Low water pressure
I have a problem in my house with low water pressure. this causes the dishwasher to not load with water fully. Is there a way to increase the time for water loading? The reason for this is that my top rack is not getting clean. seems that the sprayer is not rotating. This is water spraying out of the nozzle. I can not see the model number but it is an older version of FFBD2406NW they put the lable on the side of the door where opening and closing has worn it away.I have checked everywhere I can think for obstructions I cant think of any other problem spots but water filling
Not that I know of. The problem is that manufacturers do not publish schematics of the control boards. I am assuming that you have already checked the filter screen on the input side of the water valve. |
actually no I looked at it and wasn't sure how to.
If it is partially plugged it will decrease your water level.
| All times are GMT -7. The time now is 09:13 AM. |
