Discuss
water overflow
 in
Dishwasher Repair
Model Number: SHU5312uc/06 Brand: Bosch Age: 6-10 years I have a Bosh dishwasher model #SHU5312UC/06. That has begun to act
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » water overflow
  #1 (permalink)
Old 12-09-2012, 07:31 PM
Junior Member
culkj is on a distinguished road
Default water overflow
Model Number: SHU5312UC/06   Brand: Bosch   Age: 5 - 10 years
I have a Bosh dishwasher model #SHU5312UC/06. That has begun to act up.
The first symptom occurred about two weeks ago, when the circulator pump failed to shut off. It ran all night, long enough for it to begin to smell (burnt electric odor). Ran the self diagnostic routine and found no codes, but the diagnostic would not finish. The circulator pump ran even though the sump was empty (by sound).
Pulled the bottom access panel and found water. Drained about two quarts. Ran the diagnostic again and noticed a leak t
hat appeared to be coming from the junction of the motor/circulator pump assembly. Bought and installed a new motor, shaft seal, impeller and O ring. No more leaks from the pump. (I pressure tested it with rubber stoppers and compressed air).
I am now showing a diagnostic error code “4” and, on the fill cycle, I have water squirting out of the vent hole in the translucent plastic housing on the left side of the machine that connects the water inlet hose, drain pump hose and drain hose. Directly to the right of this (toward the front of the machine) is a blue plastic housing that holds the water leakage I
float and what I believe to be the water level sensor. Both switches seem to be free and working properly when tested with an amp meter.
I’ve also sight checked both parts of the control board for obvious fault, and can find no evidence of a burnt spot on the board or loose/poor solder connections.
I’m stumped, and would appreciate any help any of you can offer. I can send two pictures, one of the pump leak area (believed to be repaired), and one of the drain assembly where water is now coming out. Beginning to think I should have listened to the wife and sprung for a new machine
Thanks in advance for any help. Sorry pics wouldn't load.
Jack
Ads By Google
Related Models
Bosch SHU5314 UC/06
Bosch SHU5314 UC/11
Bosch SHU5314 UC/12
Bosch SHU5315 UC/06
Bosch SHU5315 UC/06 (FD 7705-7912)
Bosch SHU5315 UC/11
Bosch SHU5315 UC/11 (FD 8001-8003)
Bosch SHU5315 UC/12
Bosch SHU5315 UC/12 (FD 8003-)
Bosch SHU5316 UC/06
Bosch SHU5316 UC/11
Bosch SHU5316 UC/12
Bosch SHU5317 UC/12
Bosch SHU53A02 UC/14 (FD 8211-)
Bosch SHU53A05 UC/14 (FD 8211-)
Bosch SHU53A06 UC/14 (FD 8211-)
Bosch SHU53E02 UC/14 (FD 8211-)
Bosch SHU53E05 UC/14 (FD 8211-)
Bosch SHU53E06 UC/14 (FD 8211-)
Whirlpool SHU55000
Whirlpool SHU55010
Whirlpool SHU55040
Whirlpool SHU55041
Whirlpool SHU55042
Whirlpool SHU60010
