| » Wiring diagram for Kenmore? |
Model Number: 66515962990 Brand: Kenmore Age: 5 - 10 years
Just replaced a door switch and Now I'm not sure if I have the wiring right?
Can't find a wiring diagram to show me the colors. Switch tested bad, so I'm hoping that was it. No lights and no response from any buttons. Just need to know which wires go where 4 on switches and 2 from outer door to inner door. Thanks for any help ppritchard@cfl.rr.com Ads By Google Related Models |
Is the wiring diagram you have the same as the attachment?
If yes. Then one switch gets a Tan and a BlacK. The other switch gets a White and a White-Violet (may be just another White). It does not matter which connectors on the switch as long as they are 2 prong switches. I do not know what you ean by inner and outer door wires.
__________________
OK - so no polarity issues with which of the wires goes on either side of the switch?
There are 2 wires that go from the wiring harness area of the outer door to a connector on the inside side of the door. Not sure what they are for. thanks |
No. You do not have to worry about polarity in an AC circuit. There are 2 wires that go from the wiring harness area of the outer door to a connector on the inside side of the door. Not sure what they are for. What color are they?
__________________
| Display Modes | |
| wiring disconnected from timer, need wiring diagram | Chip65 | Dryer Repair | 1 | 12-03-2011 01:24 AM |
| Need wiring diagram for Kenmore 400 series dryer | MarthaV | Dryer Repair | 5 | 07-18-2011 06:25 AM |
| Defrost thermostat wiring, wiring diagram | jaalmdo | Refrigerator & Freezer Repair | 0 | 12-27-2010 08:10 AM |
| Wiring diagram for Kenmore Classic Grille | jeanberube | Oven Repair (including Ranges and Cooktops) | 0 | 04-04-2009 12:51 PM |
| need wiring diagram for kenmore electric dryer | heilman47978 | Dryer Repair | 0 | 12-13-2008 07:01 PM |
