Discuss
Frigidaire DW Will Not Drain
 in
Dishwasher Repair
I have a Frigidaire Dishwasher ( Model#GLD2250RDC3 ) that slowly stopped draining over several uses. Although it is an older
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Frigidaire DW Will Not Drain
  #1 (permalink)
Old 01-03-2013, 02:40 PM
Junior Member
Flyer421 is on a distinguished road
Default Frigidaire DW Will Not Drain
Model Number: GLD2250RDC3   Brand: Frigidaire   Age: Less than 1 year
I have a Frigidaire Dishwasher (Model#GLD2250RDC3) that slowly stopped draining over several uses. Although it is an older dishwasher it was installed about 3 months ago and was never used before then.
At first, when I found more RINSE water than normal was left in the bottom of the DW (touching the heating element), I started a new cycle (which caused the pump to run) then pressed "Cancel" which caused the pump to run for another 90 sec. I could hear the whisper of the pump as well as hear the water drain into the garbage disposal - taking the water down to a level I was used to (about 3/4 inch from screen).
After doing this for a couple weeks I could still hear the pump but I couldn't hear the water anymore and the water wasn't draining from the DW. I also noticed the water was dirtier/soapier than when the issue first started. Consequently leaving water with debris on top of the dishes. It appears as though when I first noticed it that the wash cycle must have completely drained, replacing the soapy/dirty water with cleaner rinse water and as time went on, the wash water didn't drain either. This is just speculation though.
Is it possible the pump is bad even though it still runs?
Here is what I have done so far:
1. Verified no blockage inside the dishwasher - I removed the sprayer arm & screen and made sure there was nothing blocking the drain (we thoroughly rinse our dishes prior to putting them in the DW so there was little chance this was the problem).
2. Verified no blockage in the drain tube - first I detached the tube from the pump and successfully blew through the tube, but I also removed the tube and ran water through it from the faucet. I was pretty sure this wasn't the problem either since it has only been in use for 3 months.
3. Verified the pump is running - after disassembling the pump housing, I re-connected the wiring and started a cycle on the DW. The pump impeller rotated. To make sure it would pump water, I poured a pitcher of water into the DW and the water came down into the pump and was forced out of the pump into another pitcher. When I inserted the inlet portion of the pump into a pan of water, it did not have enough power to create a vacuum and suck the water out of the pan, but that may be normal.
After completely detaching the DW from water and power I thought I should have tried pumping the water through the drain hose into the sink just to see if it had enough power to pump through that much pipe. I might give that a try while waiting for feedback to this post.
Everything I have read on websites assumes the pump is bad only if the impeller isn't turning, is it possible that it is bad even though the pump turns?
Thanks for your help!
UPDATE: 1/4/13 I haven't received replies yet so I keep researching. It seams that the more I research the more questions I have.
A couple websites (on other models) suggested that no/slow draining could be the cause of a bad solenoid. However, in the parts diagram for my model I can't find a solenoid. I have also found references to different types of pumps: Reversible and Direct Drive. It is unclear which type I have, the manual doesn't specify and the websites I reviewed didn't describe how to find the type for your model of DW.
Descriptions of the two types of pumps suggest that I could have either - here's why:
1. Direct Drive: The user manual for my model says "Precision Direct Wash System" - does this imply "Direct Drive"?
2. Reversible: It appears that my model has only a single pump (unless the second is extremely obscure). The lack of a second pump/motor suggests that one pump performs both the wash pumping (to circulate water through the spray arms into the cabinet) and the drain pumping (to eliminate the water from the cabinet).
However, in the same descriptions are ambiguities:
1. The part diagram does not specify two pumps (Wash & Drain) - must not be a direct drive.
2. The part diagram does not specify a solenoid which is used to switch (reverse) the pump from wash to drain - it must not be a reversible pump.
Another option I can think of is that the solenoid may be internal to the reversible pump. Therefore servicing the pump is analogous to servicing the solenoid. Though adding to the ambiguity, why do websites not include troubleshooting the electrical components of the internal solenoid the same way they do for the external solenoids?
If anyone can clear up my misunderstandings it sure would be appreciated.
