| » ZBD5900 fails to drain and stops |
Model Number: ZBD5900F01SS Brand: GE Age: 5 - 10 years
Greetings,
Our GE Monogram ZBD5900 has begun failing to drain and defauting to an error mode. Sometimes pulling the circuit breaker and pushing various control buttons gets the washer to drain and complete the cycle. The error indication is a blinking "rinse and hold" LED. Usually if I bail all the water out of the washer and then cut the power, the washer will then cycle properly for one cycle. What controls the drain cycle? Just the drain pump? Or does the sump float switch affect the drain cycle? I've removed the control board and the components, traces, and connectors all look fine. Any suggestions would be greatly appreciated. Thanks. Ads By Google Related Models |
| Display Modes | |
| Washer stops at drain cycle | salvi | Washer Repair | 1 | 12-11-2012 06:31 PM |
| Whirlpool stops after tub fills and won't drain | bogman14 | Dishwasher Repair | 0 | 07-07-2012 09:57 PM |
| Washer stops when it's ready to drain. | isroloco | Washer Repair | 1 | 09-28-2011 06:37 PM |
| GE Profile Quiet Power II fails to drain | Island Joe | Dishwasher Repair | 12 | 10-26-2008 04:54 PM |
| washer both leaks and fails to fully drain | mathias | Washer Repair | 4 | 08-05-2008 02:28 PM |
