Frigidaire dishwasher
The circulation pump has the proper voltage, no blockage, so i need to know how to ohm it and what the ohms should be before i call it bad and replace it.
Thank you! |
I do not have a spec on the winding resistance.
But if the motor rotates easily and does not run when it has 120 volts across it then it is toast. |
Quote:
Thanks for your reply! |
| All times are GMT -7. The time now is 04:20 AM. |
