Discuss
Here's how to BOOST internal water pressure for $1.79.
 in
Dishwasher Repair
This was actually my final post from a problem thread. But I thought it might help others so I've given
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Here's how to BOOST internal water pressure for $1.79.
  #1 (permalink)
Old 12-14-2012, 12:40 PM
Junior Member
drkenrich is on a distinguished road
Smile Here's how to BOOST internal water pressure for $1.79.
Model Number: MDBH945AWS   Brand: Maytag   Age: 5 - 10 years
This was actually my final post from a problem thread. But I thought it might help others so I've given it a new title so other can find it. The previous thread was Substitution parts for Paytag Dishwasher?.
Since I couldn't find an expert here that could give me help on increasing my internal circulating water pressure, and wasn't able to find any specs on the parts list for possible replacement, I had to do the DIY method. I made my own with great success!!
All it took was $1.79 for the top of a regular 5 oz. tuna can and three small brass screws no more than 3/8" long. Since I didn't have plans I had to experiment. So, if anyone is reading this thread here's what I learned.
1. The top of the impeller to housing clearance is too close to put anything on top of the impeller.
2. The bottom has enough room to work - but keep it thin.
3. There is some pressure sensor in the system that shuts down if there is too much water pressure. I had a working model, but it kept shutting off after about 10 second of high pressure, then would cycle again. This cleared up when I cut down the size of the "improvement".
4. I won't cover all the little details except think about rust. Use a can and screws that won't rust quickly. It's easy to replace, but why if you don't have to?
Here's how:
1. Cut the bottom out of a 5 oz. tuna, chicken, etc. can. It's about 3 5/8 dia. and about perfect in final size.
2. Drill a tap hole in the very center. Then carefully cut a 1" hole using the tap hole as a guide. I used a 1" wood bit since it's very thin soft metal.
3. With tin snips or kitchen scissors, expand the hole until it fits snuggle around the ring on the bottom of the impeller.
4. Mark the diameter of the impeller on the metal disk. While doing this mark a continuation line of the impeller vanes onto the disk and another line extending from the impeller vane end through the impeller center to the outer edge of the disk. The idea is that you want to extend the vanes for more thrust of the water as the impeller turns.
5. Cut a line from the outer edge of the disk to the edge of the impeller line along the straight line from edge to center. This will be about 1/2" long.
6. Bend to 90 degrees the tabs along the vane lines so when it's fit in place it literally extends the vanes another 1" (approx.).
7. Fit the disk onto the impeller from the bottom with the vanes pointing up and rotate the disk so they line up with the impeller vanes.
8. Cut the bent up vane so that anything extending above the top edge is removed by at least 1/8". This will prevent contact with the upper housing.
9. Once cut to size and lined up properly drill three small holes in the disk and into the bottom of the impeller to fit your three brass screws. Screw it in place and replace everything.
To TEST - Before you replace everything. Screw the impeller in place and install the cover with 3 screws. Run it on rince cycle to make sure it doesn't stop and cycle. If it does simply use the tin snips to cut a little more off the outer edge of the disk and bent up vanes. Try again until it works right.
You'll end up with a lot more internal water stream pressure. I hope someone can use this.
It's the right time of year so - Merry Christmas!
