Discuss
Normal Light flashing
 in
Dishwasher Repair
The "Normal" light is flashing. As a result the unit will not run thru a normal cycle - it may
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Normal Light flashing
  #1 (permalink)
Old 01-22-2013, 01:05 PM
Junior Member
donlamb is on a distinguished road
Default Normal Light flashing
Model Number: DU1145   Brand: Whirlpool   Age: 5 - 10 years
The "Normal" light is flashing. As a result the unit will not run thru a normal cycle - it may run for a while but when the lights starts flashing it stops. I have run thru the "Heated Dry-Normal-Heated Dry-Normal" reset process with varying control panel responses - sometimes, upon completion, the "Cancel/Drain" light will come on and unit runs for a short time (presumably draining any water left in the bottom; other times, upon completion, the unit will light up like a christmas tree with all the lights coming on for a short time and then all turning off for a few minutes and then "Normal" light will commence to blink again; other times other lights may come on and then go off only to have Normal light flashing again after short delay - in all cases, however, I can normally go thru the process whereupon the Normal light is off for a while. I have also tried "Normal-Pots/Pans-Normal-Pots/Pans" with same results (eventually Normal will flash again). I have also tried running thru the cycle and then opening and closing the door at the end - same results. I'm stymied - I initially thought, after all the lights came on that the reset process must have worked but eventually light started flashing again. One other avenue I have questioned is a defective/stuck door latch. In looking at the assembly from the outside (I don't know how to open up the latch area) and it seems that the latch may not be fully engaged when the door is closed - it seems to feel closed but I'm not sure about the latch mechanism.
I read that there is a tech guide that spells out diagnostic checks under the front panel of the unit but I can't see how to access it.
I'm at a point now wondering 1) the control panel is defective, 2) could it be the latch, and 3), if any of these, how do I open up the back and get to the panel - in that the control panel area doesn't have its own access, the only way I can see is to remove all the screws on the back of the door.
One more thing, I also read that the "ribbon cable"ay need cleaning. If so, is this something that I should be able to do (not being a technician) w/o too much trouble?
Related Models
Whirlpool DU1145XTPB0 UNDERCOUNTER DISHWASHER
Whirlpool DU1145XTPB1 UNDERCOUNTER DISHWASHER
Whirlpool DU1145XTPB3 UNDERCOUNTER DISHWASHER
Whirlpool DU1145XTPB6 UNDERCOUNTER DISHWASHER
Whirlpool DU1145XTPB7 UNDERCOUNTER DISHWASHER
Whirlpool DU1145XTPB8 UNDERCOUNTER DISHWASHER
Whirlpool DU1145XTPB9 UNDERCOUNTER DISHWASHER
Whirlpool DU1145XTPBA UNDERCOUNTER DISHWASHER
Whirlpool DU1145XTPQ0 UNDERCOUNTER DISHWASHER
Whirlpool DU1145XTPQ1 UNDERCOUNTER DISHWASHER
Whirlpool DU1145XTPQ3 UNDERCOUNTER DISHWASHER
Whirlpool DU1145XTPQ6 UNDERCOUNTER DISHWASHER
Whirlpool DU1145XTPQ7 UNDERCOUNTER DISHWASHER
Whirlpool DU1145XTPQ8 UNDERCOUNTER DISHWASHER
Whirlpool DU1145XTPQ9 UNDERCOUNTER DISHWASHER
Whirlpool DU1145XTPQA UNDERCOUNTER DISHWASHER
Whirlpool DU1145XTPS0 UNDERCOUNTER DISHWASHER
Whirlpool DU1145XTPS1 UNDERCOUNTER DISHWASHER
Whirlpool DU1145XTPS3 UNDERCOUNTER DISHWASHER
Whirlpool DU1145XTPS6 UNDERCOUNTER DISHWASHER
Whirlpool DU1145XTPS7 UNDERCOUNTER DISHWASHER
Whirlpool DU1145XTPS8 UNDERCOUNTER DISHWASHER
