Discuss
Bosch soap dispenser problem
 in
Dishwasher Repair
My Bosch SHX 68P 0 5UC/53 dishwasher is not cleaning the dishes. At the end of the cycle, the dry
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch soap dispenser problem
  #1 (permalink)
Old 01-21-2013, 07:36 AM
Junior Member
mtds is on a distinguished road
Default Bosch soap dispenser problem
Model Number: SHX 68P 0 5UC/53   Brand: Bosch   Age: 1 - 5 years
At the end of the cycle, the dry soap/rinse tablet is laying in the bottom of the dishwasher. I interrupted a cycle and there was water in the base and dripping from the racks. I checked the base filter and both spray arms and they look clear.
Two questions:
1. Short term, can I manually insert the tablet at some point in the cycle to clean the existing load?
2. How can I identify the source of the problem?
I have fixed a previous dishwasher and a washing machine with your help. I am a retired electromechanical tech.
Ads By Google
Related Models
Bosch SHX33A02 UC/14 (FD 8211-)
Bosch SHX33A05 UC/14 (FD 8211-)
Bosch SHX33A06 UC/14 (FD 8211-)
Bosch SHX43E02 UC/14 (FD 8211-)
Bosch SHX43E05 UC/14 (FD 8211-)
Bosch SHX43E06 UC/14 (FD 8211-)
Bosch SHX46A02 UC/14 (FD 8211-)
Bosch SHX46A05 UC/14 (FD 8211-)
Bosch SHX46A06 UC/14 (FD 8211-)
Bosch SHX46A07 UC/14 (FD 8211-)
Bosch SHX46B02 UC/14 (FD 8211-)
Bosch SHX46B05 UC/14 (FD 8211-)
Bosch SHX46B06 UC/14 (FD 8211-)
Bosch SHX46B07 UC/14 (FD 8211-)
Bosch SHX56B02 UC/14 (FD 8211-)
Bosch SHX56B05 UC/14 (FD 8211-)
Bosch SHX56B06 UC/14 (FD 8211-)
Bosch SHX99B05 UC/14 (FD 8212-)
Bosch SHX99B06 UC/14 (FD 8212-)
Bosch SHY56A02 UC/14 (FD8301-)
Bosch SHY56A05 UC/14 (FD8301-)
Bosch SHY56A06 UC/14 (FD8301-)
Bosch SHY66C02 UC/14 (FD8301-)
Bosch SHY66C05 UC/14 (FD8301-)
Bosch SHY66C06 UC/14 (FD8301-)
Bosch SHY99A02 UC/14 (FD 8212-)
Bosch SHY99A05 UC/14 (FD 8212-)
Bosch SHY99A06 UC/14 (FD 8212-)
Amana SI19E Ref - SXS/I&W
General Electric SIG7010ET1WG Electric dryer
International SILVER22 Ref - SXS/I&W
International SILVER24 Ref - SXS/I&W
Maytag SK525-2W  Ref - Sxs
Maytag SK535-2  Ref - SXS/I&W
Gaggenau SK590-2  Ref - Bottom Mounts
Hardwick SKG4622MGA639R Range - F/s Cont Clean Gas
Hardwick SKG4622MGW639R Range - F/s Cont Clean Gas
Hardwick SKG9611A540R Range - F/s Cont Clean Gas
Hardwick SKG9611W540R Range - F/s Cont Clean Gas
Amana SKI22F Ref - SXS/I&W
Amana SKI22F-A Ref - SXS/I&W
Amana SKI22F-C Ref - SXS/I&W
Amana SKI22F-G Ref - SXS/I&W
Amana SKI22FL Ref - SXS/I&W
Hardwick SKJ7141819DE Walloven - Cont Clean Gas
Maytag SL10AA Stacked Laundry - Ele
Maytag SL10AA-A01 Stacked Laundry - Ele
Maytag SL10AN Stacked Laundry - Ele
Maytag SL10AN-A00 Stacked Laundry - Ele
Maytag SL10AN-A01 Stacked Laundry - Ele
Maytag SL10AN-A02 Stacked Laundry - Ele
Maytag SL10AN-A03 Stacked Laundry - Ele
Maytag SL11AA Stacked Laundry - Ele
Maytag SL11AN Stacked Laundry - Ele
General Electric SL208 Room air conditioner
General Electric SL210 Room air conditioner
General Electric SL212 Room air conditioner
General Electric SL214 Room air conditioner
General Electric SL217 Room air conditioner
General Electric SL220 Room air conditioner
General Electric SL223 Room air conditioner
Amana SL22F Ref - SXS/I&W
Amana SL22F-A Ref - SXS/I&W
Amana SL22F-C Ref - SXS/I&W
Amana SL22F-G Ref - SXS/I&W
Amana SL22F-L Ref - SXS/I&W
Amana SL22G Ref - SXS/I&W
Amana SL22GL Ref - SXS/I&W
Amana SL22JB Ref - SXS/I&W
Amana SL22MBG Ref - SXS/I&W
Amana SL22MBL Ref - SXS/I&W
Amana SL22MBW Ref - SXS/I&W
Amana SL25G Ref - SXS/I&W
Amana SL25GL Ref - SXS/I&W
Amana SL25H Ref - SXS/I&W
Amana SL25J Ref - SXS/I&W
Amana SL25M2L Ref - SXS/I&W
Amana SL25M2W Ref - SXS/I&W
Amana SL25MG Ref - SXS/I&W
Amana SL25ML Ref - SXS/I&W
Amana SL25MW Ref - SXS/I&W
Amana SLD22JB Ref - SXS/I&W
Amana SLD22MB2L Ref - SXS/I&W
Amana SLD22MB2W Ref - SXS/I&W
Amana SLD22MBG Ref - SXS/I&W
Amana SLD22MBL Ref - SXS/I&W
Amana SLD22MBW Ref - SXS/I&W
Amana SLD25J Ref - SXS/I&W
Amana SLD25JB Ref - SXS/I&W
  #2 (permalink)
Old 01-21-2013, 06:43 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hello,
Open the door during the wash cycle to see how the spray arms are rotating and how much water is inside the dishwasher. Post the results.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 01-22-2013, 09:09 AM
Junior Member
Default
Quote:
Originally Posted by Gene View Post
Hello,
Thank you, Gene, for replying to my post.
