Discuss
Kitchen Aid seems to have problem with control board or keypad
 in
Dishwasher Repair
I have a Kitchen Aid KUDI01TJBL0 dishwasher (2001 model, I think) All of the buttons/lights seem to work fine, but
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Kitchen Aid seems to have problem with control board or keypad
  #1 (permalink)
Old 01-04-2013, 08:18 AM
Junior Member
pautler is on a distinguished road
Default Kitchen Aid seems to have problem with control board or keypad
Model Number: KUDI01TJBL0   Brand: Kitchen Aid   Age: More than 10 years
All of the buttons/lights seem to work fine, but the 'Start' button doesn't do anything. The "Cancel/Drain" button DOES work, and will run the machine through a 2min drain cycle.
I opened things up and used my meter to test the following: thermal fuse, door handle latch switch, the water fill float switch, the fill valve, and the ribbon cable coming from the keypad. I didn't test the ribbon cable super thoroughly, but I put my my meter across the pins for the various buttons (using 'diode mode'), especially the 'start' button, and they all seemed to behave properly.
I was thinking it was a problem with the electronic control board, so I ordered part 8564543 from APP.
The new board arrived (although I'm not sure if it's really 'new' - it looked like it might have been used/refurbished). After restoring power to the machine, I found that some of the buttons didn't seem to work, but others did, and I was able to get the machine to start. It ran for a while, and almost seemed to get stuck in a bit of a 'loop' and then it stopped. The "Heavy" light was flashing and the water did not drain out. Pushing other buttons on the keypad would only result in other lights flashing. I was not able to cancel/drain the machine, or get the flashing lights to turn off. I turned off the breaker (for quite a while...10+ minutes) but as soon as I restore power to the machine it would turn on for a few seconds and then stop with the "Heavy" light flashing. I repeated this many times, each time turning the power off for longer.
Finally I turned the power off, removed the 'new' control board and put my old one back in, and restored power. I used the cancel/drain button to empty the water, and then I was able to run the machine through 1 complete cycle successfully!... but then it went right back into the original state (all buttons & lights seeming to work fine, including the cancel/drain button, but NOT the 'start' button.)
I swapped the two control boards back and forth a couple times, and was never able to get the machine to run through a cycle again. The original control board consistently results in all the lights/buttons working except for the 'start' button, and the 'new' control board tries to run the machine as soon as power is turned on, and then stops with the 'heavy' light flashing.
Sooooo, I'm thinking that either my original control board and the 'new' control board I received both have problems (albeit it different problems) or it's actually my console/keypad that is the problem. Or maybe something totally different?
Any help or advice would be GREATLY appreciated! I'm thinking I should try to test my console/keypad more thoroughly - testing every single pin/button combination on the ribbon cable, with polarities in both directions, to test the diodes - but I haven't found a great chart that tells me all of the mappings between buttons and pins.
Thank you!
-Joe
Ads By Google
Related Models
Whirlpool KUDI01TJBL0 Undercounter Dishwasher
Whirlpool KUDI01TJBL1 Undercounter Dishwasher
Whirlpool KUDI01TJBT0 Undercounter Dishwasher
Whirlpool KUDI01TJBT1 Undercounter Dishwasher
Whirlpool KUDI01TJWH0 Undercounter Dishwasher
Whirlpool KUDI01TJWH1 Undercounter Dishwasher
Whirlpool KUDI02CRBL0 Undercounter Dishwasher
Whirlpool KUDI02CRBL1 Undercounter Dishwasher
Whirlpool KUDI02CRBL2 Undercounter Dishwasher