Whirlpool DU1145XTPS9 UNDERCOUNTER DISHWASHER
Whirlpool DU1145XTPSA UNDERCOUNTER DISHWASHER
Whirlpool DU1148XTPB0 UNDERCOUNTER DISHWASHER
Whirlpool DU1148XTPB1 UNDERCOUNTER DISHWASHER
Whirlpool DU1148XTPB3 UNDERCOUNTER DISHWASHER
Whirlpool DU1148XTPB6 UNDERCOUNTER DISHWASHER
Whirlpool DU1148XTPB7 UNDERCOUNTER DISHWASHER
Whirlpool DU1148XTPB8 UNDERCOUNTER DISHWASHER
Whirlpool DU1148XTPB9 UNDERCOUNTER DISHWASHER
Whirlpool DU1148XTPBA UNDERCOUNTER DISHWASHER
Whirlpool DU1148XTPBB UNDERCOUNTER DISHWASHER
Whirlpool DU1148XTPQ0 UNDERCOUNTER DISHWASHER
Whirlpool DU1148XTPQ1 UNDERCOUNTER DISHWASHER
Whirlpool DU1148XTPQ3 UNDERCOUNTER DISHWASHER
Whirlpool DU1148XTPQ6 UNDERCOUNTER DISHWASHER
Whirlpool DU1148XTPQ7 UNDERCOUNTER DISHWASHER
Whirlpool DU1148XTPQ8 UNDERCOUNTER DISHWASHER
Whirlpool DU1148XTPQ9 UNDERCOUNTER DISHWASHER
Whirlpool DU1148XTPQA UNDERCOUNTER DISHWASHER
Whirlpool DU1148XTPQB UNDERCOUNTER DISHWASHER
Whirlpool DU1200XTSB0 UNDERCOUNTER DISHWASHER
Whirlpool DU1200XTSB1 UNDERCOUNTER DISHWASHER
Whirlpool DU1200XTSQ0 UNDERCOUNTER DISHWASHER
Whirlpool DU1200XTSQ1 UNDERCOUNTER DISHWASHER
Whirlpool DU1200XTSS0 UNDERCOUNTER DISHWASHER
Whirlpool DU1200XTSS1 UNDERCOUNTER DISHWASHER
Whirlpool DU1200XTST0 UNDERCOUNTER DISHWASHER
Whirlpool DU1200XTST1 UNDERCOUNTER DISHWASHER
Whirlpool DU1201XTSB0 UNDERCOUNTER DISHWASHER
Whirlpool DU1201XTSB1 UNDERCOUNTER DISHWASHER
Whirlpool DU1201XTSQ0 UNDERCOUNTER DISHWASHER
Whirlpool DU1201XTSQ1 UNDERCOUNTER DISHWASHER
Magic Chef DU120CA-01 DISHWASHER- UNDERCOUNTER
Magic Chef DU120CA-02 DISHWASHER- UNDERCOUNTER
Magic Chef DU120CA-20 DISHWASHER- UNDERCOUNTER
Magic Chef DU120DA-25 DISHWASHER- UNDERCOUNTER
Magic Chef DU120DA-35 DISHWASHER- UNDERCOUNTER
Magic Chef DU120DA-45 DISHWASHER- UNDERCOUNTER
Magic Chef DU120DA-48 DISHWASHER- UNDERCOUNTER
Whirlpool DU1245XTSB0 UNDERCOUNTER DISHWASHER
Whirlpool DU1245XTSB1 UNDERCOUNTER DISHWASHER
Whirlpool DU1245XTSQ0 UNDERCOUNTER DISHWASHER
Whirlpool DU1245XTSQ1 UNDERCOUNTER DISHWASHER
Whirlpool DU1248XTSB0 UNDERCOUNTER DISHWASHER
Whirlpool DU1248XTSB1 UNDERCOUNTER DISHWASHER
Whirlpool DU1248XTSS0 UNDERCOUNTER DISHWASHER
Whirlpool DU1248XTSS1 UNDERCOUNTER DISHWASHER
Whirlpool DU1300XTVB0 UNDERCOUNTER DISHWASHER
Whirlpool DU1300XTVB1 UNDERCOUNTER DISHWASHER
Whirlpool DU1300XTVB2 UNDERCOUNTER DISHWASHER
Whirlpool DU1300XTVB3 UNDERCOUNTER DISHWASHER
Whirlpool DU1300XTVB5 UNDERCOUNTER DISHWASHER
Whirlpool DU1300XTVB6 UNDERCOUNTER DISHWASHER
Whirlpool DU1300XTVB7 UNDERCOUNTER DISHWASHER
Whirlpool DU1300XTVB8 UNDERCOUNTER DISHWASHER
Whirlpool DU1300XTVQ0 UNDERCOUNTER DISHWASHER
Whirlpool DU1300XTVQ1 UNDERCOUNTER DISHWASHER
Whirlpool DU1300XTVQ2 UNDERCOUNTER DISHWASHER
Whirlpool DU1300XTVQ3 UNDERCOUNTER DISHWASHER
Whirlpool DU1300XTVQ5 UNDERCOUNTER DISHWASHER
Whirlpool DU1300XTVQ6 UNDERCOUNTER DISHWASHER
Whirlpool DU1300XTVQ7 UNDERCOUNTER DISHWASHER
Whirlpool DU1300XTVQ8 UNDERCOUNTER DISHWASHER
Whirlpool DU1300XTVS0 UNDERCOUNTER DISHWASHER
Whirlpool DU1300XTVS1 UNDERCOUNTER DISHWASHER
Whirlpool DU1300XTVS2 UNDERCOUNTER DISHWASHER
Whirlpool DU1300XTVS3 UNDERCOUNTER DISHWASHER
Whirlpool DU1300XTVS5 UNDERCOUNTER DISHWASHER
Whirlpool DU1300XTVS6 UNDERCOUNTER DISHWASHER
Whirlpool DU1300XTVS7 UNDERCOUNTER DISHWASHER
Whirlpool DU1300XTVS8 UNDERCOUNTER DISHWASHER
Whirlpool DU1300XTVT0 UNDERCOUNTER DISHWASHER
Whirlpool DU1300XTVT1 UNDERCOUNTER DISHWASHER
Whirlpool DU1300XTVT2 UNDERCOUNTER DISHWASHER
Whirlpool DU1300XTVT3 UNDERCOUNTER DISHWASHER
Whirlpool DU1300XTVT5 UNDERCOUNTER DISHWASHER
Whirlpool DU1300XTVT6 UNDERCOUNTER DISHWASHER
Whirlpool DU1300XTVT7 UNDERCOUNTER DISHWASHER