I ran the machine and opened the door a few times. Each time the spray arms had moved from the position I set them in before closing the door, but were not moving when I opened the door. (I would have guessed they would still be coasting to a stop after opening the door, but they were not moving.)
Water filled the bottom of the machine.
John
  #4 (permalink)
Old 01-22-2013, 10:51 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi John,
Try to add 1/2 of gallon of water and check the spray arms again.
__________________
  #5 (permalink)
Old 01-23-2013, 07:49 AM
Junior Member
Default
Hi John,
Hi Gene,
Thank you for the suggestion, but I think adding more water will make it overflow. When I interrupt a cycle the sump is full, as well as the shallower area around it. Also, the racks and "ceiling" of the washer are dripping, and the spray arms spin freely with a light touch.
On one of my test runs yesterday I put a soap/rinse tablet in the dispenser and at the end of the cycles it was completely gone. That was different from recent uses, when the dishes were warm and wet but not clean, and the tablet was lying in the bottom of the machine, still dry. Maybe the problem has something to do with the timing of the release of the tablet?
I'm thinking that today I might take off the dress panel and look at the wax motor and linkage to the dispenser. Maybe I'll find a bad connection, mechanical or electrical. I could also do a resistance check on the wax motor (2150 ohms, right?). Does that make any sense to you?
Thanks again for trying to help me with this.
John
  #6 (permalink)
Old 01-23-2013, 10:04 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi John,
If the tablet was laying on the bottom that means the dispenser did open.
You said
Quote:
...Water filled the bottom of the machine...
How deep?
__________________
  #7 (permalink)
Old 01-24-2013, 11:59 AM
Junior Member
Default
Hi John,
How deep?
Hi Gene,
Measured during the wash cycle, right next to the "Large Object Trap/Filter Assembly", the water was one and one-quarter inches deep.
John
  #8 (permalink)
Old 01-24-2013, 03:38 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi John,
It sounds like there is not enough pressure in the wash system. It can be caused by insufficient amount of water or a bad circulation pump performance.
I don't think you will overflow the dishwasher by adding some more water. Add 2-3 cups and post the results.
__________________
  #9 (permalink)
Old 05-02-2013, 07:05 PM
MrD MrD is offline
Junior Member
MrD is on a distinguished road
Default One Solution
I had a similar problem where the soap packets would turn into a gooey mess and remain stuck in the dispenser.
After much research, I stumbled across a description of the function of the wax motor. Based on the description, I came to the conclusion that the motor/actuator system that operates the soap dispenser, ALSO activates the rinse. OR - another way of saying it would be that the FIRST time the motor is activated, it dispenses soap. The SECOND time the motor is activated, it dispenses rinse.
What would happen if you were to interrupt the dishwasher AFTER the soap was dispensed and BEFORE the rinse.
I ran an empty cycle for about 20 - 30 minutes ... interrupted the cycle ... then ran it again.
Yeah ... the problem was fixed and it has been working flawlessly for about a month now.
BEFORE you spend a bunch of money on parts and the labor to replace the unit, try this "free" approach. I hope it works for you like it did for me.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
bosch soap dispenser replacement AReed Dishwasher Repair 19 02-14-2012 11:05 AM
Bosch soap dispenser repair scurry.com@mail.com Dishwasher Repair 0 01-05-2011 07:14 PM
Bosch Dishwasher Soap Dispenser stevefrank Dishwasher Repair 1 10-05-2010 01:39 PM
Bosch diswasher soap dispenser robeem Dishwasher Repair 3 07-07-2009 05:41 PM
Bosch Soap Dispenser hriddle Dishwasher Repair 1 11-03-2008 05:44 PM
