| » No voltage to soap dispenser actuator |
Model Number: GHDA690PBB Brand: GE Age: 1 - 5 years
Tested the soap dispenser actuator and it tested good. Ran a complete cycle with a volt meter hooked up to soap dispenser actuator wires and did not get any voltage. Not sure if this is a control board problem.
Any advice would be appreciated Wayne Ads By Google Related Models |
Hi.
If you are not getting 120VAC to the dispenser - replace the control board Part number: WD21X10366 Here are the breakdown diagrams and Escutcheon & Door Assembly parts for GE GHDA690P00BB - AppliancePartsPros.com Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
You are welcome.
Simon.
__________________
Congratulations on the good job.
Simon.
__________________
Hey Simon,
I hate to bother you again but my soap door is still not opening. Worked the first time but not since. I ran the cycle again with the volt meter hooked up and it is getting 120 volts to the actuator but for only 1 minute on a stop watch. When I test the soap door hooked directly to 120 volts it takes 1 minute 22 seconds for the actuator to open the door. Is this a normal time for the actuator to work and should I be getting voltage to it for more than 1 minute? Thanks Wayne |
Hi.
Checked all possible sources with no luck.Nobody mentions for how long the wax motor is energized. You should replace the dispenser Part number: WD12X10220 and return the control board back if you got it from APP. Thank you. Simon.
__________________
| Display Modes | |
| Replacing Water Dispenser Actuator | gpeteman | Refrigerator & Freezer Repair | 5 | 11-29-2012 06:35 AM |
| Bosch Dispenser Actuator Inactive | muppin | Dishwasher Repair | 0 | 02-05-2011 11:56 AM |
| New ice dispenser actuator arm gets stuck | moboner | Refrigerator & Freezer Repair | 0 | 08-22-2009 10:01 AM |
| Dishwasher soap dispenser will not open (sticks to soap) | macfisto | Dishwasher Repair | 2 | 06-17-2008 08:20 AM |
| dishwasher soap dish actuator | herefishy | Dishwasher Repair | 0 | 04-29-2008 04:27 PM |
