| » Frigidaire Dishwasher won't work after power outage |
Model Number: FDBB2040FC1 Brand: Frigidaire Age: 5 - 10 years
We had a winter storm where first we had a "brownout" where we had lower power coming into the house for around 6 hours, then the power went off and on for various amounts of time for the rest of the day. When all of this was over and we had power back 100%, the circuit breaker was tripped for the dishwasher. I flipped the circuit, but when I tried to run the dishwasher (it was not running when power issues began, but was latched) it would not start. No response whatsoever.
Things I have checked: Circuit is good (switched it out with another circuit and worked fine) Outlet is good Checked power with multimeter and had power in the line within the dishwasher through the latch up to the control board. Not sure if the control board is bad? I dont see any signs of burnout etc. Dont want to waste money on the part and find out this is not the problem. Any suggestions would be appreciated. Ads By Google Related Models |
Hi.
Remove the kick panel and open the junction box.Use the multimeter to check if there is 120VAC going into the dishwasher. If it is - most likely you need to replace the control panel Part number: 154474701 There is still a good chance that the control board is bad Part number: 154663001 Get both of them and try the control panel first. Remember that you can return any parts you don't need, even installed ones. Here are the breakdown diagrams and Control Panel parts for Frigidaire FDBB2040FC1 - AppliancePartsPros.com Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| washer won't power on after power outage | DireWolf | Washer Repair | 1 | 04-26-2011 05:36 PM |
| Kenmore dishwasher stopped working after power outage | jklovell | Dishwasher Repair | 2 | 10-21-2009 12:39 PM |
| Power Outage while using oven, now ti doesn't work | RachelK | Oven Repair (including Ranges and Cooktops) | 0 | 10-07-2009 03:40 PM |
| oven controls don't work after power outage | nooven | Oven Repair (including Ranges and Cooktops) | 1 | 12-07-2008 02:08 PM |
| Power Outage - Dishwasher in a stuck state | gb14772 | Dishwasher Repair | 0 | 07-20-2008 10:14 AM |
