Discuss
drainage problem-error code oe
 in
Dishwasher Repair
i have a LG dishwasherwith errorcode OE which is drain line clogged dis-connected hoses and drain line still having problems
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » drainage problem-error code oe
  #1 (permalink)
Old 01-23-2013, 02:15 PM
Junior Member
wgeorgette64 is on a distinguished road
Default drainage problem-error code oe
Model Number: ldf6920st   Brand: -other-   Age: 1 - 5 years
Ads By Google
Related Models
International LDG1000AAE Dryer - Gas
Maytag LDG105 Dryer - Gas
Maytag LDG107 Dryer - Gas
Maytag LDG110 Dryer - Gas
Maytag LDG18CA Dryer - Gas
Maytag LDG18CM Dryer - Gas
Maytag LDG18CS Dryer - Gas
Maytag LDG18CT Dryer - Gas
Maytag LDG19CD Dryer - Gas
Maytag LDG19CS Dryer - Gas
Maytag LDG19CT Dryer - Gas
Maytag LDG210 Dryer - Gas
Maytag LDG212 Dryer - Gas
Maytag LDG21CS Dryer - Gas
Maytag LDG22CS Dryer - Gas
Maytag LDG22CT Dryer - Gas
Maytag LDG23CD Dryer - Gas
Maytag LDG24CA Dryer - Gas
Maytag LDG24CM Dryer - Gas
Maytag LDG24CS Dryer - Gas
Maytag LDG24CT Dryer - Gas
Maytag LDG25CS Dryer - Gas
Maytag LDG26CA Dryer - Gas
Maytag LDG26CD Dryer - Gas
Maytag LDG26CS Dryer - Gas
Maytag LDG26CT Dryer - Gas
Maytag LDG27CA Dryer - Gas
Maytag LDG27CD Dryer - Gas
Maytag LDG27CS Dryer - Gas
Maytag LDG27CT Dryer - Gas
Maytag LDG303 Dryer - Gas
Maytag LDG303D Dryer - Gas
Maytag LDG306 Dryer - Gas
Maytag LDG308 Dryer - Gas
Maytag LDG309 Dryer - Gas
Maytag LDG30CMD Dryer - Gas
Maytag LDG312 Dryer - Gas
Maytag LDG312D Dryer - Gas
Maytag LDG313 Dryer - Gas
Maytag LDG313D Dryer - Gas
Maytag LDG31CA Dryer - Gas
Maytag LDG31CM Dryer - Gas
Maytag LDG31CT Dryer - Gas
Maytag LDG32CA Dryer - Gas
Maytag LDG32CM Dryer - Gas
Maytag LDG32CT Dryer - Gas
Frigidaire LDG333PEW0 Frg(v0) / Gas Dryer
Maytag LDG33CA Dryer - Gas
Maytag LDG33CM Dryer - Gas
Maytag LDG34CD Dryer - Gas
Maytag LDG34CQ Dryer - Gas
Maytag LDG382 Dryer - Gas
Maytag LDG4000 Dryer - Gas
Maytag LDG4000AAL Dryer - Gas
Maytag LDG4000AAW Dryer - Gas
Maytag LDG4000ABL Dryer - Gas
Maytag LDG4000ABW Dryer - Gas
Maytag LDG407 Dryer - Gas
Maytag LDG408 Dryer - Gas
Maytag LDG409 Dryer - Gas
Maytag LDG410 Dryer - Gas
Maytag LDG412 Dryer - Gas
Maytag LDG412D Dryer - Gas
Maytag LDG482 Dryer - Gas
Maytag LDG482D Dryer - Gas
Maytag LDG490 Dryer - Gas
Maytag LDG490D Dryer - Gas
Maytag LDG4910 Dryer - Gas
Maytag LDG4910AAL Dryer - Gas
Maytag LDG4910AAW Dryer - Gas
Maytag LDG4914AAE Dryer - Gas
Maytag LDG4914AAL Dryer - Gas
Maytag LDG4914AAM Dryer - Gas
Maytag LDG4916AAE Dryer - Gas
Maytag LDG4916AAM Dryer - Gas
Maytag LDG5004AAW Dryer - Gas
Maytag LDG5004ABW Dryer - Gas
Maytag LDG5005AAE Dryer - Gas
Maytag LDG5005ABE Dryer - Gas
Maytag LDG510 Dryer - Gas
Maytag LDG512 Dryer - Gas
Maytag LDG512D Dryer - Gas
Maytag LDG590 Dryer - Gas
Maytag LDG590D Dryer - Gas
Maytag LDG5910 Dryer - Gas
Maytag LDG5910AAL Dryer - Gas
Maytag LDG5910AAW Dryer - Gas
Maytag LDG5914AAE Dryer - Gas
Maytag LDG5914AAL Dryer - Gas
Maytag LDG5914AAM Dryer - Gas
Maytag LDG5916AAE Dryer - Gas
Maytag LDG5916AAM Dryer - Gas
Maytag LDG6004AAW Dryer - Gas
Maytag LDG606 Dryer - Gas
Maytag LDG608 Dryer - Gas
Maytag LDG610 Dryer - Gas
Maytag LDG612 Dryer - Gas
Maytag LDG612D Dryer - Gas
Maytag LDG6914AAE Dryer - Gas
Maytag LDG6914AAL Dryer - Gas
Maytag LDG6914AAM Dryer - Gas
Maytag LDG710 Dryer - Gas
Maytag LDG712 Dryer - Gas
Maytag LDG713 Dryer - Gas
Maytag LDG7304AAE Dryer - Gas
Maytag LDG7304AAL Dryer - Gas
Maytag LDG7304AAM Dryer - Gas
Maytag LDG7304ABE Dryer - Gas
Maytag LDG7304ABL Dryer - Gas
Maytag LDG7304ABM Dryer - Gas
Maytag LDG7304AGE Dryer - Gas
Maytag LDG7304AGL Dryer - Gas
Maytag LDG7304AGM Dryer - Gas
Maytag LDG7304EGE Dryer - Gas
Maytag LDG7304EGL Dryer - Gas
Maytag LDG7304EGM Dryer - Gas
Maytag LDG7314AAE Dryer - Gas
Maytag LDG7314AAL Dryer - Gas
Maytag LDG7314AAM Dryer - Gas
Maytag LDG7334AAE Dryer - Gas
  #2 (permalink)
Old 01-24-2013, 11:15 AM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
You need to check if the drain pump is running. If it is and there is no drain - replace the pump.
If it's not running - check for 120VAc across the pump contacts and if the proper voltage present - replace the pump.
No voltage- check the wiring to the control board and voltage output from the board.
No voltage - replace the control board.
Here are the breakdown diagrams and parts for LG LDF6920ST - AppliancePartsPros.com
Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore HE2 plus drainage problem carlen Washer Repair 0 05-11-2012 04:02 AM
Drainage problem gjdl Refrigerator & Freezer Repair 0 12-30-2009 03:22 PM
drainage problem bfadler Refrigerator & Freezer Repair 0 11-01-2009 10:53 AM
Door won't latch after drainage problem RonJ Washer Repair 1 09-02-2009 05:55 PM
Drainage Problem sfreem33 Dishwasher Repair 0 08-25-2007 12:44 PM
