:confused:
Hi All,
My dishwasher cycle stops about half way. A DVM tester hooked up to the timer motor leads shows the voltage dropping to zero at this stage.
Is this normal or should the timer motor run continously to the cycle end?
Manually turning the timer restarts the cycle.
Any clues? Tks. :o
