Discuss
FGHD2433KF1 - cannot select all options from touchpad.
 in
Dishwasher Repair
I have a frigidaire dishwasher FGHD2433KF1. I can no longer select some of the options on the touchpad. For instance,
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » FGHD2433KF1 - cannot select all options from touchpad.
  #1 (permalink)
Old 12-02-2012, 07:15 PM
Junior Member
luvboating is on a distinguished road
Default FGHD2433KF1 - cannot select all options from touchpad.
Brand: Frigidaire   Age: 1 - 5 years
I have a frigidaire dishwasher FGHD2433KF1. I can no longer select some of the options on the touchpad. For instance, I press normal wash and it will not select. When I powered off the dishwasher and powered it back on, it jumps to the top rack option. It will run this option, however, the display for remaining minutes on the wash cycle jumps from the 40 minute range to the 90 minute range and back. I cannot select any of the delayed start options either. What part do you think is bad or should i try some way to clear the problem?
  #2 (permalink)
Old 12-03-2012, 03:26 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Most likely there is the problem with the control panel. However there is the small chance it's the control board.
Part number: 154791806
Here are the breakdown diagrams and Control Panel parts for Frigidaire FGHD2433KF1 - AppliancePartsPros.com
Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 12-03-2012, 03:42 PM
Junior Member
Default
I went ahead and ran the dishwasher with the top rack button selected. My dishes got clean. Now, it appears the control panel is back to normal. I will see how it performs on the normal wash cycle the next time since it is now selectable.
  #4 (permalink)
Old 12-18-2012, 09:27 AM
Junior Member
Default
The dishwasher ran for a little while today, the soap door opened and it halted. I turned off power at the breaker and back on. I can select any wash cycle, shut the door, then after a few seconds, the selected wash cycle light goes out and the dishwasher does not start. Looks like it is fried now.
  #5 (permalink)
Old 12-18-2012, 12:13 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Just to add my 2 cents...
I do not see any other solution but the one offered by Simon. Replace the control panel. If it would not fix the problem then replace the control board. You may want to order both parts together from APP to give them a try and return unneeded part later. Only APP gives you the option to return any part even if it was installed.
- The control board Part number: 154815601
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #6 (permalink)
Old 12-22-2012, 02:05 PM
Junior Member
Default
I replaced the control panel and control board and it still behaves the same. The dishwasher will allow the selection of any wash cycle, but will not start, and after several seconds the light indicating the wash cycle turns off. I checked for loose wires and could not find any. I remembered the last partial run cycle ended when the detergent came out of the dispenser door. I unplugged the leads from the detergent dispenser and plugged them back in and it still would not start a cycle. I then unplugged one of the wires from the jet dry dispenser and the washer now starts. It ran a partial cycle and now i get an error code. Everything on the error code panel flashes, It is flashing washing, drying, Er, clean and S. I unplugged the other wire from the jet dry dispenser and now I can only select the top rack cycle. It is now attempting to run the top rack cycle. Do you think I should replace the dispenser next?
  #7 (permalink)
Old 12-22-2012, 03:59 PM
Junior Member
Default
It completed the top rack cycle and the dishes were clean. The jet dry dispenser was disconnected the whole time. Now it is back to letting me select a normal wash cycle with no start and the normal wash cycle light going out in a few seconds. I think I will call a repairman.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
program select/time select - clock does not work DEAN DAGGETT Oven Repair (including Ranges and Cooktops) 1 04-29-2013 03:08 PM
Refrig options to consider Moscow1 Refrigerator & Freezer Repair 1 06-17-2011 11:06 AM
Half of the options work scott@kunuku.com Oven Repair (including Ranges and Cooktops) 0 11-27-2010 05:12 PM