Summary
1. Can a pump need replaced even if the impeller works?
2. Which type of pump does the Frigidaire GLD2250RDC3 have?
3. How does a person tell what type of pump their DW has?
4. In my specific situation, what techniques can be used to identify the issue rather than rely on speculation?
Thanks Everyone!
Ads By Google
Related Models
Frigidaire GLD2250RDC3 Frigidaire/dishwasher
Frigidaire GLD2250RDC4 Frigidaire/dishwasher
Frigidaire GLD2250RDC5 DISHWASHER
Frigidaire GLD2250RDC6 DISHWASHER
Frigidaire GLD2250RDQ0 Frigidaire/dishwasher
Frigidaire GLD2250RDQ1 Frigidaire/dishwasher
Frigidaire GLD2250RDQ2 Frigidaire/dishwasher
Frigidaire GLD2250RDQ3 Frigidaire/dishwasher
Frigidaire GLD2250RDQ4 DISHWASHER
Frigidaire GLD2250RDQ5 DISHWASHER
Frigidaire GLD2250RDS0 Frigidaire/dishwasher
Frigidaire GLD2250RDS1 Frigidaire/dishwasher
Frigidaire GLD2250RDS2 Frigidaire/dishwasher
Frigidaire GLD2250RDS3 Frigidaire/dishwasher
Frigidaire GLD2250RDS4 DISHWASHER
Frigidaire GLD2250RDS5 DISHWASHER
Frigidaire GLD2350RCB0 Frigidaire/dishwasher
Frigidaire GLD2350RCB1 Frigidaire/dishwasher
Frigidaire GLD2350RCC0 Frigidaire/dishwasher
Frigidaire GLD2350RCC1 Frigidaire/dishwasher
Frigidaire GLD2350RCQ0 Frigidaire/dishwasher
Frigidaire GLD2350RCQ1 Frigidaire/dishwasher
Frigidaire GLD2350RCS0 Frigidaire/dishwasher
Frigidaire GLD2350RCS1 Frigidaire/dishwasher
Frigidaire GLD2355RDB0 Frigidaire/dishwasher
Frigidaire GLD2355RDC0 Frigidaire/dishwasher
Frigidaire GLD2355RDC1 Frigidaire/dishwasher
Frigidaire GLD2355RDQ0 Frigidaire/dishwasher
Frigidaire GLD2355RDS0 Frigidaire/dishwasher
Frigidaire GLD2440REB0 Frigidaire/dishwasher
Frigidaire GLD2440REB1 Frigidaire/dishwasher
Frigidaire GLD2440REB2 Frigidaire/dishwasher
Frigidaire GLD2440REC0 Frigidaire/dishwasher
Frigidaire GLD2440REC1 Frigidaire/dishwasher
Frigidaire GLD2440REC2 Frigidaire/dishwasher
Frigidaire GLD2440REQ0 Frigidaire/dishwasher
Frigidaire GLD2440REQ1 Frigidaire/dishwasher
Frigidaire GLD2440REQ2 Frigidaire/dishwasher
Frigidaire GLD2440RES0 Frigidaire/dishwasher
Frigidaire GLD2440RES1 Frigidaire/dishwasher
Frigidaire GLD2440RES2 Frigidaire/dishwasher
Frigidaire GLD2445RFB0 Frigidaire/dishwasher
Frigidaire GLD2445RFB1 DISHWASHER
Frigidaire GLD2445RFB2 DISHWASHER
Frigidaire GLD2445RFC0 Frigidaire/dishwasher
Frigidaire GLD2445RFC1 DISHWASHER
Frigidaire GLD2445RFC2 DISHWASHER
Frigidaire GLD2445RFQ0 Frigidaire/dishwasher
Frigidaire GLD2445RFQ1 DISHWASHER
Frigidaire GLD2445RFQ2 DISHWASHER
Frigidaire GLD2445RFS0 Frigidaire/dishwasher
Frigidaire GLD2445RFS1 DISHWASHER
Frigidaire GLD2445RFS2 DISHWASHER
Frigidaire GLD2450RDB0 Frigidaire/dishwasher
Frigidaire GLD2450RDB1 Frigidaire/dishwasher
Frigidaire GLD2450RDQ0 Frigidaire/dishwasher
Frigidaire GLD2450RDQ1 Frigidaire/dishwasher
Frigidaire GLD2450RDS0 Frigidaire/dishwasher
Frigidaire GLD2450RDS1 Frigidaire/dishwasher
Frigidaire GLD2451RDB0 Frigidaire/dishwasher
