Discuss
Wirlpool dishwasher upper arm not spinning
 in
Dishwasher Repair
I have read a number of articles on this and have managed to take apart the whole washer and clean
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Wirlpool dishwasher upper arm not spinning
  #1 (permalink)
Old 12-13-2012, 06:11 AM
Junior Member
mogul397 is on a distinguished road
Wink Wirlpool dishwasher upper arm not spinning
Brand: Whirlpool   Age: 5 - 10 years
take apart the whole washer and clean it. The upper arm now
seems to have water pressure but does not spin.
1) I read an article about this. Said I need to take #8 off.
I did not. But did everything else
http://www.justanswer.com/appliance/...g-getting.html
2) There is the whole see tube channel. Cleaned that. It
is very small.
3) Is the end of the arm supposed to have notches on it?
Why?
I don't buy the notion that the pump is "weak".
Alan yasu3@verizon.net
Ads By Google
  #2 (permalink)
Old 12-14-2012, 03:46 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
A model number may help others help you.
Find your model number - AppliancePartsPros.com
__________________
  #3 (permalink)
Old 12-14-2012, 05:16 AM
Junior Member
Talking
The model number is GU2500XTPT1.
The link to the parts list is
http://www.*************************...1/1198/0130000.
Alan
  #4 (permalink)
Old 12-14-2012, 10:38 AM
Senior Expert
APP Volunteer
Default
Here are the parts, your link was blocked.
Parts for Whirlpool GU2500XTPT1 Dishwasher - AppliancePartsPros.com
is very small.
Sorry but I do not understand the above
__________________
  #5 (permalink)
Old 12-15-2012, 05:46 AM
Junior Member
Wink
What I mean by "tube channel" is the channel or "pipe" that comes
from the bottom where the water gets pumped up to both
the lower spray arm, and the top sprayer at the top of the machine
to spray on top of all the dishes. I cleans and flushed that whole
pipe, or tube, or whatever you call it.
As to the upper spray arm, I mean exactly what I said. One one side
there were two "notches". Equally spaced and looked like they belonged there. On the other side was a single one, that specifically looked similar to the other two, but a little chipped or broken. But somehow they looked like they are on purpose.
I plugged all 3 holes with epoxy thinking that it was a problem for pressure. When I put it back together to try the whole thing after extensive cleaning and it didn't spin, I drilled a comple replacement holes kind of at the side of the ends thinking that this discharge might propell the arm. Cause I blocked those other holes.
The whole system is kind of weak in how it should be designed to be able to work or thrust that arm and I was SHOCKED to learn the internals of how a dishwasher actually works (Not working off of house water pressure and pumping it in first, etc)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Wirlpool dishwasher will not stop cycling dbarrett76 Dishwasher Repair 1 10-29-2012 03:40 PM
Wirlpool Dishwasher Inlet Valve Voltage nezoic Dishwasher Repair 2 01-08-2012 01:57 PM
Dishwasher, upper arm not spinning MichaelGM Washer Repair 1 06-03-2011 10:05 AM
upper sprayer not spinning john jacques Dishwasher Repair 1 04-06-2011 05:31 AM
Kenmore 665.13832K600 Upper Spray Arms not Spinning robbmiller Dishwasher Repair 7 07-17-2009 03:21 PM
