| » Maytag D/W won't drain |
Model Number: MDB9150AWS Brand: Maytag Age: 5 - 10 years
My Maytag MDB9150AWS just started misbehaving, making a clicking noise when it should drain. I've taken it apart from above the drain to the impeller and it isn't clogged above. I've taken off the drain line and it's clear. I've run the automatic self-test and it fails indicating a problem with the "Motor - Low Current". Note: The motor does run in some instances (I can see the shaft spin from below). So, do I replace the circuit board, replace the motor, test the motor for a short or burnout, or buy a new dishwasher? And if it's test or replace, any tips are appreciated.
| Display Modes | |
| Maytag Bravo will not drain (Long drain code F32) | tjemery | Washer Repair | 0 | 10-06-2012 02:42 PM |
| Maytag D/W: - drain after wash issue but cancel/drain works fine after.... | diesan2011 | Dishwasher Repair | 0 | 08-10-2011 11:39 AM |
| Maytag won't drain | GEORGE6149 | Dishwasher Repair | 2 | 01-14-2009 05:16 PM |
| Old Maytag won't drain | pullmyfinger | Washer Repair | 4 | 12-16-2008 04:33 PM |
| Maytag won't drain | grandslam | Dishwasher Repair | 0 | 03-30-2008 08:17 AM |
