| » Maytag Neptune Error code E3 |
Model Number: MAH8700aww Brand: Maytag Age: 5 - 10 years
After reading similar posts on this error,I purchased the control board from this site and just replaced it today. The symptom is the same. I am reluctant to purchase the motor since it was also mentioned as a possible cause.
Any help would be appreciated. Thank you. Ads By Google Related Models |
The error code "E3" is showing because here have been problems with the motor wire harness connector on these washers. Either a loose or bent terminal in the molex connector.
Another thing can be happen the terminals may be bent. check these things. |
| Display Modes | |
| Maytag neptune error code | brockner75 | Washer Repair | 2 | 02-12-2012 04:20 PM |
| Neptune will not spin but no error code | bigmontana | Washer Repair | 1 | 10-14-2011 05:16 AM |
| Maytag Neptune Gas Dryer Error Code E5 | tthomas1020 | Dryer Repair | 0 | 03-07-2010 09:14 AM |
| MAYTAG NEPTUNE error code: "E5 or L5" ? | skalesplitur | Dryer Repair | 1 | 03-07-2010 09:08 AM |
| Maytag Neptune error code: L5 or E5 | skalesplitur | Washer Repair | 1 | 03-05-2010 06:46 AM |
