| » noisy pump |
Model Number: 36315324100 Brand: Kenmore Age: 1 - 5 years
washer wasn't fully draining, so i pulled the pump out for clean up, found soap scum, and cotton arround the shaft. but after i reinstalled the pump it make a grinding noise when ever water is applyed. any ideas?
Hi.
Check the sump for foreign objects, check if you reinstalled everything correctly (the impeller), check if the noise is coming from the motor. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
thank you. yes there was pieces of glass under the impeller. and the motor was also noisy.i ended up replacing the entire assembly.. worked perfect.. 160 bucks
You are welcome.
Simon.
__________________
| Display Modes | |
| noisy discharge pump | stavros | Dishwasher Repair | 1 | 03-08-2012 02:34 PM |
| noisy motor or pump | FARRIS T | Dishwasher Repair | 0 | 12-20-2011 01:39 PM |
| Noisy icemaker pump | Rogers | Refrigerator & Freezer Repair | 1 | 10-30-2008 07:21 AM |
| Noisy water pump | sharv999 | Washer Repair | 2 | 09-29-2008 01:13 AM |
| Noisy drain pump | HOMIE | Dishwasher Repair | 1 | 01-10-2008 07:58 PM |