drkenrich
Ads By Google
Related Models
Maytag MDBH945AWS Dishwasher - Undercounter
Maytag MDBH945AWW Dishwasher - Undercounter
Maytag MDBH950AWB Dishwasher - Undercounter
Maytag MDBH950AWQ Dishwasher - Undercounter
Maytag MDBH950AWS Dishwasher - Undercounter
Maytag MDBH950AWW Dishwasher - Undercounter
Maytag MDBH955AWB Dishwasher - Undercounter
Maytag MDBH955AWQ Dishwasher - Undercounter
Maytag MDBH955AWS Dishwasher - Undercounter
Maytag MDBH955AWW Dishwasher - Undercounter
Maytag MDBH965AWB 30" Electric Freestanding Standard Clean Range
Maytag MDBH965AWQ Dishwasher - Undercounter
Maytag MDBH965AWS Dishwasher - Undercounter
Maytag MDBH965AWW Dishwasher - Undercounter
Maytag MDBH970AWB Dishwasher - Undercounter
Maytag MDBH970AWQ Dishwasher - Undercounter
Maytag MDBH970AWS Dishwasher - Undercounter
Maytag MDBH970AWW Dishwasher - Undercounter
Maytag MDBH975AWB Dishwasher - Undercounter
Maytag MDBH975AWS Dishwasher - Undercounter
Maytag MDBH975AWW Dishwasher - Undercounter
Maytag MDBH985AWB10 Undercounter Dishwasher
Maytag MDBH985AWS10 Undercounter Dishwasher
Maytag MDBH985AWW10 Undercounter Dishwasher
Maytag MDBM601AWB Dishwasher - Undercounter
Maytag MDBM601AWQ Dishwasher - Undercounter
Maytag MDBM601AWS Dishwasher - Undercounter
Maytag MDBM601AWW Dishwasher - Undercounter
Maytag MDBM755AWB Dishwasher - Undercounter
Maytag MDBM755AWQ Dishwasher - Undercounter
Maytag MDBM755AWS Dishwasher - Undercounter
Maytag MDBM755AWW Dishwasher - Undercounter
Maytag MDBS561AWB Dishwasher - Undercounter
Maytag MDBS561AWQ Dishwasher - Undercounter
Maytag MDBS561AWS Dishwasher - Undercounter
Maytag MDBS561AWW Dishwasher - Undercounter
Maytag MDBS661AWB Dishwasher - Undercounter
Maytag MDBS661AWQ Dishwasher - Undercounter
Maytag MDBS661AWS Dishwasher - Undercounter
Maytag MDBS661AWW Dishwasher - Undercounter
Maytag MDBTT50AWB Dishwasher - Undercounter
Maytag MDBTT50AWQ Dishwasher - Undercounter
Maytag MDBTT50AWS Dishwasher - Undercounter
Maytag MDBTT50AWW Dishwasher - Undercounter
Maytag MDBTT59AWB Dishwasher - Undercounter
Maytag MDBTT59AWQ Dishwasher - Undercounter
Maytag MDBTT59AWS Dishwasher - Undercounter
Maytag MDBTT59AWW Dishwasher - Undercounter
Maytag MDBTT60AWB Dishwasher - Undercounter
Maytag MDBTT60AWQ Dishwasher - Undercounter
Maytag MDBTT60AWS Dishwasher - Undercounter
Maytag MDBTT60AWW Frigidaire/refrigerator
Maytag MDBTT70AWB Dishwasher - Undercounter
Maytag MDBTT70AWQ Dishwasher - Undercounter
Maytag MDBTT70AWS Dishwasher - Undercounter
Maytag MDBTT70AWW Dishwasher - Undercounter
Maytag MDBTT75AWB Dishwasher - Undercounter
Maytag MDBTT75AWQ Dishwasher - Undercounter
Maytag MDBTT75AWS Dishwasher - Undercounter
Maytag MDBTT75AWW Dishwasher - Undercounter
Maytag MDBTT79AWB Dishwasher - Undercounter
Maytag MDBTT79AWQ Dishwasher - Undercounter
Maytag MDBTT79AWS Dishwasher - Undercounter
