Discuss
Frigidaire Dishwasher Electrical Burning Smell While Running...Not From Coil
 in
Dishwasher Repair
Hi folks, I've been doing a ton of searching/researching over the last few days trying to get to the root
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Frigidaire Dishwasher Electrical Burning Smell While Running...Not From Coil
  #1 (permalink)
Old 11-14-2012, 06:27 PM
Junior Member
netwreck94 is on a distinguished road
Default Frigidaire Dishwasher Electrical Burning Smell While Running...Not From Coil
Model Number: FDB1050REC2   Brand: Frigidaire   Age: 1 - 5 years
Hi folks,
I've been doing a ton of searching/researching over the last few days trying to get to the root of the problem with my dishwasher. It's a 4 year old Frigidaire FDB1050REC2...fairly basic model with an exposed heating coil. Recently I've noticed a terrible electrical/plastic type burning smell during operation. I've checked the coil and it's completely free of debris and not emitting any smoke. The smell seems to be coming from either the crevace between my countertop and dishwasher, or from the little steam vent on the front left side. However, I don't seem to notice it from the inside of the washer when I open it, or from the bottom. I took off the spray arms as well as the filter/filter cover and didn't notice anything out of the ordinary. It still runs/washes, but the smell gets overwhelming after about 10 minutes...I don't smell or notice it during the first 10. Also, once I notice the smell it seems to wax and wane---I've sat by the front of it for about 10 minutes and the smell would come and go as the cycles switched. I know that it cycles from spraying the bottom arm to the top arm and vice versa, as well as pumping out inital pre-wash cleaning water. I'm not very mechanically inclined so outside of a visual inspection I couldn't notice anything wrong, nor could I probably repair it if I had. I'm hoping there may be a simple fix, but by the type of smell, dismal quality of fridigaire products, and cost of parts/labor to diagnose I don't see it as worth it unless I find something obvious. Any tips would be much appreciated.
Thank You
Evan
Ads By Google
Related Models
Frigidaire FDB1050REC2 Frigidaire/dishwasher
Frigidaire FDB1050REC3 DISHWASHER
Frigidaire FDB1050REC4 DISHWASHER
Frigidaire FDB1050REC5 DISHWASHER
Frigidaire FDB1050REM0 Frigidaire/dishwasher
Frigidaire FDB1050REM1 Frigidaire/dishwasher
Frigidaire FDB1050REM2 Frigidaire/dishwasher
Frigidaire FDB1050REM3 DISHWASHER
Frigidaire FDB1050REM4 DISHWASHER
Frigidaire FDB1050REM5 DISHWASHER
Frigidaire FDB1050REQ0 Frigidaire/dishwasher
Frigidaire FDB1050REQ1 Frigidaire/dishwasher
Frigidaire FDB1050REQ2 Frigidaire/dishwasher
Frigidaire FDB1050REQ3 DISHWASHER
Frigidaire FDB1050REQ4 DISHWASHER
Frigidaire FDB1050REQ5 DISHWASHER
Frigidaire FDB1050RES0 Frigidaire/dishwasher
Frigidaire FDB1050RES1 Frigidaire/dishwasher
Frigidaire FDB1050RES2 Frigidaire/dishwasher
Frigidaire FDB1050RES3 DISHWASHER
Frigidaire FDB1050RES4 DISHWASHER
Frigidaire FDB1050RES5 DISHWASHER
Frigidaire FDB1051REB0 Frigidaire/dishwasher
Frigidaire FDB1051REB1 Frigidaire/dishwasher
Frigidaire FDB1051REB2 Frigidaire/dishwasher
Frigidaire FDB1051REM0 Frigidaire/dishwasher
Frigidaire FDB1051REM1 Frigidaire/dishwasher
Frigidaire FDB1051REM2 Frigidaire/dishwasher
Frigidaire FDB1051REQ0 Frigidaire/dishwasher
Frigidaire FDB1051REQ1 Frigidaire/dishwasher
Frigidaire FDB1051REQ2 Frigidaire/dishwasher
Frigidaire FDB1051RES0 Frigidaire/dishwasher
Frigidaire FDB1051RES1 Frigidaire/dishwasher
Frigidaire FDB1051RES2 Frigidaire/dishwasher
Frigidaire FDB10NRBB0 Frigidaire/dishwasher
Frigidaire FDB10NRBB1 Frigidaire/dishwasher
Frigidaire FDB10NRBB2 Frigidaire/dishwasher
Frigidaire FDB1100RHB0 DISHWASHER
Frigidaire FDB1100RHB2 DISHWASHER
Frigidaire FDB1100RHB2A DISHWASHER
Frigidaire FDB1100RHC0 DISHWASHER
Frigidaire FDB1100RHC2 DISHWASHER
Frigidaire FDB1100RHC2A DISHWASHER
Frigidaire FDB1100RHM0 DISHWASHER
Frigidaire FDB1100RHM2 DISHWASHER
Frigidaire FDB1100RHM2A DISHWASHER
Frigidaire FDB1100RHQ0 DISHWASHER
Frigidaire FDB1100RHQ2 DISHWASHER
Frigidaire FDB1100RHQ2A DISHWASHER