Whirlpool SHU60011
Whirlpool SHU60020
Bosch SHU66C02 UC/14 (FD 8211-)
Bosch SHU66C05 UC/14 (FD 8211-)
Bosch SHU66C06 UC/14 (FD 8211-)
Bosch SHU66C07 UC/14 (FD 8211-)
Bosch SHU66E02 UC/14 (FD 8211-)
Bosch SHU66E05 UC/14 (FD 8211-)
Bosch SHU66E06 UC/14 (FD 8211-)
Bosch SHU66E07 UC/14 (FD 8211-)
Bosch SHU6802 UC/06 (FD 7705-7912)
Bosch SHU6802 UC/11 (FD 8001-8003)
Bosch SHU6802 UC/12 (FD 8003-)
Bosch SHU6805 UC/06 (FD 7705-7912)
Bosch SHU6805 UC/11 (FD 8001-8003)
Bosch SHU6805 UC/12 (FD 8003-)
Bosch SHU6806 UC/06 (FD 7705-7912)
Bosch SHU6806 UC/11 (FD 8001-8003)
Bosch SHU6806 UC/12 (FD 8003-)
Whirlpool SHU70000
Whirlpool SHU70001
Whirlpool SHU70010
Whirlpool SHU70040
Whirlpool SHU70041
Whirlpool SHU70050
Whirlpool SHU70051
Whirlpool SHU70052
Whirlpool SHU75000
Whirlpool SHU75010
Whirlpool SHU75040
Whirlpool SHU75042
Whirlpool SHU80000
Whirlpool SHU80001
Whirlpool SHU80010
Whirlpool SHU80040
Whirlpool SHU80041
Whirlpool SHU80042
Bosch SHU8802 UC/12 (FD 8105-)
Bosch SHU8805 UC/12 (FD 8105-)
Bosch SHU8806 UC/12 (FD 8105-)
Bosch SHU8812 UC/12 (FD 8105-)
Bosch SHU8815 UC/12 (FD 8105-)
Bosch SHU8816 UC/12 (FD 8105-)
Whirlpool SHU90000
Whirlpool SHU90001
Whirlpool SHU90002
Whirlpool SHU90010
Whirlpool SHU90040
Whirlpool SHU90041
Whirlpool SHU90050
Whirlpool SHU99000
Whirlpool SHU99001
Bosch SHU9902 UC/06
Bosch SHU9902 UC/06 (FD 7905-7912)
Whirlpool SHU99040
Whirlpool SHU99041
Bosch SHU9905 UC/06
Bosch SHU9905 UC/06 (FD 7905-7912)
Whirlpool SHU99050
Whirlpool SHU99052
Whirlpool SHU99053
Bosch SHU9906 UC/06
Bosch SHU9906 UC/06 (FD 7905-7912)
Bosch SHU9912 UC/06
Bosch SHU9912 UC/06 (FD 7908-8002)
Bosch SHU9912 UC/11
Bosch SHU9912 UC/11 (FD 8002-8003)
Bosch SHU9912 UC/12
Bosch SHU9912 UC/12 (FD 8003-)
Bosch SHU9915 UC/06
Bosch SHU9915 UC/06 (FD 7908-8002)
Bosch SHU9915 UC/11
Bosch SHU9915 UC/11 (FD 8002-8003)
Bosch SHU9915 UC/12
Bosch SHU9915 UC/12 (FD 8003-)
Bosch SHU9916 UC/06
Bosch SHU9916 UC/06 (FD 7908-8002)
Bosch SHU9916 UC/11
Bosch SHU9916 UC/11 (FD 8002-8003)
Bosch SHU9916 UC/12
Bosch SHU9916 UC/12 (FD 8003-)
Bosch SHU9922 UC/12 (FD 8003-)
Bosch SHU9925 UC/12 (FD 8003-)
Bosch SHU9926 UC/12 (FD 8003-)
Bosch SHU9952 UC/12 (FD 8105 -)
Bosch SHU9955 UC/12 (FD 8105 -)
Bosch SHU9956 UC/12 (FD 8105 -)
Bosch SHV4303 UC/06
Bosch SHV4303 UC/06 (FD 7712-8002)
Bosch SHV4303 UC/11
Bosch SHV4303 UC/11 (FD 8002-8003)
Bosch SHV4303 UC/12
Bosch SHV4303 UC/12 (FD 8003-)
Bosch SHV46C03 UC/14 (FD 8211-)
Bosch SHV4803 UC/06
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Water Overflow Tenn47 Washer Repair 2 12-06-2011 07:33 PM
Water overflow or spins out lscrisp Washer Repair 2 11-12-2009 06:11 PM
Water inlet overflow Steve A Dishwasher Repair 0 10-15-2009 02:41 PM
Water will overflow once in a while tlk1102 Washer Repair 1 04-22-2009 11:49 AM
water overflow Andrewca Washer Repair 1 12-01-2008 09:16 AM
