Discuss
Whirpool Cycle Problems
 in
Dishwasher Repair
I have a top load Whirpool that won't start it's cycle. As soon as I try to run the washer,
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Whirpool Cycle Problems
  #1 (permalink)
Old 12-22-2012, 11:40 AM
Junior Member
handymangarcia is on a distinguished road
Question Whirpool Cycle Problems
Model Number: WTW55S0200   Brand: Whirlpool   Age: Less than 1 year
I have a top load Whirpool that won't start it's cycle. As soon as I try to run the washer, it will fill with water but WON'T stop. It doesn't overfill, it will only throw water in, keeping filling, keep filling and that's where it's stuck. I was told to check Timer, water level switch, and LID switch. But if I OHM them out, what should it OHM out too? The Water Level switch and LID switch has 3 male pins. What should those pins ohm out too? Also the Timer has about 20 different male pins. How would I check it???
Ads By Google
Related Models
Whirlpool WTW5600SQ0 AUTOMATIC WASHER
Whirlpool WTW5600VQ0 AUTOMATIC WASHER
Whirlpool WTW5600XW0 AUTOMATIC WASHER
Whirlpool WTW5600XW1 AUTOMATIC WASHER
Whirlpool WTW5600XW2 WASHER
Whirlpool WTW5610XW0 AUTOMATIC WASHER
Whirlpool WTW5610XW1 AUTOMATIC WASHER
Whirlpool WTW5610XW2 WASHER
Whirlpool WTW5640XW0 AUTOMATIC WASHER
Whirlpool WTW5640XW1 AUTOMATIC WASHER
Whirlpool WTW5640XW2 WASHER
Whirlpool WTW5700SW0 AUTOMATIC WASHER
Whirlpool WTW5700XL0 AUTOMATIC WASHER
Whirlpool WTW5700XL1 AUTOMATIC WASHER
Whirlpool WTW5700XL2 WASHER
Whirlpool WTW5700XW0 AUTOMATIC WASHER
Whirlpool WTW5700XW1 AUTOMATIC WASHER
Whirlpool WTW5700XW2 WASHER
Whirlpool WTW5790SQ0 AUTOMATIC WASHER
Whirlpool WTW5790SQ2 AUTOMATIC WASHER
Whirlpool WTW5790ST0 AUTOMATIC WASHER
Whirlpool WTW5790ST2 AUTOMATIC WASHER
Whirlpool WTW5790VQ0 AUTOMATIC WASHER
Whirlpool WTW5790VQ1 AUTOMATIC WASHER
Whirlpool WTW5790VQ2 AUTOMATIC WASHER
Whirlpool WTW57ESVH0 AUTOMATIC WASHER
Whirlpool WTW57ESVH1 AUTOMATIC WASHER
Whirlpool WTW57ESVW0 AUTOMATIC WASHER
Whirlpool WTW57ESVW1 AUTOMATIC WASHER
Whirlpool WTW5800SG0 AUTOMATIC WASHER
Whirlpool WTW5800SW0 AUTOMATIC WASHER
Whirlpool WTW5810SW0 AUTOMATIC WASHER
Whirlpool WTW5820SW0 AUTOMATIC WASHER
Whirlpool WTW5821SW0 AUTOMATIC WASHER
Whirlpool WTW5830SW0 AUTOMATIC WASHER
Whirlpool WTW5840SG0 AUTOMATIC WASHER
Whirlpool WTW5840SW0 AUTOMATIC WASHER
Whirlpool WTW5850SG0 AUTOMATIC WASHER
Whirlpool WTW5850SW0 AUTOMATIC WASHER
Whirlpool WTW5860SG0 AUTOMATIC WASHER
Whirlpool WTW5860SW0 AUTOMATIC WASHER
Whirlpool WTW58ESVW0 AUTOMATIC WASHER
Whirlpool WTW58ESVW1 AUTOMATIC WASHER
Whirlpool WTW5900SB0 AUTOMATIC WASHER
Whirlpool WTW5900SW0 AUTOMATIC WASHER
Whirlpool WTW5900TB0 AUTOMATIC WASHER
Whirlpool WTW5900TW0 AUTOMATIC WASHER
Whirlpool WTW6200SW0 AUTOMATIC WASHER
Whirlpool WTW6200SW1 AUTOMATIC WASHER
Whirlpool WTW6200SW2 AUTOMATIC WASHER
Whirlpool WTW6200SW3 AUTOMATIC WASHER
Whirlpool WTW6200VW0 AUTOMATIC WASHER
Whirlpool WTW6200VW1 AUTOMATIC WASHER
Whirlpool WTW6300SB0 AUTOMATIC WASHER
Whirlpool WTW6300SB1 AUTOMATIC WASHER
Whirlpool WTW6300SB2 AUTOMATIC WASHER
Whirlpool WTW6300SG0 AUTOMATIC WASHER
Whirlpool WTW6300SG1 AUTOMATIC WASHER
Whirlpool WTW6300SG2 AUTOMATIC WASHER
Whirlpool WTW6300SW0 AUTOMATIC WASHER
Whirlpool WTW6300SW1 AUTOMATIC WASHER
Whirlpool WTW6300SW2 AUTOMATIC WASHER
Whirlpool WTW6300WW0 AUTOMATIC WASHER
Whirlpool WTW6340WW0 AUTOMATIC WASHER
Whirlpool WTW6400SW0 AUTOMATIC WASHER
Whirlpool WTW6400SW1 AUTOMATIC WASHER
Whirlpool WTW6400SW2 AUTOMATIC WASHER
Whirlpool WTW6400SW3 AUTOMATIC WASHER
