| » Testing fuse P/N 675813 |
Model Number: 665.13693K600 Brand: Kenmore Age: 1 - 5 years
We have had an issue with the dishwaher, it stopped running and we are not certain of the problem.
Possibliy the fused link but I need to know how to test that componenent. Dishwasher Fuse, Kenmore 675813... Can anyone here supply me with the value of what to read on the existing fuse so that I can test it...? Thanks, rd Ads By Google Related Models |
Hi.
Here is the thermal fuse Part number: 675813 It's clipped on the side of the control board and you can check it by testing it for continuity. You will need a multimeter. Remove the kick panel and find there a tech sheet with instructions. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Quote:
Thanks Simon, I did locate the fuse and checked only for continuity, it is open... I did not know if that was all I needed to test for. Good deal, I also did not know about the kick panel hiding a diagram. I cannot seem to pry the panel off. Try again after breakfast. Thansk very much, Rob |
Hi.
Do not pry anything off! There are screws holding it. When replacing the fuse use the new wires in the kit. Simon.
__________________
Quote:
Yeah, that was a poor choice of words, I will check for the screws on the panel, 10-4 on the wires... We still have snow clean up to do so I'll check this out later... Oh, I have a jumper wire to test / verify that the fuse is the culprit. There should be no danger in checking that, correct..? Running the washer just for a few seconds with the jumper instead of the fuse...? Thanks again, Rob |
Yes, you can do that.
Simon.
__________________
| Display Modes | |
| Dryer overheat blowing thermal fuse heater box, not vent fuse | try2repairguy | Dryer Repair | 2 | 11-10-2011 08:27 AM |
| testing | wilpas | Oven Repair (including Ranges and Cooktops) | 0 | 07-20-2011 04:15 PM |
| Testing help please! | snovog | Oven Repair (including Ranges and Cooktops) | 0 | 05-16-2011 06:21 PM |
| diode testing | electricfave | Microwave Repair | 2 | 01-10-2009 03:07 PM |
