| » whirpool won't drain |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: DU5000XL0 Brand: Whirlpool Age: More than 10 years
although it's over 10 yr old, not often used, however it does not drain. Have removes blades and drain filter, cleaned for clogs and checked hoses. Still does not drain, also asking if there is supposed to be a small ball or marbel in the drain hose.Please help, Thank you, Mark |
remove bottom kick plate cover, remove drain check valve .it is attached to motor on right side, white plastic tube 3 inches long.drain hose attached to it, un threads counter clockwise, crap collects there, reataches at anglefacing downward into motor
__________________
| Display Modes | |
| Whirpool Duet Washer | mansoor ali | Washer Repair | 1 | 12-16-2007 07:45 PM |
| Whirpool gas dryer will not heat | smsgtweber | Dryer Repair | 0 | 12-08-2007 08:48 PM |
| Whirpool Dryer will not heat up | GaryA | Dryer Repair | 1 | 12-06-2007 03:21 PM |
| Kenmore/Whirpool detergent cup (lid) problem | meyerweb | Dishwasher Repair | 1 | 10-12-2007 02:11 AM |
| Need clean cloths, whirpool washer | smurzynski | Washer Repair | 1 | 08-06-2007 04:50 PM |