Whirlpool WTW6500WW1 AUTOMATIC WASHER
Whirlpool WTW6600SB0 AUTOMATIC WASHER
Whirlpool WTW6600SB1 AUTOMATIC WASHER
Whirlpool WTW6600SB2 AUTOMATIC WASHER
Whirlpool WTW6600SB3 AUTOMATIC WASHER
Whirlpool WTW6600SG0 AUTOMATIC WASHER
Whirlpool WTW6600SG1 AUTOMATIC WASHER
Whirlpool WTW6600SG2 AUTOMATIC WASHER
Whirlpool WTW6600SG3 AUTOMATIC WASHER
Whirlpool WTW6600SW0 AUTOMATIC WASHER
Whirlpool WTW6600SW1 AUTOMATIC WASHER
Whirlpool WTW6600SW2 AUTOMATIC WASHER
Whirlpool WTW6600SW3 AUTOMATIC WASHER
Whirlpool WTW6700TU1 AUTOMATIC WASHER
Whirlpool WTW6700TU2 AUTOMATIC WASHER
Whirlpool WTW6700TW0 AUTOMATIC WASHER
Whirlpool WTW6700TW1 AUTOMATIC WASHER
Whirlpool WTW6700TW2 AUTOMATIC WASHER
Whirlpool WTW6800WB1 AUTOMATIC WASHER
Whirlpool WTW6800WE1 RESIDENTIAL WASHER
Whirlpool WTW6800WL1 AUTOMATIC WASHER
Whirlpool WTW6800WU1 RESIDENTIAL WASHER
Whirlpool WTW6800WW1 AUTOMATIC WASHER
Whirlpool WTW7300XW0 AUTOMATIC WASHER
Whirlpool WTW7300XW1 AUTOMATIC WASHER
Whirlpool WTW7300XW2 AUTOMATIC WASHER
Whirlpool WTW7320YW0 WASHER
Whirlpool WTW7340XW0 AUTOMATIC WASHER
Whirlpool WTW7340XW1 AUTOMATIC WASHER
Whirlpool WTW7340XW2 AUTOMATIC WASHER
Whirlpool WTW7600XW0 AUTOMATIC WASHER
Whirlpool WTW7600XW1 AUTOMATIC WASHER
Whirlpool WTW7600XW2 AUTOMATIC WASHER
Whirlpool WTW7800XB0 AUTOMATIC WASHER
Whirlpool WTW7800XB1 AUTOMATIC WASHER
Whirlpool WTW7800XB2 AUTOMATIC WASHER
Whirlpool WTW7800XB3 AUTOMATIC WASHER
Whirlpool WTW7800XB4 AUTOMATIC WASHER
Whirlpool WTW7800XL0 AUTOMATIC WASHER
Whirlpool WTW7800XL1 AUTOMATIC WASHER
Whirlpool WTW7800XL2 AUTOMATIC WASHER
Whirlpool WTW7800XL3 AUTOMATIC WASHER
Whirlpool WTW7800XL4 AUTOMATIC WASHER
Whirlpool WTW7800XW0 AUTOMATIC WASHER
Whirlpool WTW7800XW1 AUTOMATIC WASHER
Whirlpool WTW7800XW2 AUTOMATIC WASHER
Whirlpool WTW7800XW3 AUTOMATIC WASHER
Whirlpool WTW7800XW4 AUTOMATIC WASHER
Whirlpool WTW7990XG0 AUTOMATIC WASHER
Whirlpool WTW7990XG1 AUTOMATIC WASHER
Whirlpool WTW8200YW0 AUTOMATIC WASHER
Whirlpool WTW8240YW0 AUTOMATIC WASHER
  #2 (permalink)
Old 12-22-2012, 12:16 PM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
Did this unit ever work OK at this location/set up?
Since it never overfills it sounds like the water is draining out as it fills.
The most common cause of this is the stand pipe/drain hose being to low.
I could not find any info on the given model number but here is an install sheet for a unit I think will be similar to yours.
https://www.whirlpool.com/digitalass...0W10150593.pdf
__________________
  #3 (permalink)
Old 12-22-2012, 02:45 PM
Junior Member
Exclamation Whirpool Cycle Problems RE;
Actually yes. This machine has been working here for a year now. It works when it wants too. Like right now it's working just fine. But it's a problem I keep running into.
  #4 (permalink)
Old 12-22-2012, 09:10 PM
Senior Expert
APP Volunteer
Default
Check the drain.
Check if the motor is running.
If the motor is not running then the water may be siphoning out. If it goes into a stand pipe make sure it is not tight in the stand pipe there needs to be some room around it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirpool Washer Will No Go To Rinse Cycle roperstopper Washer Repair 4 09-10-2012 09:54 AM
Whirpool cycle problems Dobbs Washer Repair 2 04-06-2011 04:51 PM
Whirpool Washer - Spin Cycle NOT working VetteandI Washer Repair 2 06-09-2009 08:00 AM
Whirpool Duet Gas Dryer control panel problems moeman12 Dryer Repair 3 02-28-2009 10:29 PM
Whirpool Duet Gas Dryer control panel problems moeman12 Dryer Repair 0 02-24-2009 06:41 PM
