Discuss
frigidaire
 in
Dishwasher Repair
Okay I'm new to the site as well as appliance repair my question is about the machine not washing? It
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » frigidaire
  #1 (permalink)
Old 01-16-2013, 03:35 PM
Junior Member
racer35j is on a distinguished road
Default frigidaire
Model Number: fdb520rhb0   Brand: Frigidaire   Age: 1 - 5 years
Okay I'm new to the site as well as appliance repair my question is about the machine not washing? It will do the initial fill but won't wash, I took the motor out and tested it it works I was told the pump may be bad where is that and how would I check that?
Ads By Google
Related Models
Whirlpool FGP335EQ0
Whirlpool FGP335EW0
Whirlpool FGP335GN0
Whirlpool FGP335GN1
Whirlpool FGP335GQ0
Whirlpool FGP335GQ1
Whirlpool FGP335GW0
Whirlpool FGP335GW1
Whirlpool FGP335HN0
Whirlpool FGP335HQ0
Whirlpool FGP335HW0
Whirlpool FGP335VL0
Whirlpool FGP335VL1
Whirlpool FGP335VL2
Whirlpool FGP335VL3
Whirlpool FGP335VW0
Whirlpool FGP335VW1
Whirlpool FGP335VW2
Whirlpool FGP335VW3
Whirlpool FGP335YL0
Whirlpool FGP335YL1
Whirlpool FGP335YL2
Whirlpool FGP335YW0
Whirlpool FGP335YW1
Whirlpool FGP335YW2
Whirlpool FGP337GN0
Whirlpool FGP337GN1
Whirlpool FGP337GN5
Whirlpool FGP337GQ0
Whirlpool FGP337GQ1
Whirlpool FGP337GQ5
Whirlpool FGP337GW0
Whirlpool FGP337GW1
Whirlpool FGP337GW5
Whirlpool FGP337HN0
Whirlpool FGP337HQ0
Whirlpool FGP337HW0
Whirlpool FGP337KN0
Whirlpool FGP337KQ0
Whirlpool FGP337KW0
Whirlpool FGP337KW1 30" Gas Freestanding Standard Clean Range Electro
Whirlpool FGP345VL0
Whirlpool FGP345VL1
Whirlpool FGP345VL2
Whirlpool FGP345VW0
Whirlpool FGP345VW1
Whirlpool FGP345VW2
Whirlpool FGP345YL0
Whirlpool FGP345YW0
Whirlpool FGP355VL0
Whirlpool FGP355VL1
Whirlpool FGP355VL2
Whirlpool FGP355VL3
Whirlpool FGP355VW0
Whirlpool FGP355VW1
Whirlpool FGP355VW2
Whirlpool FGP355VW3
Whirlpool FGP355YL0
Whirlpool FGP355YW0
Whirlpool FGP357XL0
Whirlpool FGP357XW0
Whirlpool FGP357YL0
Whirlpool FGP357YL1
Whirlpool FGP357YL3
Whirlpool FGP357YW0
Whirlpool FGP357YW1
Whirlpool FGP357YW2
Whirlpool FGP357YW3
Frigidaire FGQ1442ES0 Frigidaire/dryer
Frigidaire FGQ332ES0 Frigidaire/gas Dryer
Frigidaire FGQB2152FE0 Frigidaire/dryer
Frigidaire FGQB4000FS0 Frigidaire/dryer
Frigidaire FGQBB30DS0 Frigidaire/dryer
Frigidaire FGR211AS0 Dryer - Frigidaire
Frigidaire FGR211AS1 Dryer - Frigidaire
Frigidaire FGR211AS2 Frigidaire/gas Dryer
Frigidaire FGR211AS3 Frigidaire/gas Dryer
Frigidaire FGR211AS4 Frigidaire/dryer
Frigidaire FGR211MAS0 Frigidaire/dryer
Frigidaire FGR221AS0 Dryer - Frigidaire
Frigidaire FGR231AS0 Dryer - Frigidaire
Frigidaire FGR231AS1 Dryer - Frigidaire
Frigidaire FGR231AS2 Frigidaire/dryer
Frigidaire FGR231AS3 Frigidaire/gas Dryer
Frigidaire FGR231AS4 Frigidaire/dryer
Frigidaire FGR231CAS4 Frigidaire/dryer
Frigidaire FGR311FS0 Frigidaire/dryer
Frigidaire FGR331AS0 Dryer - Frigidaire
Frigidaire FGR331AS1 Dryer - Frigidaire
Frigidaire FGR331KAS1 Frigidaire/gas Dryer
Frigidaire FGR341AC0 Frigidaire/dryer
Frigidaire FGR341AC1 Frigidaire/dryer
Frigidaire FGR341AS0 Dryer - Frigidaire
Frigidaire FGR341AS1 Dryer - Frigidaire
Frigidaire FGR641FS0 Frigidaire/dryer
Frigidaire FGR6600ES0 Frigidaire/dryer
