Discuss
dishwasher drain problem
 in
Dishwasher Repair
after wash cycle water does not drain. tried reset and sometimes it will drain and other times it won't
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » dishwasher drain problem
  #1 (permalink)
Old 02-01-2008, 06:51 PM
roger1477 roger1477 is offline
Junior Member
roger1477 is on a distinguished road
Default dishwasher drain problem
Model Number: GSD5920F00   Brand: GE   Age: 5 - 10 years
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-02-2008, 03:37 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
I would first check the piston and nut check valve under the filter at the back of the unit, It might me stuck open, if so, order a new one p#AP2617344
If ok, pull out unit and check the pump and clean any items stuck in there.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana Refrigerator drain freeze problem Scottrse1 Refrigerator & Freezer Repair 7 09-05-2008 06:34 PM
Drain / Spin Problem JohnB1984 Washer Repair 2 01-25-2008 05:43 PM
Spin/Drain Problem ttaylor Washer Repair 1 01-18-2008 01:29 PM
drain/spin problem lymtics Washer Repair 1 10-29-2007 04:48 PM
problem with drain pan tyrone Refrigerator & Freezer Repair 0 08-24-2007 09:56 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
