Discuss
Bosch dishwasher lukewarm water
 in
Dishwasher Repair
Symptoms: Dishwasher displays a long cycle time (160 min instead of 120) and water doesn't get very hot (though there
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch dishwasher lukewarm water
  #1 (permalink)
Old 11-30-2012, 09:33 AM
Junior Member
johnmay is on a distinguished road
Default Bosch dishwasher lukewarm water
Model Number: SHE55M15UC/57   Brand: Bosch   Age: 1 - 5 years
Symptoms: Dishwasher displays a long cycle time (160 min instead of 120) and water doesn't get very hot (though there is some heating).
What I've tried
  1. Removed the control board and inspected the the solder joints. Everything looked fine.
  2. Our cat found a rat under the dishwasher a day or so before this problem started. The rat was removed, and I pulled out the dishwasher and looked for signs of damage. Other than a little rat pee that I cleaned up, I didn't see any problems, though it's hard to get a good look underneath.
  3. I reinstalled control module and tested the A/C voltage on the two wires coming from the largest connector coming off it. One showed about 120v compared to the chassis, the other showed a fraction of a volt when tested at different times in the first 20 minutes or so of the cycle. Based on other internet posts, I thought this indicated a bad relay, so the water heating element wasn't getting turned on.
  4. Ordered a new control module and installed it. When I plugged the d/w back in, the display said "E2", two lights flashed on the display, and water cycled through the system for a few minutes. I turned the d/w off and then started a new cycle. The display read a normal 120 minutes, but the water still didn't get very hot. It seemed cool 20 minutes into the cycle, and after the end of the cycle the dishes were warm but not hot. I've only run it this one time since installing the new module, so I don't know if the cycle time will now go back up to 160 minutes.
I'm about to give up and call a pro, but I thought I'd check here first to see if there's anything else I can try.
Thanks for any help you can offer!
Ads By Google
Related Models
Whirlpool SHF3800W0
Whirlpool SHF3800W1
Whirlpool SHF3801W0
Whirlpool SHF3804W0
Whirlpool SHF3804W2
Whirlpool SHF4500W0
Whirlpool SHF5500W0
Whirlpool SHF5501W0
Whirlpool SHF5504W0
Whirlpool SHF5584P0
Whirlpool SHF5584P1
Whirlpool SHF5584P2
Whirlpool SHF5800W0
Whirlpool SHF5800W1
Whirlpool SHF5801W0
Whirlpool SHF5801W1
Whirlpool SHF5880P0
Whirlpool SHF5884P0
Whirlpool SHF5884P1
Whirlpool SHF5884P2
Whirlpool SHF6000W0
Whirlpool SHF6000W1
Whirlpool SHF6002W0
Whirlpool SHF7800W0
Whirlpool SHF7800W1
Whirlpool SHF7801W0
Whirlpool SHF7804W0
Whirlpool SHF7804W1
Whirlpool SHF7884P0
Whirlpool SHF7884P1
Whirlpool SHF7884P2
Bosch SHI4302 UC/06 -FD8002
Bosch SHI4302 UC/11 -FD8003
Bosch SHI4302 UC/12
Bosch SHI4306 UC/06 -FD8002
Bosch SHI4306 UC/11 -FD8003
Bosch SHI4306 UC/12
Bosch SHI66A05 UC/14 (FD 8211-)
Bosch SHI6802 UC/06
Bosch SHI6802 UC/11
Bosch SHI6802 UC/12
Bosch SHI6805 UC/06
Bosch SHI6805 UC/11
Bosch SHI6805 UC/12
Bosch SHI6806 UC/06
Bosch SHI6806 UC/11
Bosch SHI6806 UC/12
Whirlpool SHU30000
Whirlpool SHU30010
Whirlpool SHU30011
Bosch SHU3002
Whirlpool SHU30040
Whirlpool SHU30041
Bosch SHU3006
Whirlpool SHU30110
Bosch SHU3012
Whirlpool SHU30140
Whirlpool SHU30141
Bosch SHU3016
Bosch SHU3032 UC/06 (FD 7908-8002)
Bosch SHU3032 UC/11 (FD 8002-8003)
Bosch SHU3032 UC/12 (FD 8003-)
Bosch SHU3035 UC/12 (FD 8006-)
Bosch SHU3036 UC/06 (FD 7908-8002)
Bosch SHU3036 UC/11 (FD 8002-8003)
Bosch SHU3036 UC/12 (FD 8003-)
Bosch SHU3132 UC/12 (FD 8105-)
Bosch SHU3135 UC/12 (FD 8105-)
Bosch SHU3136 UC/12 (FD 8105-)
Bosch SHU3302 UC/06 (FD 7902-8003)
Bosch SHU3302 UC/11 (FD 8003-8003)
Bosch SHU3302 UC/12 (FD 8003 -)
Bosch SHU3305 UC/06 (FD 7902-8003)
Bosch SHU3305 UC/11 (FD 8003-8003)
Bosch SHU3305 UC/12 (FD 8003 -)
Bosch SHU3306 UC/06 (FD 7902-8003)
Bosch SHU3306 UC/11 (FD 8003-8003)
Bosch SHU3306 UC/12 (FD 8003 -)
Bosch SHU3307 UC/12 (FD 8005 -)
Bosch SHU3322 UC/06
Bosch SHU3322 UC/11
Bosch SHU3322 UC/12
Bosch SHU3322 UC/12 (FD 8003-)
Bosch SHU3326 UC/06
Bosch SHU3326 UC/11
Bosch SHU3326 UC/12
Bosch SHU3326 UC/12 (FD 8003-)
Bosch SHU3336 UC/06
Bosch SHU3336 UC/11
Bosch SHU3336 UC/12
Bosch SHU3336 UC/12 (FD 8003-)
Bosch SHU33A02 UC/14 (FD 8211-)
Bosch SHU33A06 UC/14 (FD 8211-)
Bosch SHU33AC02 UC/14
Bosch SHU33AC06 UC/14
Whirlpool SHU40000
Whirlpool SHU40010
Whirlpool SHU40011
Bosch SHU4002 UC/06
Whirlpool SHU40040
Whirlpool SHU40041
Bosch SHU4006 UC/06
Bosch SHU4016 UC/06
Bosch SHU4022 UC/06
Bosch SHU4026 UC/06
Bosch SHU4036 UC/06
Bosch SHU4302 UC/06 (FD 7705-7912)
Bosch SHU4302 UC/11 (FD 8001-8003)
Bosch SHU4302 UC/12 (FD 8003-)
Bosch SHU4306 UC/06 (FD 7705-7912)
Bosch SHU4306 UC/11 (FD 8001-8003)
Bosch SHU4306 UC/12 (FD 8003-)
Bosch SHU4312 UC/06 (FD 7701-7912)
Bosch SHU4312 UC/11 (FD 8001-8003)
Bosch SHU4312 UC/12 (FD 8003-)
Bosch SHU4316 UC/06
Bosch SHU4316 UC/11
Bosch SHU4316 UC/12
Bosch SHU4322 UC/12
Bosch SHU4322 UC/12 (FD 8003-)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch dishwasher no hot water samsrc Dishwasher Repair 2 02-19-2011 07:21 PM
Bosch Dishwasher- No water sw1956 Dishwasher Repair 0 04-17-2010 04:31 PM
Bosch Dishwasher No Water smarino Dishwasher Repair 0 05-31-2009 08:24 AM
no water out in my Bosch dishwasher arwen Dishwasher Repair 0 05-28-2009 06:48 PM
bosch dishwasher won't take water jeff26 Dishwasher Repair 5 04-13-2009 04:23 PM