Whirlpool DU1300XTVT8 UNDERCOUNTER DISHWASHER
Whirlpool DU1301XTVB0 UNDERCOUNTER DISHWASHER
Whirlpool DU1301XTVB1 UNDERCOUNTER DISHWASHER
Whirlpool DU1301XTVB2 UNDERCOUNTER DISHWASHER
Whirlpool DU1301XTVB4 UNDERCOUNTER DISHWASHER
Whirlpool DU1301XTVB5 UNDERCOUNTER DISHWASHER
Whirlpool DU1301XTVQ0 UNDERCOUNTER DISHWASHER
Whirlpool DU1301XTVQ1 UNDERCOUNTER DISHWASHER
Whirlpool DU1301XTVQ2 UNDERCOUNTER DISHWASHER
Whirlpool DU1301XTVQ4 UNDERCOUNTER DISHWASHER
Whirlpool DU1301XTVQ5 UNDERCOUNTER DISHWASHER
Whirlpool DU1301XTVS1 UNDERCOUNTER DISHWASHER
Whirlpool DU1301XTVS2 UNDERCOUNTER DISHWASHER
Whirlpool DU1301XTVS4 UNDERCOUNTER DISHWASHER
Whirlpool DU1301XTVS5 UNDERCOUNTER DISHWASHER
Whirlpool DU1301XTVT1 UNDERCOUNTER DISHWASHER
Whirlpool DU1301XTVT2 UNDERCOUNTER DISHWASHER
Whirlpool DU1301XTVT4 UNDERCOUNTER DISHWASHER
Whirlpool DU1301XTVT5 UNDERCOUNTER DISHWASHER
Whirlpool DU1345XTVB0 UNDERCOUNTER DISHWASHER
  #2 (permalink)
Old 01-22-2013, 04:07 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Most likely it's a bad control panel. Please provide the complete model number of the unit.
The tech sheet could be found behind the toe panel.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 01-22-2013, 04:54 PM
Junior Member
Default
Complete model number DU1145XTPQ7 (lsuffix designates that it's the white unit)
  #4 (permalink)
Old 01-22-2013, 05:54 PM
Expert
Default
Hi.
If your dishwasher is white than this is the control panel
Part number: 3385735
For the black one use this Part number: W10142945
To replace it remove the screws from the inner door.
Here are the breakdown diagrams and Door and Latch parts for Whirlpool DU1145XTPQ7 - AppliancePartsPros.com
Post the results.
Simon.
__________________
  #5 (permalink)
Old 01-23-2013, 10:20 AM
Junior Member
Default
Is replacing the control panel a challenging/difficult procedure?
  #6 (permalink)
Old 01-23-2013, 11:13 AM
Expert
Default
Not at all.
Don't forget to unplug the dishwasher.If I'm not mistaken you'll need the torx screwdriver.
Simon.
__________________
  #7 (permalink)
Old 01-23-2013, 01:52 PM
Junior Member
Default
I assume that it would be OK to trip the circuit breaker as an alternative to unplugging the unit, right. What is the connection between the control panel and dishwasher itself?
  #8 (permalink)
Old 01-23-2013, 02:01 PM
Expert
Default
Hi.
Yes, turn the breaker off.
the connection is a flex ribbon, unplugs from the control board.
When you open the panel it will be very clear.
Simon.
__________________
  #9 (permalink)
Old 02-01-2013, 11:36 AM
Junior Member
Default
Simon - Curious as to your rationale for pin-pointing the flashing "Normal" problem as most likely being in the control panel not the control circuit board. Is there any simple check I could do to verify this?
Don
  #10 (permalink)
Old 02-01-2013, 05:51 PM
Expert
Default
Hello.
Open the kick panel and locate the tech sheet. Use it for testing the control panel.
My rationale is based on the experience. The good thing is if you get parts from APP you may return them for full refund, no questions asked.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool gold quiet partner 3 AccuSense or normal light light flashing ljtuchman Dishwasher Repair 0 11-03-2011 08:36 AM
Flashing Normal Light philjewett Dishwasher Repair 0 12-15-2010 08:11 PM
Flashing Normal light - geischen Dishwasher Repair 1 08-07-2010 01:40 PM
normal light keeps flashing patricia eves Dishwasher Repair 0 06-06-2010 02:53 PM
Flashing Normal Wash Light Koriganp Dishwasher Repair 5 08-19-2009 05:15 PM
