Appliance Repair Forum
-   Dishwasher Repair (http://forum.appliancepartspros.com/dishwasher-repair/)
-   -   Bosch draining constantly, not flood switch (http://forum.appliancepartspros.com/dishwasher-repair/515767-bosch-draining-constantly-not-flood-switch.html)
cevictor 01-19-2013 08:44 AM
Hi, my Bosch DW is running the drain pump continuously with the door open or closed. I did some research and checked the flood pan (it's dry) and floats are clean and slide fine.
I manually pushed the pump switch on and off and still pump is running regardless.
I also disconnected the pump switch just to see what would happen and the pump still ran.
Bosch Model # SHX46A05UC / 38
I'd like to check the error codes but can't find a guide or manual for how to do this with my model. Any help or ideas?
space.shot.powah 04-11-2013 09:30 PM
Did you resolve the issue ? I have a shx46a05uc/46 which is doing the same thing, running dry with door open or closed. I found the control code guide and am having a hard time interpreting the error code. It seems to read heater error.
How did you resolve your issue ? Thanks