Frigidaire FGR6600FS0 Frigidaire/dryer
Frigidaire FGRB5700DS0 Frigidaire/dryer
Frigidaire FGRB6600ES0 Frigidaire/dryer
Frigidaire FGRB6600FS0 Frigidaire/dryer
Frigidaire FGRB7800DS0 Frigidaire/dryer
Whirlpool FGS325RQ0 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ1 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD0 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD1 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD3 30" Gas Freestanding Self Clean Range
Whirlpool FGS335EN0
Whirlpool FGS335EQ0
Whirlpool FGS335EW0
Whirlpool FGS337GN0
Whirlpool FGS337GN1
Whirlpool FGS337GN5
Whirlpool FGS337GQ0
Whirlpool FGS337GQ1
Whirlpool FGS337GQ5
Whirlpool FGS337GQ6
Whirlpool FGS337GQ7
Whirlpool FGS337GW0
  #2 (permalink)
Old 01-17-2013, 03:11 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Did it make any noise when it should wash?
Did it drain?
Which motor did you remove?
Here are the breakdown diagrams and Parts for Frigidaire FDB520RHB0 Dishwasher - AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 01-17-2013, 03:32 PM
Junior Member
Default
It does make a whining noise when it should be washing I took the motor on the bottom center out number 70 in the diagram it functioned properly on a bench test, the unit drains with no problems as well.
  #4 (permalink)
Old 01-18-2013, 01:29 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Would the spray arms spin if you will open the door during the wash cycle?
Remove the toe panel and check if the motor which you removed earlier is working?
__________________
  #5 (permalink)
Old 01-18-2013, 11:24 PM
Junior Member
Default
The spray arms do not spin, as for removing the toe kick and checking the motor it is getting power and works off of the machine. I guess I'm not sure how to check it on the machine? Does the drain pump act as the spray/wash pump as well?
  #6 (permalink)
Old 01-19-2013, 01:49 AM
Junior Member
jenniferatkins is on a distinguished road
Default frigidaire
If you are not sure how to check the drain pump or any other washer parts of your Frigidaire washing machine then don't try to repair it your self. It will be better if you call a expert repairman for repairing. He is solve your problem very well. I want to add one thing your washer belt may be crack or damaged. It may have to be replace.
  #7 (permalink)
Old 01-21-2013, 01:47 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by racer35j View Post
...The spray arms do not spin...
...as for removing the toe kick and checking the motor it is getting power and works off of the machine...
Open the door during the wash cycle and check the water level inside. Try to add a few cups of water manually to see if the spray arm will spin.
Remove the toe panel and touch the motor while it's on wash cycle. You should feel it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
frigidaire dw GUNNER50 Dishwasher Repair 1 06-26-2012 02:45 AM
Frigidaire norty777 Refrigerator & Freezer Repair 0 01-13-2011 09:16 AM
FRIGIDAIRE FDB2410LDC1 Frigidaire/dishwa mlender Dishwasher Repair 1 12-31-2010 10:52 AM
Frigidaire niesee16 Washer Repair 0 07-15-2010 10:24 AM
frigidaire kailey309 Dishwasher Repair 1 12-18-2009 04:40 AM