Whirlpool KUDI02CRBL3 Undercounter Dishwasher
Whirlpool KUDI02CRBL4 Undercounter Dishwasher
Whirlpool KUDI02CRBS0 Undercounter Dishwasher
Whirlpool KUDI02CRBS1 Undercounter Dishwasher
Whirlpool KUDI02CRBS2 Undercounter Dishwasher
Whirlpool KUDI02CRBS3 Undercounter Dishwasher
Whirlpool KUDI02CRBS4 Undercounter Dishwasher
Whirlpool KUDI02CRWH0 Undercounter Dishwasher
Whirlpool KUDI02CRWH1 Undercounter Dishwasher
Whirlpool KUDI02CRWH2 Undercounter Dishwasher
Whirlpool KUDI02CRWH3 Undercounter Dishwasher
Whirlpool KUDI02CRWH4 Undercounter Dishwasher
Whirlpool KUDI02FRBL0 Undercounter Dishwasher
Whirlpool KUDI02FRBL1 Undercounter Dishwasher
Whirlpool KUDI02FRBL2 Undercounter Dishwasher
Whirlpool KUDI02FRBL3 Undercounter Dishwasher
Whirlpool KUDI02FRBL4 Undercounter Dishwasher
Whirlpool KUDI02FRSS0 Undercounter Dishwasher
Whirlpool KUDI02FRSS1 Undercounter Dishwasher
Whirlpool KUDI02FRSS2 Undercounter Dishwasher
Whirlpool KUDI02FRSS3 Undercounter Dishwasher
Whirlpool KUDI02FRSS4 Undercounter Dishwasher
Whirlpool KUDI02FRWH0 Undercounter Dishwasher
Whirlpool KUDI02FRWH1 Undercounter Dishwasher
Whirlpool KUDI02FRWH2 Undercounter Dishwasher
Whirlpool KUDI02FRWH3 Undercounter Dishwasher
Whirlpool KUDI02FRWH4 Undercounter Dishwasher
Whirlpool KUDI02IRBL0 Undercounter Dishwasher
Whirlpool KUDI02IRBL1 Undercounter Dishwasher
Whirlpool KUDI02IRBL2 Undercounter Dishwasher
Whirlpool KUDI02IRBL3 Undercounter Dishwasher
Whirlpool KUDI02IRBL4 Undercounter Dishwasher
Whirlpool KUDI02IRBS0 Undercounter Dishwasher
Whirlpool KUDI02IRBS1 Undercounter Dishwasher
Whirlpool KUDI02IRBS2 Undercounter Dishwasher
Whirlpool KUDI02IRBS3 Undercounter Dishwasher
Whirlpool KUDI02IRBS4 Undercounter Dishwasher
Whirlpool KUDI02IRBT0 Undercounter Dishwasher
Whirlpool KUDI02IRBT1 Undercounter Dishwasher
Whirlpool KUDI02IRBT2 Undercounter Dishwasher
Whirlpool KUDI02IRBT3 Undercounter Dishwasher
Whirlpool KUDI02IRBT4 Undercounter Dishwasher
Whirlpool KUDI02IRWH0 Undercounter Dishwasher
Whirlpool KUDI02IRWH1 Undercounter Dishwasher
Whirlpool KUDI02IRWH2 Undercounter Dishwasher
Whirlpool KUDI02IRWH3 Undercounter Dishwasher
Whirlpool KUDI02IRWH4 Undercounter Dishwasher
Whirlpool KUDI210S0
Whirlpool KUDI21DS0
Whirlpool KUDI21DS1
Whirlpool KUDI21DS2
Whirlpool KUDI21DS3
Whirlpool KUDI21SS1
Whirlpool KUDI21SS2
Whirlpool KUDI220T0
Whirlpool KUDI220T1
Whirlpool KUDI220T2
Whirlpool KUDI220T3
Whirlpool KUDI220T4
Whirlpool KUDI220T5
Whirlpool KUDI220T6
Whirlpool KUDI220WWH0
Whirlpool KUDI220WWH1
Whirlpool KUDI220WWH2
Whirlpool KUDI220WWH3
Whirlpool KUDI220WWH4
Whirlpool KUDI22GT0
Whirlpool KUDI22GT1
Whirlpool KUDI22GT2
Whirlpool KUDI22GT3
Whirlpool KUDI22HT0
Whirlpool KUDI22HT1
Whirlpool KUDI22HWWH0
Whirlpool KUDI22HWWH1
Whirlpool KUDI22XX0
Whirlpool KUDI22XX1
Whirlpool KUDI22XX2
Whirlpool KUDI230B0
Whirlpool KUDI230BAL0
Whirlpool KUDI230BW0
Whirlpool KUDI230BWH0
Whirlpool KUDI23HB0
Whirlpool KUDI23HBWH0
Whirlpool KUDI24SEAL0
Whirlpool KUDI24SEAL1
Whirlpool KUDI24SEAL2
Whirlpool KUDI24SEAL3
Whirlpool KUDI24SEAL4
Whirlpool KUDI24SEAL5
Whirlpool KUDI24SEBL0
Whirlpool KUDI24SEBL1
Whirlpool KUDI24SEBL2
Whirlpool KUDI24SEBL3
Whirlpool KUDI24SEBL4
Whirlpool KUDI24SEBL5
Whirlpool KUDI24SEWH0
Whirlpool KUDI24SEWH1
Whirlpool KUDI24SEWH2
Whirlpool KUDI24SEWH3
Whirlpool KUDI24SEWH4
Whirlpool KUDI24SEWH5
Whirlpool KUDI25CHAL0
Whirlpool KUDI25CHBL0
Whirlpool KUDI25CHBL1
Whirlpool KUDI25CHBS0
Whirlpool KUDI25CHBT0
Whirlpool KUDI25CHBT1
Whirlpool KUDI25CHWH0
Whirlpool KUDI25CHWH1
Whirlpool KUDJ01TJBL0 Undercounter Dishwasher
Whirlpool KUDJ01TJBL1 Undercounter Dishwasher
  #2 (permalink)
Old 01-04-2013, 10:30 AM
Junior Member
Default
fyi... I called the APP customer service number and they recommended that I try ordering the console/keypad (part 8270223) to see if that does the trick. They were *super* helpful and said that I can send back either part (or both) for a refund if need be.
