Discuss
quiet clean II, no water from spray arm
 in
Dishwasher Repair
I get water into & pumped out of washer but no water out of spray arm. I can hear water
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » quiet clean II, no water from spray arm
  #1 (permalink)
Old 02-03-2008, 06:46 PM
strattm strattm is offline
Junior Member
strattm is on a distinguished road
Default quiet clean II, no water from spray arm
Model Number: gdb635rhs0   Brand: Gibson   Age: 5 - 10 years
I get water into & pumped out of washer but no water out of spray arm. I can hear water enter & drain from machine thru tailpeice. This breakdown occurred after weeks of a louder operating noise, mechanical in nature, than usual. Any Ideas as to what this problem may be?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-04-2008, 02:30 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely there is a foreign object inside the pump intake which could cause a damage to the motor and/or impeller.
Remove the lower spray arm and the filter.
Remove the screw holding the impeller cover (#10 on the motor & pump break down diagram). Remove the cover and check for any foreign objects.
- Here are the break down diagrams for the Gibson dishwasher Model GDB635RHS0
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Quiet Parnter II Locked bigbalbossa Dishwasher Repair 31 12-12-2008 11:01 PM
Kenmore doesn't clean-"Clean " Flashning Seven times demark Dishwasher Repair 44 03-10-2008 02:17 PM
Dishwasher not cleaning,water not hot, spray arms not working postofficepatty Dishwasher Repair 0 01-29-2008 06:22 PM
Whirlpool Quiet Partner III Does Not Drain volant Dishwasher Repair 6 12-28-2007 03:17 AM
DW arms won't spray the water rflores Dishwasher Repair 1 08-07-2007 10:24 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
