| » reset has no effect, drain pump stays on |
Model Number: GSD4410x66 Brand: GE Age: More than 10 years
While away a power failure occurred. Pressed the reset only to have the pump go on and stay on. Have a C4 code and pump on when door is closed. No water is in the tub. I also cut the circuit breaker on and off but this had no effect.
C4 Error: the machine thinks there is too much water in it. The flood switch is probably stuck closed. Make sure nothing is caught under the float assembly. It's the micro switch attached to the bottom of the float assembly. Turn the power off and check it for continuity.
__________________
Ricks Appliance Repair |
| Display Modes | |
| GE dishwasher Reset light blinking will not reset when pressed and unit is not workin | Caesar100 | Dishwasher Repair | 0 | 01-07-2012 12:04 PM |
| bosch shu9925 - drain pump works, won't drain after cycle | mjbarr | Dishwasher Repair | 0 | 10-16-2009 01:11 PM |
| will not drain or reset | 4everwork | Dishwasher Repair | 4 | 10-07-2008 05:22 PM |
| will this pump also pump the drain water out | Paul Radovsky | Dishwasher Repair | 5 | 07-20-2008 01:41 PM |
| Dishwasher drain pump stays on continuously | WilliamS | Dishwasher Repair | 5 | 05-30-2008 03:37 PM |
