order to try and find a tech sheet for this unit online. Find your model number - AppliancePartsPros.com You may be able to find it taped under the unit or to the back of it's kick plate.
__________________
Yews it does sound like the control board is sshot.
I am assuming that when you checked the latch switches that you removed power from the unit so that the board has done a manual reset,
__________________
I believe so . When you say circuit board are you referring to the circuit board inside on the backside of the door or the control panel on the front door which i had suggested.
Yes I mean the control board (item 7 in section 02).
It may be the control panel. To narrow it down you have to check the keyboard/control panel keys/output with a meter, see the tech sheet for the pinouts. If it checks out OK then the control board goes to the top of the list. Still a bit of a gamble but your odds are better. You may want to try the below. Connector Cleaning / Checking Unplug the unit Open it up Remove the ribbon cable from the keypad to the control board at the control board. Clean the edge connector. Use electronics contact cleaner or isopropyl alcohol. If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive. Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here. Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates. Reconnect everything and give it a try.
__________________
| Display Modes | |
| Maytag dishwasher run part cycle, then jumps to flashing clean and heated dry lights | snowbunny517 | Dishwasher Repair | 0 | 02-13-2012 10:22 AM |
| All lights flashing on Maytag Jetclean | secretkpr9 | Dishwasher Repair | 1 | 07-05-2011 07:58 PM |
| maytag refrig. flashing lights. | audley | Refrigerator & Freezer Repair | 1 | 09-20-2010 09:01 AM |
| Panel lights flashing on Maytag Dishwasher | rhansen | Dishwasher Repair | 0 | 05-26-2010 07:31 AM |
| Maytag Dishwasher lights flashing | TMo235 | Dishwasher Repair | 0 | 12-17-2009 10:49 PM |