Maytag MDBTT79AWW Dishwasher - Undercounter
Maytag MDC4000AWE Dishwasher - Convertible
Maytag MDC4000AWX Dishwasher - Convertible
Maytag MDC4100AWB Dishwasher - Convertible
Maytag MDC4100AWE Dishwasher - Convertible
Maytag MDC4100AWX Dishwasher - Convertible
Maytag MDC4650AWB Dishwasher - Convertible
Maytag MDC4650AWW Dishwasher - Convertible
Maytag MDC5100AWB Dishwasher - Convertible
Maytag MDC5100AWW Dishwasher - Convertible
Magic Chef MDCP1085 Dryer - Ele
Magic Chef MDCP1085- Dryer - Ele
Magic Chef MDCP1085-A Dryer - Ele
Frigidaire MDD25TF1 Frg(v1) / Dehumidifier
Frigidaire MDD25TG1 Gib(v1) / Dehumidifier
Frigidaire MDD25WF1 Frg(v1)
Frigidaire MDD25WG1 Gib(v1) / Dehumidifier
Frigidaire MDD25WW1 Wwh(v1) / Dehumidifier
Frigidaire MDD30FW1 Wwh(v0) / Dehumidifier
Frigidaire MDD30FW2 Wwh(v0) / Dehumidifier
Frigidaire MDD30TF1 Frg(v2) / Dehumidifier
Frigidaire MDD30TG1 Gib(v2) / Dehumidifier
Frigidaire MDD30TG2 Gib(v3) / Dehumidifier
Frigidaire MDD30WF1 Frg(v2)
Frigidaire MDD30WG1 Gib(v2) / Dehumidifier
Frigidaire MDD30WG2 Gib(v0) / Dehumidifier
Frigidaire MDD30WW1 Wwh(v1) / Dehumidifier
Frigidaire MDD40TF1 Frg(v1) / Dehumidifier
Frigidaire MDD40TG1 Gib(v1) / Dehumidifier
Frigidaire MDD40TG3 Gib(v0) / Dehumidifier
Frigidaire MDD40WF1 Frg(v3)
Frigidaire MDD40WF2 Frg(v4)
Frigidaire MDD40WG1 Gib(v3) / Dehumidifier
Frigidaire MDD40WG2 Gib(v4) / Dehumidifier
Frigidaire MDD40WW2 Wwh(v2) / Dehumidifier
Frigidaire MDD40WW4 Wwh(v3) / Dehumidifier
Frigidaire MDD50TF1 Frg(v2) / Dehumidifier
Frigidaire MDD50TF2 Frg(v3) / Dehumidifier
Frigidaire MDD50TG1 Gib(v2) / Dehumidifier
Frigidaire MDD50TG2 Gib(v3) / Dehumidifier
Frigidaire MDD50WF1 Frg(v5)
Frigidaire MDD50WG1 Gib(v5) / Dehumidifier
Frigidaire MDD50WG2 Gib(v0) / Dehumidifier
Frigidaire MDD50WW1 Wwh(v2) / Dehumidifier
Frigidaire MDD50WW2 Wwh(v0) / Dehumidifier
Frigidaire MDDQ40FF1 Frg(v0) / Dehumidifier
Frigidaire MDDQ40FF3 Frg(v0) / Dehumidifier
Frigidaire MDDQ40FG1 Gib(v0) / Dehumidifier
Frigidaire MDDQ40FW1 Wwh(v1) / Dehumidifier
Frigidaire MDDQ40FW3 Wwh(v0) / Dehumidifier
Frigidaire MDDQ50FF1 Frg(v0) / Dehumidifier
Frigidaire MDDQ50FF2 Frg(v0) / Dehumidifier
Frigidaire MDDQ50FF3 Frg(v0) / Dehumidifier
Frigidaire MDDQ50FG1 Gib(v0) / Dehumidifier
Frigidaire MDDQ50FG2 Gib(v0) / Dehumidifier
Frigidaire MDDQ50FG3 Gib(v0) / Dehumidifier
Frigidaire MDDQ50FW1 Wwh(v2) / Dehumidifier
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Internal Water Leak newatappliancerepair Washer Repair 1 12-07-2012 01:45 AM
poor wash, low internal spray pressure rhblack11 Dishwasher Repair 0 01-08-2011 08:45 AM
internal water leak gsmillerjr Refrigerator & Freezer Repair 1 03-01-2009 08:03 AM
Motor humming and water comes but blades don't spin (water pressure problem?) mtheriault3 Dishwasher Repair 4 01-11-2009 04:18 PM
Internal water leak CVN76 Refrigerator & Freezer Repair 1 09-17-2008 08:06 AM