I'll post an update after I get the console/keypad, in case this information is useful to anyone else searching this forum in the future with a similar problem.
-Joe
  #3 (permalink)
Old 01-04-2013, 11:16 AM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Most likely it is the control panel/key pad. That should take care of the problem.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #4 (permalink)
Old 01-05-2013, 04:38 AM
Junior Member
Default
Attached to this post is the diagram for the keypad matrix from the tech sheet for my model.
I tested all of the 'button pushes' with my multimeter in diode mode, and they all seemed fine as follows:
P1-13 (+) -> P1-5 (-), push 'normal wash' => .78V
P1-13 (+) -> P1-4 (-), push 'Heavy' => .78V
P1-12 (+) -> P1-5 (-), push 'Rinse Only' => .78V
P1-12 (+) -> P1-4 (-), push 'Start' => .78V
P1-12 (+) -> P1-2 (-), push 'Cancel/Drain' => .76V
P1-11 (+) -> P1-6 (-), push 'Energy Saver Dry' => .80V
P1-11 (+) -> P1-4 (-), push 'High Temp Wash' => .79V
I also tested most of them with my leads connected with opposite polarity, and they did not show any reading (as would be expected, since the diodes should only pass current in 1 direction).
Now, my question is with regards to the 3 diodes that are shown all the way on the left side of the diagram - they are marked D6, D7, & D8. Based on the diagram, it would seem to me that my diode tester should always show a reading (without any button press) for:
P1-11 (+) -> P1-1 (-)
P1-12 (+) -> P1-1 (-)
P1-13 (+) -> P1-1 (-)
However, I don't. My meter shows 'overload' (open circuit) for all 3 of those connections. BUT, if I connect the leads in the opposite direction for P1-12 (-) -> P1-1 (+) then I do get a reading of .76V. The other two paths show 'overload' regardless of which way I connect the leads.
Is this indicative of a problem with the keypad/console, or is this expected behavior? Like I said, I really don't understand the purpose/function of those 3 diodes on the left side of the diagram - I suspect they might have something do with grounding?
I have a new keypad/console on the way from APP, but I'm just not sure that it is going to fix my problem. I'm still wondering if I might have 2 faulty control boards.
Thanks in advance for any help you might be able to provide!!
-Joe
  #5 (permalink)
Old 01-09-2013, 08:07 AM
Junior Member
Default
The new "control panel" (that's the front console, including the keypad buttons and ribbon cable) seems to have resolved the problem. I successfully ran 3 loads through the dishwasher, using the new "control panel" and my original "control board" (circuit board).
-Joe
  #6 (permalink)
Old 01-09-2013, 11:12 AM
Expert
Default
You are welcome,Joe.
I'm glad the problem is taken care off.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kitchen Aid Control Board diceboy15 Refrigerator & Freezer Repair 6 09-18-2011 05:50 AM
Replacing Kitchen Aid Control Board paul_8788 Oven Repair (including Ranges and Cooktops) 0 10-22-2010 12:45 PM
Kitchen aid control board abtrman Dishwasher Repair 2 03-10-2010 01:37 PM
Kitchen Aid:Switch Panel Membrane or Control Board? Pirate6381 Dishwasher Repair 1 11-08-2009 04:19 AM
Kitchen Aid Control Board Replacement Help tjgx100 Microwave Repair 2 12-08-2008 01:21 PM