Frigidaire FDB1100RHS0 DISHWASHER
Frigidaire FDB1100RHS2 DISHWASHER
Frigidaire FDB1100RHS2A DISHWASHER
Frigidaire FDB1200RGB0 DISHWASHER
Frigidaire FDB1200RGB1 DISHWASHER
Frigidaire FDB1200RGB2 DISHWASHER
Frigidaire FDB1200RGC0 DISHWASHER
Frigidaire FDB1200RGC1 DISHWASHER
Frigidaire FDB1200RGC2 DISHWASHER
Frigidaire FDB1200RGQ0 DISHWASHER
Frigidaire FDB1200RGQ1 DISHWASHER
Frigidaire FDB1200RGQ2 DISHWASHER
Frigidaire FDB1200RGS0 DISHWASHER
Frigidaire FDB1200RGS1 DISHWASHER
Frigidaire FDB1200RGS2 DISHWASHER
Frigidaire FDB1250REB0 Frigidaire/dishwasher
Frigidaire FDB1250REB1 Frigidaire/dishwasher
Frigidaire FDB1250REB2 Frigidaire/dishwasher
Frigidaire FDB1250REB3 DISHWASHER
Frigidaire FDB1250REB4 DISHWASHER
Frigidaire FDB1250REC0 Frigidaire/dishwasher
Frigidaire FDB1250REC1 Frigidaire/dishwasher
Frigidaire FDB1250REC2 Frigidaire/dishwasher
Frigidaire FDB1250REC3 DISHWASHER
Frigidaire FDB1250REC4 DISHWASHER
Frigidaire FDB1250REQ0 Frigidaire/dishwasher
Frigidaire FDB1250REQ1 Frigidaire/dishwasher
Frigidaire FDB1250REQ2 Frigidaire/dishwasher
Frigidaire FDB1250REQ3 DISHWASHER
Frigidaire FDB1250REQ4 DISHWASHER
Frigidaire FDB1250RES0 Frigidaire/dishwasher
Frigidaire FDB1250RES1 Frigidaire/dishwasher
Frigidaire FDB1250RES2 Frigidaire/dishwasher
Frigidaire FDB1250RES3 DISHWASHER
Frigidaire FDB1250RES4 DISHWASHER
Frigidaire FDB125RHB0 Dishwasher
Frigidaire FDB125RHB1 DISHWASHER
Frigidaire FDB125RHB2 Frigidaire/dishwasher
Frigidaire FDB125RHB3 Frigidaire/dishwasher
Frigidaire FDB125RHD0 Dishwasher
Frigidaire FDB125RHD1 DISHWASHER
Frigidaire FDB125RHD2 Frigidaire/dishwasher
Frigidaire FDB125RHD3 Frigidaire/dishwasher
Frigidaire FDB125RHS0 Dishwasher
Frigidaire FDB125RHS1 DISHWASHER
Frigidaire FDB125RHS2 Frigidaire/dishwasher
Frigidaire FDB125RHS3 Frigidaire/dishwasher
Frigidaire FDB125RHU0 Frigidaire/dishwasher
Frigidaire FDB125RHU1 Frigidaire/dishwasher
Frigidaire FDB126RBB0 Frigidaire/dishwasher
Frigidaire FDB126RBB1 Frigidaire/dishwasher
Frigidaire FDB126RBB2 Frigidaire/dishwasher
Frigidaire FDB126RBB3 Frigidaire/dishwasher
Frigidaire FDB126RBB4 Frigidaire/dishwasher
Frigidaire FDB126RBQ0 Frigidaire/dishwasher
Frigidaire FDB126RBQ1 Frigidaire/dishwasher
Frigidaire FDB126RBQ2 Frigidaire/dishwasher
Frigidaire FDB126RBQ3 Frigidaire/dishwasher
Frigidaire FDB126RBQ4 Frigidaire/dishwasher
Frigidaire FDB126RBS0 Frigidaire/dishwasher
Frigidaire FDB126RBS1 Frigidaire/dishwasher
Frigidaire FDB126RBS2 Frigidaire/dishwasher
Frigidaire FDB126RBS3 Frigidaire/dishwasher
Frigidaire FDB126RBS4 Frigidaire/dishwasher
Frigidaire FDB130RGB0 Frigidaire/dishwasher
Frigidaire FDB130RGB1 DISHWASHER
Frigidaire FDB130RGB2 DISHWASHER
Frigidaire FDB130RGB3 DISHWASHER
Frigidaire FDB130RGQ0 Frigidaire/dishwasher
Frigidaire FDB130RGQ1 DISHWASHER
Frigidaire FDB130RGQ2 DISHWASHER
  #2 (permalink)
Old 11-17-2012, 02:18 AM
Junior Member
Default
Update...Decided that due to the extreme smell and the likely chance that it's terminal I decided to simply buy a new one. For anyone looking for a new dishwasher for a great deal...there's a seller on ******** "markdown madness" located in WNY that sells all kinds of high-end appliances at huge savings. Some have very minor "scratches/dents" and some are mint in factory packaging (all have full warranty). I purchased a brand new Bosch SHE3AR56UC which is around a $500+ DW for $213 with free local pickup. It has a couple of miniscule dents that aren't noticable since it's black. Also, Sears has a Kenmore Top Control full Stainless DW for $341, and then there's a $35 and $50 coupon to get it down to $256! (MSRP is $700)
Lots of great info on this site, very happy I stumbled upon it.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore electrical burning smell swiet3 Washer Repair 4 05-20-2011 05:39 AM
Electrical burning smell when using microwave mikaymo Microwave Repair 0 04-02-2011 05:23 PM
Whirlpool dishwasher burning smell & coil is brown THINGUYEN Dishwasher Repair 1 10-17-2009 05:04 AM
dishwasher burning smell and coil is brown arunp Dishwasher Repair 0 10-06-2009 03:53 PM
electrical burning smell sharky1 Washer Repair 0 11-28-2008 02:30 PM
