Discuss
Dishwasher Won't Fill
 in
Dishwasher Repair
GE Dishwasher Model EDW6060L00SS quit working. When first happened it was only partially drained and wouldn't fill when cycle started.
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dishwasher Won't Fill
  #1 (permalink)
Old 01-12-2013, 10:48 AM
Junior Member
Rjkaster is on a distinguished road
Default Dishwasher Won't Fill
Model Number: EDW6060L00SS   Brand: GE   Age: 5 - 10 years
GE Dishwasher Model EDW6060L00SS quit working. When first happened it was only partially drained and wouldn't fill when cycle started. Repairman came and said there was low voltage to the water valve therefore the control board was not working. I replaced the control board myself. Piece of cake. Still wont work. The display and buttons work as if everything is fine. When I start the cycle I can here a click at valve, then another click after a short period of time. Checked flood control with ohm meter and it has continuity across it when float is down and continuity breaks when float is raised (by hand). The voltage at the water valve is about 30 volts when the cycle starts then drops to 0 volts after a short period. I disconnected valve and cleaned filter. Good water flow to valve. What next???????
Ads By Google
Related Models
General Electric EDW6060L00SS Dishwasher
General Electric EDW6060L15SS Dishwasher
General Electric EDW6100N00BB Dishwasher
General Electric EDW6100N00CC Dishwasher
General Electric EDW6100N00WW Dishwasher
General Electric EDW6160N00SS Dishwasher
Hardwick EE7-11819R Walloven - Std Ele
Whirlpool EEB191EKWR0
Whirlpool EEB191EKWR2
Whirlpool EEB191MKWR0
Whirlpool EEB191PKWR0
Whirlpool EEB191PKWR1
Whirlpool EEB191PKWR2
Whirlpool EEB191PKWR3
Whirlpool EEB192MKWR0
Whirlpool EED191EKWR0
Whirlpool EED191EKWR1
Whirlpool EED191MMWR0
Whirlpool EED191MMWR2
Whirlpool EED191PKWR0
Whirlpool EED191PKWR2
Whirlpool EED191PKWR3
Whirlpool EED191SKWR0
Whirlpool EED191SKWR1
Whirlpool EED191VKWR0
Whirlpool EED191VKWR1
Whirlpool EED192EKWR0
Whirlpool EED192MMWR0
Whirlpool EED192MMWR1
Whirlpool EED192PKWR0
Whirlpool EED192PKWR1
Whirlpool EED192SKWR0
Whirlpool EED192VKWR0
Whirlpool EED193EKWR0
General Electric EED2000A0WW Electric dryer
General Electric EED2000A1WW Electric dryer
Whirlpool EED221MKWR0
Whirlpool EED221MKWR2
Whirlpool EED221MMWR0
Whirlpool EED221MTWR0
Whirlpool EED221MTWR1
Whirlpool EED221PKWR0
Whirlpool EED221VKWR0
Whirlpool EED222MKWR0
Whirlpool EED222MTWR0
Whirlpool EED251MMWR0
Whirlpool EED251MMWR1
Whirlpool EED251MMWR4
Whirlpool EED261MKWR0
Whirlpool EED261MKWR1
Whirlpool EED261MKWR2
Whirlpool EED261MKWR3
General Electric EED3000B0WW Electric dryer
General Electric EED3000B1WW Electric dryer
General Electric EED3000B2WW Electric dryer
Whirlpool EED4100SQ0 29" Electric Dryer
Whirlpool EED4300SQ0 29"electric Dryer
Whirlpool EED4300TQ0 29" Electric Dryer
Whirlpool EED4400SQ0 29"electric Dryer
Whirlpool EED4400TQ0 29" Electric Dryer
General Electric EED4500D0WW Electric dryer
General Electric EED6500D0WW Electric dryer
General Electric EED6500D1WW Electric dryer
Whirlpool EEH061CW0
Whirlpool EEH061FW0
Whirlpool EEH061FW1
Whirlpool EEH091CW0
Whirlpool EEH091FW0
Whirlpool EEH091FW1
Whirlpool EEH151CW0
Whirlpool EEH151CW5
Whirlpool EEH151FW1
Whirlpool EEH152FW0
Whirlpool EEH153FW0
Whirlpool EEH153FW5
Whirlpool EEH153FW8
