| » Washer does not get cold water, works with hot only |
Model Number: S2100G5WW Brand: GE Age: 1 - 5 years
The washer does not supply cold water. The pipe for cold water is OK. Washing with hot water only.
Thanks! Ads By Google Related Models |
Hi.
Remove the cold water hose and check if the water goes through it, next check if the screen inside the water valve port is not blocked with debris.Clean if needed. Next open the control panel and with temperature set for COLD/COLD start the washer and check using the multimeter for 120VAC at the water inlet valve coils between T-WR and V-WR. If correct voltage is present - replace the water valve Part number: WH13X10026 If not - check the temperature switch contacts 1-3 for continuity. If open - replace it Part number: WH12X10498 If it's closed - replace the timer Part number: WH12X10338 Here are the breakdown diagrams and Controls & Backsplash parts for GE S2100G5WW - AppliancePartsPros.com Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| washer is filling with hot water but no COLD water is coming through | rocky777 | Washer Repair | 1 | 06-18-2012 02:41 PM |
| Maytag washer no cold water during cycle, but finger faucet works | jimbojamble | Washer Repair | 0 | 09-25-2010 10:23 AM |
| washer won"t run on cold cold water setting | jwh4969 | Washer Repair | 1 | 12-23-2008 06:41 AM |
| Freezer works, refrigerator not cold also water drips and accumalates on bottom shelf | taf | Refrigerator & Freezer Repair | 3 | 09-09-2008 11:18 AM |
| Washer works great,.. but won't spin out water from clothes. | PhantomLord | Washer Repair | 13 | 08-28-2008 08:22 AM |