Frigidaire GLD2451RDQ0 Frigidaire/dishwasher
Frigidaire GLD2451RDS0 Frigidaire/dishwasher
Frigidaire GLD2555NDB0 Frigidaire/dishwasher
Frigidaire GLD2555NDQ0 Frigidaire/dishwasher
Frigidaire GLD2555NDS0 Frigidaire/dishwasher
General Electric GLD2800T05BB DISHWASHER
General Electric GLD2800T05WW DISHWASHER
General Electric GLD2800T10BB DISHWASHER
General Electric GLD2800T10WW DISHWASHER
General Electric GLD2850T05CS DISHWASHER
General Electric GLD2850T10CS DISHWASHER
Frigidaire GLD2860RDB0 Frigidaire/dishwasher
Frigidaire GLD2860RDS0 Frigidaire/dishwasher
Frigidaire GLD2870RFB0 Frigidaire/dishwasher
Frigidaire GLD2870RFS0 Frigidaire/dishwasher
Frigidaire GLD2875FPB0 Frigidaire/dishwasher
Frigidaire GLD2875FPB1 Frigidaire/dishwasher
Frigidaire GLD2875FPB2 DISHWASHER
Frigidaire GLD2875FPW0 Frigidaire/dishwasher
Frigidaire GLD2875FPW1 Frigidaire/dishwasher
Frigidaire GLD2875FPW2 DISHWASHER
Frigidaire GLD3450RDB0 Frigidaire/dishwasher
Frigidaire GLD3450RDQ0 Frigidaire/dishwasher
Frigidaire GLD3450RDS0 Frigidaire/dishwasher
Frigidaire GLD3451RDB0 Frigidaire/dishwasher
Frigidaire GLD3451RDQ0 Frigidaire/dishwasher
Frigidaire GLD3451RDS0 Frigidaire/dishwasher
General Electric GLD3806T05BB DISHWASHER
General Electric GLD3806T05WW DISHWASHER
General Electric GLD3806T10BB DISHWASHER
General Electric GLD3806T10WW DISHWASHER
General Electric GLD3846T05SA DISHWASHER
General Electric GLD3846T10SA DISHWASHER
General Electric GLD3866T05SS DISHWASHER
General Electric GLD3866T10SS DISHWASHER
Frigidaire GLD4050RHB0 DISHWASHER
Frigidaire GLD4050RHB1 DISHWASHER
Frigidaire GLD4050RHS0 DISHWASHER
Frigidaire GLD4050RHS1 DISHWASHER
General Electric GLD4100L00BB Dishwasher
General Electric GLD4100L00CC Dishwasher
General Electric GLD4100L00WW Dishwasher
General Electric GLD4100M00BB Dishwasher
General Electric GLD4100M00CC Dishwasher
General Electric GLD4100M00WW Dishwasher
General Electric GLD4100M15BB Dishwasher
General Electric GLD4100M15CC Dishwasher
General Electric GLD4100M15WW Dishwasher
General Electric GLD4150L00CS Dishwasher
General Electric GLD4150M00CS Dishwasher
General Electric GLD4150M15CS Dishwasher
General Electric GLD4160L00SS Dishwasher
General Electric GLD4160M00SS Dishwasher
General Electric GLD4160M15SS Dishwasher
General Electric GLD4200L00BB Dishwasher
General Electric GLD4200L00CC Dishwasher
General Electric GLD4200L00WW Dishwasher
General Electric GLD4200L15BB Dishwasher
General Electric GLD4200L15CC Dishwasher
General Electric GLD4200L15WW Dishwasher
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire - Won't Drain TJCEngr Dishwasher Repair 3 04-10-2013 06:05 PM
Frigidaire DW won't drain srmauburn Dishwasher Repair 0 12-29-2012 06:53 AM
Frigidaire will not drain Jeff Holley Dishwasher Repair 0 11-28-2011 07:58 AM
Frigidaire Won't Drain mpvaughn1 Washer Repair 3 06-21-2009 10:45 AM
frigidaire d/w won't drain cmorris Dishwasher Repair 0 01-18-2008 03:30 PM