Whirlpool EEH181FW0
Whirlpool EEH182FW0
Whirlpool EEH182FW5
Whirlpool EEH182FW7
Whirlpool EEH231FW1
Whirlpool EEH232FW0
Whirlpool EEH232FW5
Whirlpool EEH232FW8
Whirlpool EEH271FW1
Whirlpool EEH272FW0
Whirlpool EEH272FW1
Whirlpool EEH272FW5
Whirlpool EEH272FW6
Whirlpool EEH272FW8
Whirlpool EEL131CTWL0
Whirlpool EEL131CTWR0
Whirlpool EEL131CTWR1
Whirlpool EEL131CTWR2
Whirlpool EEL131CTWR3
Whirlpool EEL131CTWR4
Whirlpool EEL141CTWR0
Whirlpool EEL141CTWR1
Whirlpool EEL141ETWR0
Whirlpool EEL142CTWR0
Whirlpool EEL142ETWR0
General Electric EER2000C00BB Electric range
General Electric EER2000C00CC Electric range
General Electric EER2000C00WW Electric range
General Electric EER2000C04BB Electric range
General Electric EER2000C04CC Electric range
General Electric EER2000C04WW Electric range
General Electric EER3000D00BB Electric range
General Electric EER3000D00CC Electric range
General Electric EER3000D00TW Electric range
General Electric EER3000D01BB Electric range
General Electric EER3000D01CC Electric range
General Electric EER3000D01TW Electric range
General Electric EER3000F01BB Electric range
General Electric EER3000F01CC Electric range
General Electric EER3000F01TW Electric range
General Electric EER3000H01BB Electric range
General Electric EER3000H01KC Electric range
General Electric EER3000H01TW Electric range
General Electric EER3000H02BB Electric range
  #2 (permalink)
Old 01-15-2013, 03:54 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Here are your parts.
Parts for GE EDW6060L00SS Dishwasher - AppliancePartsPros.com
Disconnect the wires from the water inlet valve and attach your meter leads to them. Make sure that they cannot short to each other or the frame.
Now try a cycle, if you see 120 volts across the valve wires when it should be filling then odds are that you have a bad connection or contact set somewhere in the wiring.
Here is my thoughts on this if I read your post correctly. You see 30 volts across the valve when it should be filling so it is dropping 90 volts somewhere else in the wiring due to the current pull. This could be pitted contacts or a bad (loose or dirty) connection.When you attach just the meter there is very little current flow so you see the full voltage.
Remove power from the unit set your meter on it's most sensitive meter scale. Short the meter leads together before you start masuring so you know what if any zero offset the meter has.
Remove both wires from the overflow switch and measure the switch contacts. They should be 0 ohms when the switch is activated.
If OK
Remove the wires that go to the valve/overflow switch at the control board.
Short the wires for the valve and the switch together then check the resistance, should be 0 ohms.
It may also be the valve itself but I would have thought it would blow a fuse if the valve was dropping the 120 down to 30 volts but who knows they may have a current limiting device on the board.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dishwasher will not fill repair monkey Dishwasher Repair 0 10-03-2012 06:51 PM
Dishwasher won't fill segriggs Dishwasher Repair 2 03-21-2011 03:33 PM
Dishwasher won't fill idgie Dryer Repair 3 01-25-2011 04:56 AM
dishwasher will not fill wledswift Dishwasher Repair 3 12-15-2009 06:35 PM
Dishwasher will not fill DFinan Dishwasher Repair 0 07-20-2009 01:19 PM
