| » door leaks when washing |
Model Number: GSD4000J00BB Brand: GE Age: Less than 1 year
I have this dishwasher hooked up correctly, properly balanced and the tub fills easily. The problem is when I turn the wash cylce on.
At that point, when using detergent, it froths out of the bottom of the tub dangerously close to the motor electronics in front. This has also happened when I have test run it with clear water only. It's very disconcerting. I essentially only use the dishwasher to store dishes in, not to wash them, as I am concerned about water contact with electricity. I checked the tub gasket and it appears to be fine. Can you advise what the leakage problem may be and a remedy to fix it? Thank you. Related Models |
| Display Modes | |
| Whirlpool Dishwasher Door Leaks | snakeman56 | Dishwasher Repair | 5 | 03-21-2008 07:18 PM |
| Water leaks from top of door possibly vent | dbanister2 | Dishwasher Repair | 0 | 01-11-2008 09:43 PM |
| New lower door seal is too narrow and leaks | kkayaker | Dishwasher Repair | 4 | 12-14-2007 12:04 AM |
| Washing machine leaks from bottom | shechter | Washer Repair | 0 | 10-15-2007 02:26 PM |
| Washing Machine leaks when filling tank | cheryla | Washer Repair | 0 | 09-28-2007 01:10 AM |
