| » Dishwasher wont start new key pad installed |
Model Number: Jen aire Jdb1100aws Brand: Jenn-Air Age: 1 - 5 years
Thanks in advance for the help.
Dishwasher stopped working ,new control panel installed as per manufac recomendations . Machine worked fine for several days . Today , same problem as before . No power to the panel and machine wont start. I verified correct installation with the ribbon input to circuit board ,cleaned circuit board input as reco with isobu alcohol , cycled circuit breakers hairdryervto circuit board in case of moisture,this is my third control panel to the machine. Its only 5 years old , what would cause no power to the panel at all? No lights, nothing. Ads By Google Related Models |
Hello,
You may want to start the troubleshooting from verifying proper polarity and voltage at the power cord connection to the dishwasher. Unplug the dishwasher power cord. Remove the toe panel and open the junction box under the dishwasher. Make sure the black wire from the power cord is connected to the dishwasher black wire and the white wire from the power cord is connected to the dishwasher white wire. Verify that the all connections are firm. Check both door switches for continuity. Make sure they are properly engaged when the door is locked. Check for 120 VAC at the door switch where the black wires connected to. Post the results. Here are the breakdown diagrams and Parts for Jenn-Air JDB1100AWS Dishwasher - AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| New Motor Installed & Now Dryer Will Not Start | tbeaun | Dryer Repair | 1 | 10-03-2011 03:38 AM |
| Kenmor Washer Wont Spin/agitate New Controllor Installed | GEOR35 | Washer Repair | 1 | 09-03-2011 06:22 PM |
| dishwasher wont start | bennieportnoy | Dishwasher Repair | 1 | 01-06-2011 01:11 AM |
| Installed Compressor Start Device Kit. Worked fine for 3 minutes. | rballeng | Refrigerator & Freezer Repair | 3 | 10-27-2010 03:06 AM |
| Installed Hard start kit on refrig | Jim Stapleton | Refrigerator & Freezer Repair | 0 | 11-28-2007 10:18 AM |
