| » soap still on door |
Model Number: HDA3400G02BB Brand: Hotpoint Age: 5 - 10 years
New water on off value- water line- water inlet value, will fill to start later open door while in later cycle & there isn't enouth water in washer-soap left in main cup-cup did open??????Check drain solenoid, it is fine-check continuity ,ok- it will engage but not disengage. There is steal juice to it,flip door latch & it will release. till it is time for it to engage again & it still will not release till juice is brock. Is this the timer or some thing else.HELP
Ads By Google Related Models Last edited by Ray D G : 12-10-2012 at 08:30 PM. |
Parts for GE HDA3400G02BB Dishwasher - AppliancePartsPros.com Remove the kick plate and look at the wash drain solenoid on the left front of the pump. Check that the springs are pulling the solenoid plunger all the way back up. This is the wash position. Down is the drain position. So if it does not go all the way out some water can leak past the flapper valve and out the drain.
__________________
Quote:
The drain solenoid will not release once it engages- it checks out fine- what stops the current to it . The timer or in line switch
The timer. The way it is suppose to work is that at the start of a drain cycle the solenoid is powered on for a couple seconds. The solenoid piston is pulled down, the flapper moves to the drain position and the water pressure holds it there until the unit is empty. The springs then pull the piston/flapper back to the wash position (up). Sometimes the timer can power the solenoid for too long. It then overheats and melts the plastic in the solenoid causing binding etc. So usually when you find a melted solenoid it is a good idea to also replace the timer.
__________________
| Display Modes | |
| soap dispenser door | charliechan | Dishwasher Repair | 0 | 12-18-2011 10:52 AM |
| Soap door opens but soap just runs down door and sits on the bottom | MsCrystalNorton | Dishwasher Repair | 3 | 06-08-2011 03:25 AM |
| Bosch soap door | Matt K | Dishwasher Repair | 0 | 03-13-2011 10:18 AM |
| whirlpool soap door | motman | Dishwasher Repair | 1 | 10-27-2009 01:59 AM |
| Kenmore Soap Door | rpaquin1 | Dishwasher Repair | 3 | 03-20-2009 04:11 PM |
