Hi, the handle/latch just under the front control panel is broken. It is no longer flush with the front and is now depressed up and inside the panel and a bit corroded, that is the left side of the handle is depressed less than the right side. It will still work, but you have to kind of reach up into and press to a greater depth to make it unlatch the door. I don't know if the handle itself is broken or something to which it attaches inside is broken. Here are my questions. How do I get to the latch assembly and when I get there, how can I tell what part is broken. Will it be obvious? I hope it is simply the handle. Perhaps one of its fulcrum points (hinges) is broken. Thanks for the help.
